mafiosa
OSPF routes marked invalid
Fri Jul 03, 2020 8:30 pm
I have established ospf neighborship with other mikrotik routers yet the ospf routes learnt are marked as invalid on the router running rosv7 beta 8
oreggin
Re: OSPF routes marked invalid
Wed Jul 22, 2020 1:30 pm
Hi!
I have a ROS v7.1ß1 test setup with CHR on qemus and I have the same issue with OSPFv2. All of my ipv4 ospf routes duplicated and inactive:
[admin@rtr1.CPE] > routing/ospf/interface-state/print
Flags: D - dynamic; V - virtual-interface
 0 D  address=fe80::d012:2bff:fe83:2e99%Loopback0 area=backbone6 instance-id=0 state="DR" dr=10.0.10.11 bdr=0.0.0.0
 1 D  address=10.0.10.11%Loopback0 area=backbone4 instance-id=0 state="DR" dr=10.0.10.11 bdr=0.0.0.0
 2 D  address=fe80::a00:27ff:fe00:5102%ether2 area=backbone6 instance-id=0 state="Point-to-Point"
 3 D  address=10.0.1.2%ether2 area=backbone4 instance-id=0 state="Point-to-Point"
[admin@rtr1.CPE] > routing/ospf/neighbor-state/print
Flags: X - disabled, I - inactive, D - dynamic
 0 D address=fe80::a00:27ff:fe00:4101%ether2 router-id=10.0.10.1 state="Full"
 1 D address=10.0.1.1 router-id=10.0.10.1 state="Full"
[admin@rtr1.CPE] > ip route/print detail where ospf
Flags: D - dynamic; X - disabled, I - inactive, A - active; C - connect, S - static, r - rip, b - bgp, o - ospf, d - dhcp, v - vpn, m - modem; + - ecmp
   DIo  dst-address=10.0.0.0/30 routing-table=main gateway=ether2 type=unicast distance=110 scope=20 target-scope=10
   DIo  dst-address=10.0.0.0/30 routing-table=main gateway="" type=unicast distance=110 scope=20 target-scope=10
   DIo  dst-address=10.0.0.4/30 routing-table=main gateway=ether2 type=unicast distance=110 scope=20 target-scope=10
   DIo  dst-address=10.0.0.4/30 routing-table=main gateway="" type=unicast distance=110 scope=20 target-scope=10
   DIo  dst-address=10.0.0.8/30 routing-table=main gateway=ether2 type=unicast distance=110 scope=20 target-scope=10
   DIo  dst-address=10.0.0.8/30 routing-table=main gateway="" type=unicast distance=110 scope=20 target-scope=10
   DIo  dst-address=10.0.0.12/30 routing-table=main gateway=ether2 type=unicast distance=110 scope=20 target-scope=10
   DIo  dst-address=10.0.0.12/30 routing-table=main gateway="" type=unicast distance=110 scope=20 target-scope=10
etc...
Intersting is OSPFv3 works fine:
[admin@rtr1.CPE] > ipv6/route/print detail where ospf
   DAo  dst-address=b00b::10:0:10:1 routing-table=main gateway=fe80::a00:27ff:fe00:4101%ether2 immediate-gw=fe80::a00:27ff:fe00:4101%ether2 type=unicast distance=110 scope=20
        target-scope=10
   DAo  dst-address=b00b::10:0:10:2 routing-table=main gateway=fe80::a00:27ff:fe00:4101%ether2 immediate-gw=fe80::a00:27ff:fe00:4101%ether2 type=unicast distance=110 scope=20
        target-scope=10
   DAo  dst-address=b00b::10:0:10:3 routing-table=main gateway=fe80::a00:27ff:fe00:4101%ether2 immediate-gw=fe80::a00:27ff:fe00:4101%ether2 type=unicast distance=110 scope=20
        target-scope=10
   DAo  dst-address=b00b::10:0:10:4 routing-table=main gateway=fe80::a00:27ff:fe00:4101%ether2 immediate-gw=fe80::a00:27ff:fe00:4101%ether2 type=unicast distance=110 scope=20
        target-scope=10
   DAo  dst-address=b00b::10:0:10:5 routing-table=main gateway=fe80::a00:27ff:fe00:4101%ether2 immediate-gw=fe80::a00:27ff:fe00:4101%ether2 type=unicast distance=110 scope=20
        target-scope=10
   DAo  dst-address=b00b::10:0:10:6 routing-table=main gateway=fe80::a00:27ff:fe00:4101%ether2 immediate-gw=fe80::a00:27ff:fe00:4101%ether2 type=unicast distance=110 scope=20
        target-scope=10
   DIo  dst-address=b00b::10:0:10:11 routing-table=main gateway=Loopback0 type=unicast distance=110 scope=20 target-scope=10
   DAo  dst-address=b00b::10:0:10:12 routing-table=main gateway=fe80::a00:27ff:fe00:4101%ether2 immediate-gw=fe80::a00:27ff:fe00:4101%ether2 type=unicast distance=110 scope=20
        target-scope=10
   DAo  dst-address=b00b::10:0:10:13 routing-table=main gateway=fe80::a00:27ff:fe00:4101%ether2 immediate-gw=fe80::a00:27ff:fe00:4101%ether2 type=unicast distance=110 scope=20
        target-scope=10
   DAo  dst-address=b00b::10:0:10:14 routing-table=main gateway=fe80::a00:27ff:fe00:4101%ether2 immediate-gw=fe80::a00:27ff:fe00:4101%ether2 type=unicast distance=110 scope=20
        target-scope=10
   DAo  dst-address=b00b::10:0:10:15 routing-table=main gateway=fe80::a00:27ff:fe00:4101%ether2 immediate-gw=fe80::a00:27ff:fe00:4101%ether2 type=unicast distance=110 scope=20
        target-scope=10
   DAo  dst-address=b00b::10:0:10:16 routing-table=main gateway=fe80::a00:27ff:fe00:4101%ether2 immediate-gw=fe80::a00:27ff:fe00:4101%ether2 type=unicast distance=110 scope=20
        target-scope=10
[admin@rtr1.CPE] >
mrz
Wed Jul 22, 2020 3:00 pm
Does it start to work if you change interface type from point-to-point to broadcast?
mafiosa
Thu Jul 23, 2020 12:05 am
No same issue even with point to point and broadcast!
Also for bgp nexthop is getting changed to :: which is invalid as a result all routes become invalid.
mducharme
Trainer
Trainer
Thu Jul 23, 2020 11:03 am
I am having this issue with only some of my OSPFv2 routes.
I have OSPFv2 routes across an L2TP tunnel to a RouterOS 6 device - these all show as invalid. I also have OSPFv2 routes to a RouterOS 6 device across an EoIP tunnel - these seem to work.
mrz
Thu Jul 23, 2020 5:15 pm
FYI problem is only on P2P interfaces (not ospf interface type but actual P2P interfaces like l2tp etc. )
We will fix the problem as soon as possible.
oreggin
Fri Jul 24, 2020 11:39 am
Yes, thanks mrz for workaround.
mafiosa
Sat Jul 25, 2020 3:20 pm
Yes problem is with p2p as interface types and p2p tunnel interfaces
mafiosa
Sat Aug 01, 2020 3:00 pm
Hello I can confirm that with gre tunnel interface if I set network type to broadcast then the ospf routes work. However on enabling ospfv3 the cou usage increates to 50-70% and sometimes lan interfaces stop processing traffic (ipv4)
Users browsing this forum: arm920t, DimaFIX and 12 guests
