speaksandeep
hAP router mode
Tue Jun 30, 2020 6:03 pm
I want to use hAP in both Switch as well as Router mode.
All Ethernet ports will be bridges as WAN and only Wireless Interface need to work as LAN mode (Router/NAT mode)
Is it possible in hAP
Regards,
Sandeep Baral
xvo
Forum Veteran
Forum Veteran
Re: hAP router mode
Tue Jun 30, 2020 6:11 pm
Yes, it is.
speaksandeep
Re: hAP router mode
Tue Jun 30, 2020 8:29 pm
Yes, it is.
Now I can purchase
Regards,
Sandeep Baral
anav
Re: hAP router mode
Tue Jun 30, 2020 9:17 pm
Just in case you have doubts trusting a man who has not discovered the razor or electric shaver..................
Pretty much all wifi devices in the MT lineup using RouterOS can do this.
It sounds like you have a definite WAN INPUT in mind and a definite WIFI capability in mind.
A. Can you expand on the number of ISPs you will be attaching, throughput etc, and expectations for that traffic.
B. Assuming all traffic will be wifi, is this traffic going directly to smart devices, smartphones, etc???? How many devices??
Just want to ensure expectations and requirements lineup!
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Zacharias
Re: hAP router mode
Wed Jul 01, 2020 11:10 am
@anav made some accurate considerations...
wow, anav you sound like a pro... :D
anav
Re: hAP router mode
Wed Jul 01, 2020 3:05 pm
Its all about impressions!! I learned from the best but I still only know 1%.
mkx
Re: hAP router mode
Tue Jul 07, 2020 8:40 am
You expressed the right impression at the right time. And that is what a real pro does :wink:
BR,
Metod
anav
Re: hAP router mode
Tue Jul 07, 2020 4:02 pm
Which impression(s)?
a. that i knew what I was talking about and exuded eons of experience and on the cusp of spouting forth great knowledge?
b. that i cared deeply about the Ops predicament and was bursting at the seams to help my fellow man? or
c. that I gently pointed the Op into expanding his views on the possibilities of what must be considered when setting up a new router, with confidence but not bravado?
mkx
Re: hAP router mode
Tue Jul 07, 2020 11:51 pm
b. is what usually some activists (e.g. cats-lovers) do. And c. is something a priest / cult leader would do.
So definitely it's a. making you seem like a real IT pro :wink:
BR,
Metod
Users browsing this forum: No registered users and 34 guests
