Moebius
missing routeros-mmips-7.0beta8.npk
Wed Jul 08, 2020 10:09 pm
Using the 'Check for Updates' feature under 6.48beta12 to upgrade to 7.0Beta8 results in the following message:
It should actually be trying to download:
routeros-7.0beta8-mmips.npk
mducharme
Trainer
Trainer
Re: missing routeros-mmips-7.0beta8.npk
Thu Jul 09, 2020 2:33 am
That's normal. I believe they did that on purpose so that the average home user would not accidentally upgrade to v7beta using Check for Updates. You have to upload it manually, and if you know how to do that, you probably know what you are getting yourself into by upgrading.
normis
Fri Jul 10, 2020 3:18 pm
Exactly as explained above.
