chihimchong
How to connect the VLAN and non VLAN
Tue Jun 30, 2020 4:31 am
I have a Centos and create two VLAN interfaces VLAN 82, VLAN 83.
I have also create the two VLAN interfaces and map to bridge in mikrotik CRS125-24G-1S
The CentOS can ping to mikrotik.
And the next step I will connect a some PC without VLAN id to connect to the mikrotik.
Is that work fine the CentOS and communicate to the PC
PS. Sorry about that, I am the rookie in RouterOS. Please give me some suggestion
anav
Re: How to connect the VLAN and non VLAN
Wed Jul 01, 2020 4:46 pm
Please draw a diagram of your setup as it is not clear.
Also, is the MT acting as solely a switch, or is it giving out DHCP addresses?
Finally please describe the use cases more clearly, connecting non vlans and vlans means nothing to me.
Put it in words, what you want users to be able to do functionally speaking.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
erlinden
Wed Jul 01, 2020 4:55 pm
Search for trunk port and access port.
Besides, this is 'must read' material (it helped me lot understanding):
viewtopic.php?t=143620
First the problem, then the solution
Users browsing this forum: abergr, gkk, pe1chl, rpress, sindy, zakynthoswifi, Znevna and 113 guests
