Diresta
LAN to LAN forwarding
Sun Jun 28, 2020 10:25 pm
I am trying to set up forwarding rules to redirect traffic from one to another device within the same LAN so I can silently migrate services from one server to another without having to change IP adresses for everyone that's on the LAN network. Once all services are migrated the new server will be assigned the IP of the old one and the redirect rules will be disabled.
In a bit more detail. What I'm trying to achieve is forwarding data going to old server (192.168.10.125 port 150) to new server (192.168.10.126 port 10000).
So far I managed to set up the following rules:
add action=masquerade chain=srcnat comment="Allow internet access through WAN port" ipsec-policy=out,none out-interface-list=WAN
add action=dst-nat chain=dstnat comment="External forward does work" dst-address-list=Home dst-port=150 protocol=tcp to-addresses=192.168.10.126 to-ports=10000
add action=dst-nat chain=dstnat comment="Internal forward does not work" dst-address=192.168.10.125 dst-port=150 protocol=tcp to-addresses=192.168.10.126 to-ports=10000
add action=masquerade chain=srcnat comment="Give Lan access to local devices via WAN IP" dst-address-list=LAN out-interface=bridge src-address-list=LAN
The port forward using the WAN ip works but through the LAN forward it just times out. I've spent nearly the entire day trying different setups and reading up on Hairpin NAT but I'm at a total loss on this one. I hope someone can help me solve this problem.
xvo
Forum Veteran
Forum Veteran
Re: LAN to LAN forwarding
Sun Jun 28, 2020 10:38 pm
You need to use bridge filter and bridge nat for the traffic inside your LAN.
And even then it will work only if the path from client to server physically lies via you router.
If, for example the client and server are connected to the switch, and not to the router directly, that won't work at all.
sindy
Sun Jun 28, 2020 10:45 pm
It may be simpler to temporarily dedicate a subnet different from 192.168.10.0/24 for the server, so that the clients would have to use the router as a gateway. Bridge NAT rules are a nightmare (ARP handling is necessary, NAT is not stateful...)
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Diresta
Mon Jun 29, 2020 10:35 am
Thanks to the both of you for the reply. It seems this answer from sindy is the easiest to setup:
I have created a new subnet and assigned the new server and ip on it (192.168.12.25) but I still have the same forwarding problem. Would it be possible to provide me with an example of how I should redirect my traffic from 192.168.10.125:150 to 192.168.12.10000?
Zacharias
Mon Jun 29, 2020 2:48 pm
Traffic inside your LAN is a Layer 2 traffic that will not go through The Firewall !!! Firewall filters Layer 3 Traffic...
So either you enable the bridge filter so that the traffic is forced to pass through the prerouting, forward and postrouting chains, as @xvo suggested or you use a whole different subnet for your server as @sindy suggested...
Personally i would go with @sindy's suggestion...
sindy
Mon Jun 29, 2020 3:02 pm
The "internal dst-nat" rule you've posted in one of the previous posts was OK for this purpose, so it's most likely just a typo in it, or you have done something wrong when adding the dedicated subnet for the new server. So if you don't find the typo, follow the suggestion in my automatic signature below.
mutluit
Forum Veteran
Forum Veteran
Mon Jun 29, 2020 5:12 pm
Port forwarding from wanIP:port to lanIP:port works.
What the OP wants to know is how to port forward from internal lanIP1:port to internal lanIP2:port .
Me too interested in the solution. :-)
sindy
Mon Jun 29, 2020 5:25 pm
It's not exactly like this - what the OP really wants is to migrate services from old server to new server one by one without touching the clients' configuration, and whilst it should be possible to port forward even L2 traffic, the amount of hair lost while debugging it would not be proportional to the outcome. And as the real goal can be achieved using simpler means, it is unlikely that the question above will be answered here :)
anav
Mon Jun 29, 2020 6:19 pm
Okay I will bite as its not clear to me.
By the way first of, I would introduce the server at a quiet time and do the switch period.
I dont see why one needs to do it slowly like over a few days. Set it up in the LAB and then simply deploy it, you know, plug in for power, take out ethernet cable from old server and plug cable into new server, unplug power to old server, remove old server. :-)
The way I read it is that the OP has the following scenario.
Bunch of users on SUBNET A, and a server on SUBNET A.
THe OP wants to move everyone over to a NEW SERVER ON SUBNET A over time so its transparent to users.
I do not understand your solution as it makes too many assumptions.
What if lan users use the LANIP and port number of the server.................
Are you suggesting that users be instructed to use a DYNDNS name (IE GO through the WANIP for server access). Invoking Hairpin NAT or loopback LOL.
CHANGE METHOD OF ACCESSING SERVER (using hairpin)
If So, the dst nat rules would be on day one Prior to Server Changes
dstport=XXX (current) to IP-- currentserverip to port= XXXX original
CHANGE DESTINATION NAT RULE
Day Two Admin puts the new server in place and changes the rule.
dstport=XXX (current) to-ip --newserver to port=YYYY new IP/new port
RETURN DST NAT RULE
Once the migration is satisfactorily completed and op changes new server IP and port back to original numbers.
dstport=xxxx current to ip-currentnew to port=xxxx original
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
mutluit
Forum Veteran
Forum Veteran
Mon Jun 29, 2020 6:21 pm
@sindy, I'm looking for a solution for port-forwarding from lanIP1:port to lanIP2:port within the same LAN. Is there a solution available for this (simpler) problem?
Ie. connections to 192.168.88.12:8512/tcp shall be (on the router) redirected to 192.168.88.11:8511
xvo
Forum Veteran
Forum Veteran
Mon Jun 29, 2020 6:59 pm
It's not a simpler problem.
And there is no good solution for this.
Mostly because the concept itself is bad: while the idea of putting devices on the same L2 network pursues the goal to offload handling of traffic between hosts on this network to cheaper (and faster) devices - switches, what you are trying to achieve needs quite the opposite - that all the traffic in your LAN passes through your router (an not even it's internal switch, but its CPU).
So not only will you need to build your whole network with that in mind, but you are at the same time making router's CPU the whole network's bottleneck.
anav
Mon Jun 29, 2020 7:05 pm
Hi XVO you nailed the issue on the head............ the concept is bad. This points out that OP is concerned with fulfilling a config solution without revealing the true requirement. Cart before the horse and the most expensive way to implement anything.
Suggest mutluit that you describe the user case(s), in terms of what users require to do their jobs etc, without any discussion of configuration or hardware involved.
What is unique, different from other requirements.
What are the limitations? (here you may state what equipment is involved, what is available to work with on the canvass so to speak).
mutluit
Forum Veteran
Forum Veteran
Mon Jun 29, 2020 8:23 pm
ATTN everybody!
I now have found a solution. Will post it shortly. But it works only if no bridge is configured in RouterOS :-( Could be a ROS bug...
Zacharias
Mon Jun 29, 2020 8:28 pm
ATTN everybody!
Then how exactly did you create a Layer 2 Broadcast Domain if you configured no Bridge ?
mutluit
Forum Veteran
Forum Veteran
Mon Jun 29, 2020 8:38 pm
Ok, here's the said solution:
Solution for port forwarding for both WAN-to-LAN as well LAN-to-LAN (incl. inside same LAN):
On my router (hAP ac^2 with RouterOS 7.0beta8) with no NAT (ie. as 2nd router) now the following solution works:
IP of WAN interface (ether1): 192.168.254.253/24
IP of ether2 (ie. the gateway IP for LAN): 192.168.127.254/17
IP of host attached to router ether2: 192.168.20.1/17 (can add more hosts into that LAN by attaching a dumb switch to ether2).
WAN port 8458 is forwarded to LAN IP 192.168.20.1:8459. There an iperf server is running for testing.
All connections to 192.168.254.253:8458 (ie. the WAN interface) are correctly redirected, even connections from inside the LAN !
So, the culprit is the bridge as with bridge this solution doesn't function.
I first tried the following step-by-step guide (with some good explanations) that says it works,
but I couldn't get it working here (as said WAN-to-LAN works, but not from inside the LAN):
https://serverfault.com/questions/97034 ... tik-router
Then I removed the bridge, and voila it works! And performance is ok (Gigabit speed, s.b.).
[admin@AP1] /ip/firewall/nat> export
add action=dst-nat chain=dstnat dst-address=192.168.254.253 dst-port=8458 in-interface=all-ethernet log=yes protocol=tcp to-addresses=192.168.20.1 to-ports=8459
add action=src-nat chain=srcnat dst-address=192.168.20.1 dst-port=8459 log=yes protocol=tcp src-address=192.168.0.0/17 to-addresses=192.168.127.254
[admin@AP1] /ip/firewall/filter> export
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
host:
# ifconfig
eth0 Link encap:Ethernet HWaddr XXXXXXXXX
inet addr:192.168.20.1 Bcast:192.168.127.255 Mask:255.255.128.0
# iperf server running on host:
$ iperf -e -s -p 8459
# iperf client from anywhere:
$ iperf -e -c 192.168.254.253 -p 8458 -t 5
Client connecting to 192.168.254.253, TCP port 8458 with pid 18513
Write buffer size: 128 KByte
TCP window size: 468 KByte (default)
[ 3] local 192.168.20.1 port 12146 connected with 192.168.254.253 port 8458 (ct=0.93 ms)
[ ID] Interval Transfer Bandwidth Write/Err Rtry Cwnd/RTT NetPwr
[ 3] 0.00-5.01 sec 552 MBytes 925 Mbits/sec 4417/0 0 -1K/816 us 141735.83
Btw, without the above filter rules the performance is only about half:
[ 3] 0.00-5.02 sec 314 MBytes 525 Mbits/sec 2511/0 0 -1K/695 us 94425.95
So, the "fasttrack" and the "established,related" rules should be present in the firewall to get wire-speed performance.
P.S.: of course the log=yes in the firewall rules should be removed after testing.
mutluit
Forum Veteran
Forum Veteran
Mon Jun 29, 2020 9:02 pm
ATTN everybody!
Just assign an IP to the router port, for example ether2: 192.168.50.254/24. That's then the gateway IP for LAN 192.168.50.0/24 at ether2.
Of course w/o a bridge one loses the switch-functionality on the router, meaning one has to attach a dumb switch to ether2 to be able to attach more than one host into that LAN. Same with the other router ports...
xvo
Forum Veteran
Forum Veteran
Mon Jun 29, 2020 9:22 pm
I don't exactly understand what is that thing, that is working, for you have only one host on your LAN in your example.
And even if there is a thing, and it is actually working, how is it supposed to continue to work after you put two hosts on one dumb switch?!
These two hosts will connect to each other via the switch, not via your router, no matter the configured rules.
mutluit
Forum Veteran
Forum Veteran
Mon Jun 29, 2020 9:34 pm
It should work b/c one uses the WANGATEWAYIP:port as the WANGATEWAYIP is on the router (in my case ether1).
As said WANGATEWAYIP in my case means the uplink-interface on this 2nd router --> going to the 1st router.
I'll now test it also with a dumb switch, and also from the other router ports (ie. from other LANs).
CZFan
Mon Jun 29, 2020 9:49 pm
@xvo, "that thing..." gave me a good laugh.
Might be a solution, but that will mean all clients will have to be reconfigured to point to WAN address and not internal address of server
MTCNA, MTCTCE, MTCRE & MTCINE
mutluit
Forum Veteran
Forum Veteran
Mon Jun 29, 2020 9:52 pm
Hmm. yes, you are right. But I think that problem is solvable too. I'll check.
Update:
I now tested using a dumb switch, as well using from another LAN at ether3: both works using the GATEWAYIP:port.
I'll now see whether it as well functions if one uses the (non-existent) hostIP:port instead of the GATEWAYIP:port.
Diresta
First of all, thanks for all the replies and the effort all of you put in.
I've been going through all of it and trying different options but I don't even really understand half the solutions stated above. I think my skill level just is not up to par for this one as I have never had any Mikrotik or networking training and all I know has been self taught. All in all I don't think I'm going to be able to get it up and working the way I wanted it to without getting myself educated better about routing in general.
Sorry y'all. I hope someone else can use this port to solve their problem but I can't seem to see the forest through the trees no more :( Maybe it's best I'll let it rest for a few days before giving it another try. In the meanwhile, if someone know's a good place for a beginner to learn more about mikrotik firewall/routing it'd be much appreciated.
CZFan
Mon Jun 29, 2020 10:03 pm
Like your energy / enthusiasm / attitude towards a problem!!
anav
Mon Jun 29, 2020 10:26 pm
Unfortunately you have a scared off the original poster by subverting (for lower class folks the term is 'hijacking) the thread with what appears to be a nonsense idea. Valid or not, my apologies to the original poster and I very much would like to solve your issue as its interesting and potentially useful for others.
As I said I dont know why you dont want to make a swap change at a quiet time?
To progress your issue how do lan users access the LAN server now? Vian WANIP or LANIP?
sindy
Mon Jun 29, 2020 10:37 pm
You can always post your current configuration (minus sensitive information, see my automatic signature below) and get a few lines in return which will modify it to fulfil the goal.
Sob
Tue Jun 30, 2020 12:06 am
Unfortunately you have a scared off the original poster by hijacking the thread ...
Says the hijacking expert. ;)
But on topic, it doesn't seem too difficult. The main problem is that normally traffic between devices in same subnet doesn't pass through router, so it can't do anything with it. But if you connect old server in a way that traffic has to pass through router, i.e. just switch two ports together, connect old server (with same address and everything) to it and rest of LAN to other one, then you can use bridge NAT to redirect connections for old server's address and selected port to router and there process them using IP firewall (dstnat to new server + hairpin NAT). I didn't test it, but it should work. It should be also possible with bridge's use-ip-firewall, but I don't like that, because it affects everything.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
sindy
Tue Jun 30, 2020 12:19 am
I'd even go further, s/affects/breaks/ - especially when it comes to NAT. But I've just realized that my suggestion is also only addressing one part of the issue - in fact, both the old and new server have to be moved to another subnet (which may be the same for both, but it has to be different from the clients' subnet), and the original IP address of the old server has to be assigned to the Mikrotik itself in order that my suggestion would work.
xvo
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 12:20 am
Ok, so basically you just "invented" hairpin NAT on your own, right?! :lol:
And that is what you actually need?
But that is not what you've asked for initially.
And has very little to do with the original post...
Sob
Tue Jun 30, 2020 12:40 am
I tried simple test with RB working as (not so much) transparent bridge. First put two ports together:
add name=bridge1
Add some address (can be also static, doesn't matter):
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=bridge1
Disconnect old server from network and connect it back through RB. At this point it's like a switch, fully transparent. Then add NAT rules (192.168.80.17 is old server, 192.168.80.3 is new server):
add action=dst-nat chain=dstnat dst-address=192.168.80.17 dst-port=80 protocol=tcp to-addresses=192.168.80.3
add action=masquerade chain=srcnat dst-address=192.168.80.0/24 src-address=192.168.80.0/24
And as expected, nothing happens. But add one bridge NAT rule:
/interface bridge nat
add action=redirect chain=dstnat dst-address=192.168.80.17/32 dst-port=80 in-bridge=bridge1 ip-protocol=tcp mac-protocol=ip
And suddenly all clients connecting to old web server get content from new one. Integrating it with existing config could be a little more work, to make sure that it doesn't conflict with anything else (so maybe the simplest choice is to not do it, and instead just use spare RB like I did, if you have one).
mutluit
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 3:29 am
@Sob, your solution is very interesting, but unfortunately in current beta8 it hangs in a loop so that the router reboots endlessly :-(
I suspect it is the masquerade rule with src-addr and dst-addr equal.
But if it works well with stable/long-term version than it could indeed be the solution for the OP.
anav
Tue Jun 30, 2020 3:37 am
Haha too funny fellas, you should know that being MTUNA certified I am authorized to point the thread in the proper direction, hijacking is such an uncultured term, where did you go to school?
My problem is I cannot figure out which thread SOB is answering LOL, the original thread by the OP, or the usurper thread??
mutluit
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 3:40 am
Ok, ok, got it. I now realize it as well.
I apologize for my wrong solution and the confusion it caused. Sorry.
Sob
Tue Jun 30, 2020 4:46 am
@mutluit: I generally leave MikroTik's betas to more adventurous types, because I believe that their use of terms like beta, rc or stable is slightly shifted from the usual meaning, and not for the better. I have few CHRs to play with latest stuff, but that's it. Otherwise I'm glad for every brave user who is willing to sacrifice real hardware to help squash bugs. If current beta v7 doesn't like this config, I guess it's probably the bridge NAT rule. Masquerade is just for hairpin NAT and IP firewall is well tested, everyone uses that. Bridge NAT on the other hand, I don't thing that it's used much.
Btw, it would be also possible to do similar thing with proxy ARP instead of bridge.
@anav: How can't you tell? The thing I posted is complete working config, just few rules and with comments. If you continue like this, I'll have to revoke your uncertification.
Diresta
Tue Jun 30, 2020 10:08 am
Allright, I removed everything I setup to try this and started with a blank slate. I setup a bridge on (normally unused) ports 8 & 9 on my RB3011, setup a DHCP server and connected my new server to port 9. The router assigned it an IP address but I set it to static --> 192.168.12.125.
Here are all my Firewall rules, The address-list:
/ip firewall address-list
add address=192.168.10.0/24 list=LAN
add address=192.168.12.0/24 list=LAN_Server
add address=PUBLIC_IP list=Home
add address=8.8.8.8 list="Google DNS"
add address=8.8.4.4 list="Google DNS"
add address=208.67.222.222 list="Google DNS"
add address=209.244.0.3 list="Google DNS"
add address=0.0.0.0/8 comment=RFC6890 list=NotPublic
add address=10.0.0.0/8 comment=RFC6890 list=NotPublic
add address=100.64.0.0/10 comment=RFC6890 list=NotPublic
add address=127.0.0.0/8 comment=RFC6890 list=NotPublic
add address=169.254.0.0/16 comment=RFC6890 list=NotPublic
add address=172.16.0.0/12 comment=RFC6890 list=NotPublic
add address=192.0.0.0/24 comment=RFC6890 list=NotPublic
add address=192.0.2.0/24 comment=RFC6890 list=NotPublic
add address=192.168.0.0/16 comment=RFC6890 list=NotPublic
add address=192.88.99.0/24 comment=RFC3068 list=NotPublic
add address=198.18.0.0/15 comment=RFC6890 list=NotPublic
add address=198.51.100.0/24 comment=RFC6890 list=NotPublic
add address=203.0.113.0/24 comment=RFC6890 list=NotPublic
add address=224.0.0.0/4 comment=RFC4601 list=NotPublic
add address=240.0.0.0/4 comment=RFC6890 list=NotPublic
add address=192.168.10.0/24 comment=RFC6890 list=NotPublic
add address=192.168.11.0/24 comment=RFC6890 list=NotPublic
The Filters:
    "Accept established,related & untracked connections to the router" \
    "Accept all connections from local network - LAN" in-interface-list=LAN
    "Accept all connections from local network - LAN_SERVER" in-interface-list=\
    LAN_SERVER
add action=accept chain=input comment="Accept established and related packets" \
    "Accept established and related packets" connection-state=\
    established,related
add action=drop chain=input comment="Drop invalid connections to the router" \
    connection-state=invalid
add action=drop chain=input comment="Drop invalid packets" connection-state=\
    invalid
    "Drop all packets which are not destined to routers IP address" \
    dst-address-type=!local
    "Drop all packets which does not have unicast source IP address" \
    src-address-type=!unicast
add action=drop chain=input comment="Drop all packets from public internet which\
    \_should not exist in public network" in-interface-list=WAN \
    src-address-list=NotPublic
add action=drop chain=forward comment="Drop invalid packets" connection-state=\
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface-list=WAN log-prefix=dz
add action=drop chain=forward comment="Drop all packets from public internet whi\
    ch should not exist in public network" in-interface-list=WAN \
    "Block internet but allow local network for PC" disabled=yes out-interface=\
    ether1 src-address=192.168.10.253
The nat rules:
add action=masquerade chain=srcnat comment="WAN NAT - Grants local LAN devices a\
    ccess to the internet by masquering as the WAN IP address" ipsec-policy=\
    out,none out-interface-list=WAN src-address-list=LAN
    add action=masquerade chain=srcnat comment="WAN NAT - Grants local LAN_SERVER devices a\
    out,none out-interface-list=WAN src-address-list=LAN_Server
add action=masquerade chain=srcnat comment="HAIRPIN NAT - Gives local devices ac\
    cess to other local devices using the WAN IP address" dst-address-list=LAN \
    log=yes log-prefix=HP NAT out-interface=bridge src-address-list=LAN
add action=dst-nat chain=dstnat comment="This works from WAN to LAN" \
    dst-address-list=Home dst-port=125 log=yes log-prefix=WAN2LAN protocol=tcp \
    to-addresses=192.168.12.125 to-ports=9000
add action=dst-nat chain=dstnat comment=\
    "DMZ to server - Always place below other rules" dst-address-list=Home \
    to-addresses=192.168.10.125
So far I'm back where I was when I posted this thread. If i go to WANIP:125 the traffic gets forwarded tot 192.168.12.125 (newServer). But if I add a rule redirecting traffic for 192.168.10.125 to 192.168.12.125 nothing happens. I tried Sob's approach and setup bridge nat etc but nothing seemed to happen so I removed rules for that. Any pointers on where to go with above config?
mutluit
Forum Veteran
Forum Veteran
Re: LAN to LAN forwarding  [SOLVED]
Tue Jun 30, 2020 12:22 pm
@Diresta, which RouterOS version does your device have?
And can you post the output of this:
/interface export hide-sensitive
And: together with the new servers will also the old servers be online at the same time during the transition phase?
If yes, and if your servers do have iptables, then you could use the following accepted alternative solution on each of the the old servers:
https://serverfault.com/questions/58648 ... me-network
The problem with RouterOS seems to be that port-forwarding using DNAT/SNAT within the same LAN seems not possible.
In my experiments here so far port-forwarding in ROS works only for clients from other LANs as well from the WAN side, but not from inside the same LAN.
But of the working part this fact IMO is very interesting: the old server does not need to exist nor be online :-)
Diresta
Tue Jun 30, 2020 6:18 pm
I'm running routerOS 6.44. I try to always run the newest stable release for security reasons.
Here it is:
add admin-mac=00:25:9C:42:C7:E8 auto-mac=no comment=defconf name=bridge
add comment="Bridge for temp server" name=bridge-server
add fast-forward=no name=brige-gast
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
set [ find default-name=ether8 ] speed=100Mbps
set [ find default-name=ether9 ] speed=100Mbps
set [ find default-name=ether10 ] speed=100Mbps
set [ find default-name=sfp1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface vlan
add interface=ether1 name=vlan-gast use-service-tag=yes vlan-id=999
add interface=ether1 name=vlan10 vlan-id=10
add interface=ether1 name=vlan20 vlan-id=20
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=LAN_SERVER
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge-server interface=ether8
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge-server interface=ether9
/interface detect-internet
set detect-interface-list=all
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface=bridge-server list=LAN_SERVER
/interface ovpn-server server
set auth=sha1 certificate=SOMECERT cipher=aes256 default-profile=\
    open_vpn enabled=yes require-client-certificate=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set certificate=SOMECERT_default-profile=default-encryption enabled=yes
The old server will remain online for the whole duration of the migration to the new server so the idea of using iptables might be the easiest solution indeed. I can't believe I didn't think of that myself :-| I'll go give it a try later today and will report back..
xvo
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 6:42 pm
It's not a RouterOS problem.
Actually it's not a problem at all - it's just basic networking concept.
mutluit
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 6:54 pm
But you have to admit that it's not satisfactorily if it works as wished/intended from other LANs and WAN, but not from inside the same LAN. One has to question why ROS can't handle that, don't you agree? I would classify that as a bug, or at least as a shortcoming or as a missing capability...
xvo
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 7:22 pm
And you couldn't be more wrong in you classification attempt.
Two hosts on one LAN (broadcast domain) don't communicate via router, they communicate "directly", and they will never do it the other way, unless forced to.
So this task has to be solved not on the router (L3), but on the switch(es) (L2).
And earlier in the thread @Sob presenter a working solution, how to solve this on mikrotik router's bridge (which is a software switch), but this solution is not universal, and works only if router's bridge is the only switch along the way. To make it work in more complex network, something like that might need to be done on other switches. And in some situation, when unmanaged switches are used, this task can't bу solved at all without physically reconfiguring the network.
anav
Why would it be a bug? The MT RoS allows one to program (via config) traffic flow required by the admin.
This is not a plugNplay device. I have used zyxel routers and they had the same process except they called it Loopback vice hairpin nat and one checked a box.
In the MT you dont get the luxury of the checkbox, instead you have to understand what is actually going on in traffic flow and then assign appropriate rules.
Have read through this, as the only bug is lack of education. :-)
https://help.mikrotik.com/docs/pages/vi ... Id=3211299
anav
Tue Jun 30, 2020 7:25 pm
@Diresta
How do users access the server now, by LANIP or by WANIP (dyndns type name)?
If by WANIP.
Then all they are doing is accessing server by dyndnsname:port#
You can migrate all users over to the new server by simply changing the current dstnat rule.
chain=dstnat action=dst-nat dst-port=currentport protocol=tcp dst-address=fixedstaticWANIP to address=currentserver
TO
chain=dstnat action=dst-nat dst-port=currentport protocol=tcp dst-address=fixedstaticWANIP to address=IPofnewServer to-port=newserverport
Done, anybody attempting to reach the current server via the usual method gets redirected to the new Server.
You then have some choices to make.
a. Leave as is,
b. Decide to Change IP of new server back to IP of old server (and thus need to modify dstnat rule so that too-address is back to the original IP address)
c. Decide to Change port of new server back to port of old server (and thus need simply to remove TO-ports )
(Of course to do hairpin NAT you need to add the appropriate srcnat rule)
(add chain=srcnat src-address=192.168.10.0/24 dst-address=192.168.10.0/24 action=masquerade - use appropriate subnet for your scenario)
mutluit
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 9:33 pm
@xvo, FYI: here's a solution using iptables on a linux router with a bridge. It reads "Port forwarding between bridged interfaces":
https://askubuntu.com/questions/720207/ ... interfaces
It's a similar problem-case: moving services from one host to another host in same LAN / same bridge, but keeping the clients' configs untouched so that they continue connecting to the old host, which by this iptables solution on that linux router silently is redirected to the new host. All hosts are in the same broadcast domain (same LAN) under same one bridge.
Yes, bridge is L2, but the above solution is using pure iptables, ie. L3+.
Since RouterOS is based on Linux and iptables, then the same solution should be reproducible in ROS I was thinking/hoping.
xvo
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 9:51 pm
What's your point?
You already have a working ROS solution for this case earlier in the thread.
Does it work for you or not?
If not, then no solution will work without reconfiguring the rest of the network, no matter what device with what os you have in place of mikrotik.
mutluit
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 10:56 pm
What's your point?
Because you said "So this task has to be solved not on the router (L3), but on the switch(es) (L2)."
In that solution it's solved on the router without using any L2, just FYI :-)
No, it doesn't work here, though I haven't tried other ROS versions.
Such a task should be doable centrally on a router or switch with just a few firewall rules, nothing more. You OTOH seem to say one needs to reconfigure the net.
Never mind, I've seen enough and experienced enough.
xvo
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 11:10 pm
You clearly still don't understand the nature of the problem in general.
And thus don't see what can work in a particular case and what can't.
mutluit
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 11:13 pm
I just know this: in the field out there this important use-case has to function with no excuses.
xvo
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 11:25 pm
And FYI, for iptables to be able to filter bridged traffic you have to enable "net.bridge.bridge-nf-call-iptables" which is the same as "use ip firewall" in bridge settings in ROS.
In other words: "use L3 firewall rules for L2".
xvo
Forum Veteran
Forum Veteran
Tue Jun 30, 2020 11:28 pm
Yeah, right. Laws of physics included? :lol:
Jotne
Wed Jul 01, 2020 12:00 am
@Diresta
Changing server may be an normal operation to do with new IP. This is why we have DNS. Just redirect DNS to new server.
But why do you need to change port? What services is this that you have on port 150 or port 10000? Not standard ports?
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
Sob
Wed Jul 01, 2020 1:51 am
@Diresta: Don't create completely new bridge, that was just simple example on a router with no other config. If the *old* server (192.168.10.125) is connected to LAN (192.168.10.0/24 I guess) which is on bridge called "bridge", then just make sure that the *old* server is physically directly connected to one of router's ports which is part of this bridge. The point is that it must not be further in LAN behind other switch(es), so any traffic from other 192.168.10.x devices to 192.168.10.125 has to physically pass through this router. Then all the magic lies in dstnat rule in "/interface bridge nat", which sends selected packets to IP firewall and you can use dstnat to send them to new server (otherwise they would just pass through router and IP firewall wouldn't see them).
Edit: Btw, @mutluit, trust the bearded man, he was right from the start, from first response in this thread (I missed that initially).
anav
Wed Jul 01, 2020 4:49 am
But but but , how can you trust someone who hasnt figured out how to use a razor or electric shaver??
Seriously though I will have to award an MTUNA Sarcasm Certificate to xvo, he has learned well and is dishing it out in great fashion.
Diresta
Wed Jul 01, 2020 9:05 am
First of all I'd like to thank all of you for the time and effort you put into helping me. It seems my problem took the interest of several of you and sparked several ideas (and some discussion ;-)). Probably half of what's been posted is way above my head but the good news is:
I managed managed to solve my problem using IP tables as stated in mutluit's post above which I marked as answer. I read several posts on different forums and eventually set up a few rules on my ubuntu (old) server. It took me 5 hours to set it up (managed to roast my entire firewall and had to start from scratch but at least I learned a lot in the proces hehe) and now I am able to forward traffic that is sent to old server to new server.
Since there were a several reply's with question since my last post I'm gonna try and answer them all here at once.
Users access the server 95% by LAN IP. There is a DMZ on my MT router that sends all traffic that is not specifically routed in the router to the server however a firewall with a deny all is set up on the server. A few ports (like http/https) are opened up to WAN but I prefer using a VPN over WAN access when it comes to more sensitive data/services.
I see where you're going but won't using DNS reroute all traffic that is sent to ip 192.168.10.125 to 192.168.12.125 instead of one port? I need port based forwards so I can migrate one service at a time to my new server instead of having to migrate them all at once. The reason for different (and non standard) ports is that I have several instances of services already running in Docker on new server for test purposes. Once I figure out the best Docker config that host will be set to the final port and the forward will be changed to only forward to different ip but same port. I hope this makes sense.
I think I see what you're getting at. I will most likely give this a try later when I have some more time to play around. Since I got it working using IPtables and I really need to get started migrating services I'm gonna have to postpone on it though. Still very interested in this so thanks for the explanation.
For anyone with this same problem also running ufw & iptables on their old server I thought the least I could do is tell them the solution to my problem:
First I changed the UFW default forward policy. To do open "/etc/default/ufw" and change the default forward policy to ACCEPT
DEFAULT_FORWARD_POLICY="ACCEPT"
Than append the following to /etc/ufw/before.rules:
*nat
:PREROUTING ACCEPT [0:0]
# forward 192.168.10.125 port 125 to 192.168.12.125:10000
-A PREROUTING -p tcp --dport 125-j DNAT --to-destination 192.168.12.125:10000
-A POSTROUTING -p tcp --dport 10000 -j MASQUERADE
# don't delete the 'COMMIT' line or these rules won't be processed
COMMIT
Little sidenote: Place this at the end and don't worry about there already being a commit above. Also don't forget to reload ufw (sudo ufw reload).
All in all I'm really glad I've got it working and I hope that in the long run more people will be helped by this thread. Thanks again!
xvo
Forum Veteran
Forum Veteran
Wed Jul 01, 2020 10:24 am
This joke seems to need a shaver itself. :lol:
Jotne
Wed Jul 01, 2020 12:14 pm
Send out information that there will be a service windows from 01:00 to 02:00 first Tuesday next month, move all service in one go.
MikroTik->Splunk
Diresta
Wed Jul 01, 2020 12:27 pm
Haha, that might be an option but it all depends on how you want to move your systems. All in all I'm happy with the found solution and glad I can continue with the migration.
mutluit
Forum Veteran
Forum Veteran
Wed Jul 01, 2020 8:08 pm
Glad to see that @Diresta's problem of transparent port-forwarding within the same LAN has been solved by using iptables' port-forwarding function on the old server(s).
It would have functioned also centrally on a Linux router with iptables as shown in posting #41 viewtopic.php?f=2&t=162996#p803433
So, here's what I do get & learn from this discussion: use your own open-source switch-router with Linux :-) Then you can do and realize everything with it.
IMO the only advantage of such nice devices like the MikroTik CRS3xx switch-routers is IMO their special ASIC switch-chip with the stateless firewall (ACL).
But the ACL as implemented in RouterOS is very limited, one even can't check the TCP flags in ACL. So then this advantage is relative/minuscule.
I've currently these MT devices in operation here: CRS326, CRS125, CRS305, hAP ac^2.
But to be fully flexible in the future I'll build my own switch-router on a dedicated PC by adding some multi-port NICs (1G and 10G, and maybe even 40G) to it.
Of course that will eat at least twice as much power than the 24W of a CRS326 switch-router, but with all the other advantages one gets it's then worth it well, IMO.
I would recommend MikroTik to open ROS, so that the admin can access/extend/modify the underlying Linux.
Otherwise for advanced use-cases like seen in this thread (and IMO especially in corporate environments) people will use their own DIY Linux router/switch with root access.
Sob
Thu Jul 02, 2020 3:56 am
It depends. Normally iptables don't see bridged packets, exactly as IP firewall rules don't see them in RouterOS. You need extra option for that. Quick search suggests that it may be enabled by default in some systems, so that would explain why it can work. But it's something you generally don't want to have. RouterOS has it too (/interface bridge settings set use-ip-firewall=yes), but as I already mentioned, it does weird things. But have your fun with it if you want. :)
xvo
Forum Veteran
Forum Veteran
Thu Jul 02, 2020 11:16 am
Forget it, @Sob.
I already tried to explain him exactly that, but he prefers to stick to his false assumptions, that particular network layout have nothing to do with the ability (or inability) to solve the problem, and that the problem lies in ROS.
As surprising as it may sound, but @anav was right in on of his early posts in this thread saying that the only bug here is the lack of education.
anav
Thu Jul 02, 2020 4:19 pm
Did I say education, I meant cult following.
Master Sob and MKX are often referred to as Cult leaders in MTUNA literature. ;-P
Sob
Thu Jul 02, 2020 8:09 pm
I can't give up so easily. If I want my own cult, I need to build up membership. I can't have just @anav, because look at him... he's eager and everything, but he already leaks my plans to public (and I didn't even share them with him), there's no way he would become submissive enough and not question the leader all the time, etc. :D
But more on topic, anyone who has doubts about something can test what works and what doesn't. Don't believe what others write, do it yourself. All required tools are easily available.
xvo
Forum Veteran
Forum Veteran
Thu Jul 02, 2020 8:22 pm
That made my evening :lol:
anav
Thu Jul 02, 2020 8:27 pm
xvo, you are the perfect sycophant ;-)
mkx
Mon Jul 06, 2020 11:06 pm
C'mon @anav, why are you dragging me into this mud? I've declared @mutluit a foe expressly to avoid reading his misconceptions and now you're forcing me in? If I was to lead a cult, I want to choose my own mud pit.
BR,
Metod
anav
Mon Jul 06, 2020 11:21 pm
Too true MKX, on thread too many although I did mention your name in another thread, but cannot remember where LOL.
Users browsing this forum: MAcSpecialist and 184 guests
