emils
v6.47.1 [stable] is released!
Fri Jul 10, 2020 9:12 am
RouterOS version 6.47.1 has been released in public "stable" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.47.1 (2020-Jul-08 12:34):
Changes in this release:
*) crs3xx - fixed HW offloading for netPower 15FR and netPower 16P devices (introduced in v6.47);
*) crs3xx - fixed increased CPU temperature for CRS354-48G-4S+2Q+ device (introduced in v6.47);
*) crs3xx - improved Ethernet port group traffic forwarding for CRS354 devices;
*) defconf - fixed default configuration generation on devices without "wireless" package installed;
*) defconf - fixed default configuration loading on RBmAPL-2nD;
*) defconf - improved default configuration generation on devices with changed wireless interface names;
*) dhcpv6-server - disallow changing binding's "prefix-pool";
*) dhcpv6-server - improved stability when changing server for static bindings;
*) dns - do not allow setting "forward-to" same as "name" or "regex";
*) dns - do not allow setting zero value IP addresses for "A" and "AAAA" records;
*) dns - do not use DoH for local queries when a server is specified;
*) export - fixed HotSpot "address-per-mac" parameter export;
*) filesystem - fixed increased "sector writes" reporting (introduced in v6.47);
*) ftp - fixed possible buffer overflow;
*) ike2 - fixed initiator child SA init without policy;
*) ike2 - fixed policy reference for pending acquire;
*) ike2 - retry RSA signature validation with deduced digest from certificate;
*) ipsec - do not update peer endpoints for generated policy entries (introduced in v6.47);
*) lora - added "spoof-gps" parameter for fake GPS coordinate sending;
*) lora - fixed JSON statistics inaccuracies;
*) lte - added support for MTS 8810FT;
*) lte - fixed modem initialization when multiple modems are used simultaneously;
*) lte - fixed PDP authentication configuration for SIM7600;
*) metarouter - fixed image importing (introduced in v6.46);
*) ospf - improved route tag processing for OSPFv3;
*) ppp - allow specifying pool name for "remote-ipv6-prefix-pool" parameter;
*) profile - fixed "unclassified" load reporting on PowerPC devices (introduced in v6.47);
*) qsfp - fixed auto-negotiation status;
*) qsfp - ignore FEC mode when set to fec91, only fec74 mode is supported (introduced in v6.47);
*) routerboard - fixed "mode-button" support on SMIPS devices (introduced in v6.47);
*) routerboard - fixed "reset-button" menu presence on all devices;
*) supout - added "LoRa" section to supout file;
*) switch - fixed MAC address learning on switch-cpu port for Atheros8316, Atheros8227 and Atheros7240 switch chips;
*) w60g - added "mdmg-fix" parameter for RBwAP60Gx3 (CLI only);
*) winbox - fixed flag displaying under "IP/DNS/Static" table;
*) winbox - fixed minor typo in "BGP/Peer" menu;
*) winbox - hide irrelevant switch port parameters;
*) wireless - changed "station-roaming" default setting from "enabled" to "disabled";
*) wireless - updated "bangladesh" regulatory domain information;
*) wireless - updated "egypt" regulatory domain information;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
buburcito
Re: v6.47.1 [stable] is released!
Fri Jul 10, 2020 9:57 am
Impossible to update in Hap Lite.
killersoft
Fri Jul 10, 2020 11:01 am
hAP update seems ok to me.
MTCNA
MIT, BIT,CERT IV Electronics.
ITIL
Piotr
Fri Jul 10, 2020 11:05 am
I have updated hAP ac^2... so far so good.
BR,
Piotr
msatter
Fri Jul 10, 2020 11:13 am
Good that the false reporting of sector writes is finally fixed. This did reduce the resell value of the Mikrotik device you own greatly.
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.48beta35 / Winbox 3.27 64bits / MikroTik APP 1.3.15
rzirzi
Fri Jul 10, 2020 11:39 am
Do You think it was "false reporting" ? Maybe it was "true reporting", but now (and before) something is hidden...
nithinkumar2000
Fri Jul 10, 2020 11:41 am
One of the most annoying issues every faced "LOW SPACE IN DISK" :(
MTCNA | MTCRE | MTCINE | MTCTCE
Mikrotik Consultant - Specialized in ISP OPERATIONS | ROUTING | QOS | FIREWALL | MPLS | SCRIPTING | IPv6
dragoxdk
Fri Jul 10, 2020 12:00 pm
Great!
But Winbox CRASH DOWN, when Press + under System -> IPsec-> Policies.
Please fix that bug...
Kindis
Fri Jul 10, 2020 12:07 pm
Great!
Tested this and I have no issues with this so this might be related to your setup.
RN3QTB
Fri Jul 10, 2020 12:30 pm
After upgrading SXT 5nD r2 from version 6.47 to version 6.47.1, the access point was updated, rebooted, and hung. I tried to restore, downloaded this firmware via netinstall - nothing came of it. With it, this access point does not load !!!
pe1chl
Fri Jul 10, 2020 1:53 pm
To fix that, download the "extra packages" file here on a computer: https://download.mikrotik.com/routeros/ ... 6.47.1.zip
Unzip the file somewhere, and upload ONLY the package files that you are using (advanced-tools, dhcp, ppp, routing, security, system, wireless) to the device.
Probably you can omit the routing package as well, unlikely you are doing BGP or OSPF on such a tiny device.
Then reboot using the System->Reboot menu entry (do not powercycle the device).
eworm
Long time Member
Long time Member
Fri Jul 10, 2020 2:00 pm
Already reported for 6.48beta, but applies here, too:
This is about forwarding? Looks like queries are still sent via DoH for me.
Anybody made this work?
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Jotne
Fri Jul 10, 2020 2:25 pm
Great!
Its IP -> IPsec -> Policies not System and it works fine with Winbox 3.24 (latest)
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
nichky
Long time Member
Long time Member
Fri Jul 10, 2020 2:40 pm
please do /system resource print
RouterOS does not have a random function. Many has tried to make script to make random text, but all seems to be flawed.
viewtopic.php?f=9&t=160183
!) Safe Mode is your friend;
obscurus
Fri Jul 10, 2020 2:47 pm
Not working Adguard doh dns ( https://dns.adguard.com/dns-query ).
Error in log like:
DoH server response not OK: 301: <html>
<head><title>301 Moved Permanently</title></head>
<body>
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx</center>
</body>
</html>
how to configure mikrotik on this doh dns?
buburcito
Fri Jul 10, 2020 2:52 pm
vecernik87
Forum Veteran
Forum Veteran
Fri Jul 10, 2020 3:29 pm
Not working on mine either.
msatter
Fri Jul 10, 2020 5:11 pm
Mikrotik states increased "sector writes" reporting. So the counter was just hyperactive and was even triggered when noting was written to the flash.
Running:
notToNew
Fri Jul 10, 2020 7:12 pm
Really? Nobody ever asked me for this... 😂
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
floaty
Fri Jul 10, 2020 8:01 pm
still no option-set linking to a vendor-class-id possible in dhcpd ... ? it's possible in v7beta8 !? ... is this by intent ?... or a bug ?
[admin@v6.47.1] /ip dhcp-server vendor-class-id> add
Creates new item with specified property values.
address-pool -- pool used for this vendor-class-id
copy-from -- Item number
disabled -- Defines whether item is ignored or used
name --
server -- global or single server
vid -- contents of vendor-class-id as string or hex with 0x prefix
We know what happens to people who stay in the middle of the road. They get run over.
msatter
Fri Jul 10, 2020 8:35 pm
You poor thing. Do you feel left out now?
Running:
Znevna
Fri Jul 10, 2020 10:43 pm
Nobody cares about the "reduced resell value" because of the sector writes count. Who advertises de sector writes count when selling their hardware? Is that a thing? realy?
Selling a cheap MikroTik, cheaper? how much "resell value" loss are we talking about? If you decided to ditch that device you must have some other reasons.
You're not reselling gold.
It has any meaning from an administrative point of view when you monitor that value and you notice it increasing without any explanation and you start to dig for the cause, nothing else.
OH, and if you have some device for sale, why do you still keep updating and using it with the latest and greatest release? Leave it somewhere offline without installing some release as soon it gets out.
Any comment about this should be considered offtopic and deleted. Including my current comment.
Cheers.
Davis
Fri Jul 10, 2020 10:45 pm
I think this might be about :resolve command with server parameter specified.
E.g.:
:put [:resolve google.com server=8.8.8.8]
:put [:resolve example.com server=10.10.10.10]
msatter
Fri Jul 10, 2020 11:44 pm
Cheers.
I have two hEX-s bought in short sequence and one has 300K on the clock and the other one 1600K. The last one, ran ROS 6.47 with the crazy counter. Gold has a market price so you can't compare that with a router. I don't think a router will increase it price during years of usage.
Resell value is something different than collectors value and I don't keep my routers in the original unopened box.
Running:
nichky
Long time Member
Long time Member
Sat Jul 11, 2020 12:04 am
have you seen the issues?
you got 6.8MiB free memory, and the new version itself has 11.4MiB
What have you got in file? it seems like you have to remove something from there.
Make sure you got enough free memory.
staticsafe
Sat Jul 11, 2020 12:17 am
Is the issue with SFP interfaces fixed in this release? Changelog suggests so but can anyone confirm?
ozone
Sat Jul 11, 2020 12:26 am
6.47.1 seems to work fine on 3011 and 2011....
(other RBs are still on "long-term")
Still missing the "antenna gain" setting though (removed in 6.47), since I'm running the 2011 with non-standard (not build-in) antenna's, and now the gain cannot be set correctly against regulatory-domain.
Also, I know that in 6.44.3 the sfp-led is removed from the configs, but this was very useful. So why???
It was, space-wise, also totally unnecessary to remove, since 2011 has more that enough storage to run 8 (!) Mipsbe-partitions if one would choose to....
Searched through the forums and the net, and all I could find was people asking why it was removed, but never an answer by MT.
So please Mikrotik, be a sport, and re-instate the sfp-led (as user-led setting) and the antenna-gain field.
Ozone
floaty
Sat Jul 11, 2020 12:37 am
must be very annoying to our fellow Mikrotikls, that every new release anouncement is turning into a whining-zone : )
so many fashionable new features ... no party : \
... but that's your life jacky brown : |
so hopefully my vendor id dhcpd inconvience is handled first : )
vecernik87
Forum Veteran
Forum Veteran
Sat Jul 11, 2020 1:30 am
E.g.:
You may be right davis! I tested it just now with 6.47 (not working) vs 6.47.1 (working). So it was just misunderstanding of the changelog.
nmt1900
Sat Jul 11, 2020 2:27 am
Dude is having frequent disconnects with operation failed: 10054:connection reset by peer. System log is not showing anything related to that...
For now reboot seemed to cure that problem.
megabitus
Sat Jul 11, 2020 7:07 am
I've upgraded an LtAP mini (RB912R-2nD), and it would not boot after updating.
I did a netinstall with 6.47.1 and it started. I kept the config, seems to work fine now.
Not sure if a problem with my device or a bug.
hAP ac, hAP ac 2, and crs112 updated with no problem.
krafg
Long time Member
Long time Member
Sat Jul 11, 2020 7:32 am
Updated RBM33G, LtAP LTE kit, BaseBox 2, BaseBox 5 and PowerBox Pro without issues.
R11e-LTE-US works well on both devices.
Regards.
If you want to know my network, you can find it here.
ofer
Sat Jul 11, 2020 1:43 pm
Updated 3xHapAC 6.47 -> 6.47.1 - So far no issues.
Updated 3xHap Lite 6.47 -> 6.47.1 - No issues.
Regards.
tesme33
Sat Jul 11, 2020 2:09 pm
Hi
i dont believe that i will be able to upgrade my hex3.
Only 4.9MiB free but nothing on the flash.
Anybody an idea ? Im about 50km away from this box.
[admin@MikroTik] /file> /system resource print
                   uptime: 20w5d4h35m31s
                  version: 6.46.3 (stable)
               build-time: Jan/28/2020 10:46:05
         factory-software: 6.40
              free-memory: 207.1MiB
             total-memory: 256.0MiB
                      cpu: MIPS 1004Kc V2.15
                cpu-count: 4
            cpu-frequency: 880MHz
                 cpu-load: 0%
           free-hdd-space: 4.9MiB
          total-hdd-space: 16.3MiB
  write-sect-since-reboot: 207005
         write-sect-total: 470237
               bad-blocks: 0%
        architecture-name: mmips
               board-name: hEX
                 platform: MikroTik
[admin@MikroTik] /file> print
 # NAME                                   TYPE                                         SIZE CREATION-TIME
 0 mikrotik_config_2020032... script                                     8.4KiB mar/26/2020 15:20:53
 1 hex3_20200711.rsc          script                                     8.9KiB jul/11/2020 12:59:24
 2 flash                                  disk                                              jan/01/1970 02:00:07
 3 flash/skins                            directory                                         jan/01/1970 02:00:08
 4 flash/pub                              directory                                         sep/07/2019 11:30:53
nmt1900
Sat Jul 11, 2020 2:37 pm
That turned out to be premature assumption - problem is back. It occures only when trying to open property window of Dude server device itself in Devices menu - Device properties window stays open for a second and then disconnection occures - every time. System log shows only "logged in" and logged out" messages...
anav
Sat Jul 11, 2020 3:29 pm
Stable - do these products contain francium?
Not updated - 2xHex Stable
Not updated- 2xCapac Stable
Not updated-1ccr1009 Stable
As for hex resale value, still waiting for HW offload on the hex chipset. ;-)
PS. This Danish custom of drinking in the early morning is not that bad!
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
tesme33
Sat Jul 11, 2020 4:38 pm
Mmmh.
it worked on
hex3 with only 5 M free hdd space
crs326 with only 2.5 M free hdd space
hap lite with 7.9 M frre space (but here i only have the following packages: advanced,dhcp,routing,security,system,wireless)
xvo
Forum Veteran
Forum Veteran
Sat Jul 11, 2020 6:24 pm
I had the same problem. Was able to trace it to the fact that I renamed the device that had some disabled services: graph data sources for these services retained the old device name and that was causing client to crash on mouse over.
After I removed these disabled services the crashes stopped.
Jotne
Sat Jul 11, 2020 8:47 pm
Hi
I would downgrade to an older, much smaller version then upgrade to latest, but in your case that may give problem if you loose some function so that you can not reach it any more.
MikroTik->Splunk
kai
Sat Jul 11, 2020 11:48 pm
I think this is broken in 6.47 (and also here still in 6.47.1). It works fine on 6.46.6.
https://www.reddit.com/user/gromo3eka/c ... indscribe/
I did send some support files for 6.47 regarding this issue but I think it's still not fixed here. Can anyone else confirm? Or maybe even better still suggest a fix? It's stopping me from upgrading as I need to use this feature..
Jotne
Sun Jul 12, 2020 12:17 am
What is this? Post info here, not a link..
MikroTik->Splunk
kai
Sun Jul 12, 2020 3:45 am
It's instructions for setting up an IKEv2 client to a VPN service. It generates a dynamic NAT rule to route traffic for addresses in an address list.
In 6.47+, it basically kills all routing for some reason.
Link to post in the 6.47 release thread about the same problem: viewtopic.php?f=21&t=161887#p800523
tesme33
Sun Jul 12, 2020 10:08 am
Hi
Hi
thanks for the hint. Not sure if you have seen my former post. It worked even with the limited amount of storage.
Im wondering why mikrotik doesnt make custom images per HW. What i mean. There is no need for the wireless package on a hex3.
macropin
Sun Jul 12, 2020 10:57 am
Updated cAP ac (RBcAPGi-5acD2nD). Upgrade seemed to work fine. Then performed a reset using the reset switch and now it won't boot. I'm about to try netinstall to see if it's bricked or not.
Update: Can't get netinstall to work. Not sure if the device is bricked or if it's because I'm connecting through a mikrotik switch for PoE. Any advice?
Update2: Finally got netinstall working under Windows XP. Windows 7 & 10 didn't work for me. Reflashed and reset the device and its working again.
faxxe
Sun Jul 12, 2020 11:09 am
Update from 6.47 (38d uptime) to 6.47.1 on CCR1009-7G-1C-1S+ was flawless
-faxxe
dvm
Sun Jul 12, 2020 11:49 am
CAPsMAN is a part of the wireless@ package.
abiv
Sun Jul 12, 2020 10:41 pm
Is transmit power back for the AC2?
jsadler
Sun Jul 12, 2020 11:10 pm
I'm I've seen issues with Bridge Hardware offloadfing causing packet loss on 6.47.1 (that didn't exist in 6.47).
I'm still investigating the issue currenltly, but so far I have seen....
-Packets between non-hardware accellerated interface and hardware accellerated interfaces are OK.
-Packets between two hardware-accellerated interfaces have severe packet loss.
-Simply turning OFF hardware acceleration on the bridge port fixes the issue, and turning setting back ON brings the issue back
So far I've updated about 100 devices, I've had complaints / noticed this issue on 2 devices.
1 x HAP AC Lite 952Ui-5ac2nD and 1 x 2011iL.
Has anyone else noticed this issue?
Cheers,
Jono.
vecernik87
Forum Veteran
Forum Veteran
Mon Jul 13, 2020 1:41 am
@jsadler: Do you have some switch chip configuration on those particular devices with faults? It might be relevant because quite a while ago, I had an experience with RBD52G (using Atheros 8327 switch chip) that some features from switch-chip menu were causing serious packet loss to a degree I had to power-cycle the device because I couldn't even access it. the RB2011 is using two switch chips (Ath8327 for 1Gbit ports and Ath8227 for 100Mbit ports). The RB952Ui also uses Ath8227.
So... there might be a pattern, or it may be completely unrelated thing :D I got all 3 models sitting around in production so I will see if there is some way to reproduce it.
or... maybe this?
Can you identify, whether the RB2011 suffers this issue on both switches or just 100Mbit/1Gbit?
bratislav
Mon Jul 13, 2020 2:43 pm
Hi
Hi
There is really no reason for that because you can make your own selection very easy ...
You download "Extra packages" that would be all_packages-<platform>-<ver>.zip with all available packages, then copy only what you need from the zip to routerboard (say system, dhcp, security, advanced-tools) and reboot and system with leave and update only these packages and from that point will update only that ...
Jotne
Mon Jul 13, 2020 3:10 pm
Did not now that this was possible. Will test it out.
MikroTik->Splunk
bpwl
Forum Veteran
Forum Veteran
Mon Jul 13, 2020 4:31 pm
Hi
Hi
Well since some recent RouterOS version, the download area for the npk is hidden. Maybe there are some files that will be deleted before the upgrade. (/system package update cancel ???)
If you do it manually the npk goes in RAM (above flash)
rtlx
Mon Jul 13, 2020 9:01 pm
I can't understand, why MikroTik put so little flash memory to current devices. 16MB in 2020...
bda
Mon Jul 13, 2020 11:51 pm
Agreed... Very disappointing fact... Many interesting devices, but 16mb... And causes many troubles with upgrading.
God bless UNIX!
wrkq
Tue Jul 14, 2020 1:25 am
Because the Qualcomm system-on-a-chip designs used for many MT products which hardware limit of max 16 MB SPI flash.
This is also the reason some products have the bizarre combination of fast wireless and 100Mbit ethernet ports - QCA decided to embed a 100Mb switch into the SoC.
patrickmkt
Tue Jul 14, 2020 2:23 am
I still have the same problem with CRL not being updated with DOH. (I am using Cloudflare)
DoH server connection error: SSL: handshake failed: unable to get certificate CRL.
I do have the DigiCert Global Root CA as trusted.
I even went to the extend to download the root CA of the websites where the CRL were downloaded from but with no luck either.
The DNS queries however seems to work properly with the DOH for all the clients. Just the router CRL update is not working anymore.
ksteink
Tue Jul 14, 2020 2:30 am
I have upgraded multiple devices from 6.46.6 to 6.47.1 (I skipped 6.47 as it was too buggy with the write disk issues that several users reported). I have upgraded:
- 4 x hAP AC2
- 2 x CRS326
- 1 x CRS312
- 2 x RB2011
- 1 x RB4011
- 3 x hEX S
- 1 x RB951Ui
- 1 x hAP Lite TC
Some of them has IPv6, others VPNs (L2TP/IPSec, IKEv2 and OVPN) and I have identified no issues so far.
r00t
Tue Jul 14, 2020 3:03 am
It's possible to use small boot SPI flash and then store main filesystem on bigger SPI flash accessed using linux SPI driver.
But Mikrotik keeps doing the same stupid 16MB thing even on devices with chips with no such limitations. For example, RBM11/33 and hEXv3 and hEX S all use MT7621A CPU. It's very common SOC, you can find list of all devices with it here: https://wikidevi.wi-cat.ru/MediaTek_MT7621
Now look around and you will see many APs with 128MB of flash, that use exactly the same CPU as Mikrotik. So for hEX, it's down to saving pennies for no good reason. 128MB flash in volume is not even $1... is it REALLY worth it!????
vecernik87
Forum Veteran
Forum Veteran
Tue Jul 14, 2020 3:58 am
Yes it is. Lets call it planned obsolescence and whats the first rule of planned obsolescence? We don't talk about it!
Ok, lets go from conspiracy theories back to the reality: It is well known that this is not a technical limitation. e.g. Mikrotik Audience with IPQ-4019 has 128MB NAND storage. on the other hand, the new Mikrotik hAP ac3 (or the "ultimate home router" chateau", both costs 50% more than Audience) has also IPQ-4019 but only 16MB Flash storage. That's the reality, deal with it. Its not about the technical limitation, it is not about the price. They just want to mess with us. No need to go into details within this software release topic
bratislav
Tue Jul 14, 2020 12:30 pm
Actually there is much simpler explanation ... those RBs don't need more ...
Firstly flash is not used to store firmware upgrade files, RAM is, as can be seen if you check free space before and after copying npk:
              free-memory: 104.4MiB
             total-memory: 128.0MiB
           free-hdd-space: 3268.0KiB
          total-hdd-space: 16.0MiB
  write-sect-since-reboot: 487
              free-memory: 91.4MiB
After reboot system is only then writing to flash deleting old system files and replacing them with new versions (or old in downgrade) ...
And since standard RouterOS package is currently around 12MB there is roughly 3MB free flash space which means there is enough reserve for future versions as it is ...
pe1chl
Tue Jul 14, 2020 12:46 pm
Note that in v7 they are moving away from the possibility to install only the packages you require, there is one big package for all functions in RouterOS and then additional packages are only used for niche functionality like monitoring a UPS or running the user-manager.
This reduces the expansion potential as all additional functions in the main RouterOS will consume space no matter if you are interested in those additions, and the remaining space for additional packages will shrink more and more.
(e.g. on my non-wireless routers I do not install hotspot and wireless, I always omit "mpls" because I don't use it, I omit "routing" on routers not running BGP/OSPF, etc. that will no longer be possible on v7)
I can understand that having separate packages for things like "ppp", "security" and "dhcp" is becoming a dependency nightmare, so it is reasonable to move those in the main package. Same for IPv6. But "mpls", "routing", "wireless" etc certainly could have been left as separate packages.
mada3k
Tue Jul 14, 2020 1:59 pm
Many other devices only have the bootloader in a 2-4MB SPI Flash, then loads the system from SD or eMMC.
Manages some CCR's, RB750Gr3, RB922 and wAP's
Ryo
Tue Jul 14, 2020 7:55 pm
When using DoH in 6.47.1 and 6.47, the dns caching is broken as the cache used will keep accumulate until it reach the max cache size set. Flush cache is not working either.
viewtopic.php?f=2&t=162733
Chupaka
Wed Jul 15, 2020 2:58 am
What about partitioning? :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Yotendoten
Wed Jul 15, 2020 5:32 am
I'm having an issue on v6.47.1 at two seperate locations (identical behavior at both) with the same setup/hardware.
This issue was not present in v6.47 (also confirmed after downgrading one of the locations that the issue did disappear when going back to v6.47) and I believe it to be specifically related to this line in the change log of this release:
I have a bridge set up for an ip-camera network on both devices with a VLAN interface assigned to an ethernet port on each side to connect them. (see config code below)
  • A PoE Switch is attached to Ether6 on the 2011UAS-2HnD.
  • The NVR is attached to Ether 7 on the 2011UAS-2HnD.
  • A Vlan(300) interface is attached to ether10 which is connected to a wAP 2nD r2.(the wAP has more than one network on it, which is why i'm using a VLAN interface here)
  • A (raspberry pi) display that views the RTSP feed of several cameras is connected to a wlan interface that is bridged to VLAN300 on the wAP.
Since the device upgraded to v6.47.1 there is some kind of arp/switching issue happening where if any device connected to the wAP is accessing a host on this network, no devices connected to the LAN side on the 2011UAS-2HnD are able to communicate with those hosts anymore. After I turn off the wireless interface and allow a few minutes to pass, the devices become accessible on the LAN again.
When this happens I can see that the MAC Entries on Switch/Host in Winbox change from "ether6" to "Switch 2 CPU".
Relevant Config Info:
# model = 2011UAS-2HnD
add name=bridge-cameras
/interface vlan
add interface=ether10-wap name=vlan300-cameras vlan-id=300
add bridge=bridge-cameras interface=vlan300-cameras
add bridge=bridge-cameras interface=ether6
add bridge=bridge-cameras interface=ether7
# model = RouterBOARD wAP 2nD r2
add fast-forward=no name=bridge-cameras
/interface vlan
add interface=ether1 name=vlan300-cameras vlan-id=300
add bridge=bridge-cameras interface=wlan300-cameras
erlinden
Wed Jul 15, 2020 9:00 am
Is my assumption correct that you are using multiple bridges? One dedicated to the cameras?
If so, you can get rid of that. A single bridge is sufficient, all you have to do is filter VLAN id's.
Have a look at this topic (I learned a lot of this topic: viewtopic.php?t=143620)
First the problem, then the solution
baks
Wed Jul 15, 2020 10:20 am
Hi All,
My router issue described in this post viewtopic.php?f=21&t=161887&p=799044&hilit=sfp#p799044 isn't resolved with upgrade to 6.47.1, still had to rollback to 6.46.6 to get SFP ONU work again.
I have made fresh rif and log it via ticket SUP-22021
BTW: Mikrotik has setup Jira service desk so if anyone with such an issue is concerned you can drop Me you email and I will add you as a requester to this issue.
RB435G+R52Hn+PSU24V2A+CustomIndoorCase
CRS125-24G-1S-RM
CRS326-24G-2S+
RB962UiGS-5HacT2HnT (HAPac)
staticsafe
Wed Jul 15, 2020 8:02 pm
Hi All,
Thanks baks, I'll DM you my e-mail address.
I guess I stay on 6.46 on my device for now, I need the SFP interface to work.
bratislav
Thu Jul 16, 2020 2:28 pm
Partioning? We don't need no stinkin' partitioning :D
Frankly I find partitioning too much hassle to use on local devices, backups are just fine ...
And RBs dont need partitioning, you do so choose your gear wisely :)
mkx
Thu Jul 16, 2020 4:06 pm
Partitioning is the best option to test something (e.g. ROS v7). Rollback involves a mere change of active partition and a reboot.
BR,
Metod
pe1chl
Thu Jul 16, 2020 4:26 pm
Partitioning has saved me when there was a problem with an update forgetting to remove the old files, causing the flash to fill up and making it impossible to upgrade, then MikroTik released a quick-and-dirty small package that would have to be installed on the system and would clean it up.
But unfortunately the package had a bug and it made the system unbootable.
With partitioning, the bootloader detects that the system fails to boot, then automatically toggles the active partition and reboots, and it rebooted the copy that I made before downloading the package and that still worked. So I could wait for the re-release of the fix package.
Without that, it would have been going through a difficult procedure to gain access to the site, and a 2x40km drive. While the network was down.
Philosof
Thu Jul 16, 2020 9:49 pm
CCR-7G-1C-1S + PC when writing to SD flash, the SPI process loads one core at 100% for a long time. I tried to change SD flash, it did not help.
kai
Fri Jul 17, 2020 2:49 am
I have a problem with a hAP ac^2 on 6.47. It won't update to 6.47.1 from either the check update option (which sees 6.47.1) nor by manually adding the firmware file from the website into files and trying to reboot.
In both cases, the router comes back up as normal but for some reason wipes all DHCP lease allocations? It remains on version 6.47.
sindy
Fri Jul 17, 2020 7:29 am
What does the log say after the reboot?
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
zedalert
Sat Jul 18, 2020 12:14 pm
Updated 4 devices to 6.47.1, local DNS records still doesn't resolving if DoH server is used. We was waiting DoH for so long but why you ruined other part of DNS...
RB2011UiAS-RM
CHR x86_64
cAP ac
mAP
regz
Sat Jul 18, 2020 12:59 pm
I have same issue with manual upgrade (upload specific packages). But it was succeeded on 2nd attempt.
pekr
Sun Jul 19, 2020 11:50 am
Very cosmetic issue, but - for quite few releases, the scaling of UI is not correct. Each time I log-in to a router, I have to go to menu and press Zoom-in, to have a correct size.
pe1chl
Sun Jul 19, 2020 12:00 pm
That problem is not related to the RouterOS version, but to the Winbox version. Please try upgrading Winbox and discuss in Winbox version topic.
Jeroen3
Mon Jul 20, 2020 11:52 pm
Good! Patches.
Put stable 6.47.1 on my hap-ac and hap-ac2 last weekend.
But now the roaming is terrible... Ehm, where did the antenna-gain field go, or what are the workarounds?
Am I now stuck with maximum gain? That's would be kind of sad actually.
amojak
Tue Jul 21, 2020 2:35 am
hi,
Why do they call this STABLE, it should be BETA at best.
6.47.1 on a Hap AC-lite and a 951-2hnd have both created a bridge problem where the router cannot be pinged or accessed from the same subnet via IP even when used as a basic bridged access point.
It produces two "neighbour" entries on other routers with differing mac addresses.
The only way to clear it is to log in via MAC telnet and disable fast forward on the bridge and disable hardware offload on the port you are trying to access it from.
The two ghost neighbour issue shows up on many routers running this release too, one shows the device name the other does not.
Seems the new Bridge implementation is rather broken, it has also nuked using Vlans for Active backup too, no amount of use of vlan filtering fixes it either.
ho hum..
Bill
mikrotikedoff
Tue Jul 21, 2020 8:01 pm
@ amojak
I fell your pain. I got lucky and had someone who'd been working with them for years explain it to me when I started a few years back. Treat beat like alpha, stable like beta, and long-term as stable. However, even this is not always the case as for example at the moment 6.45.9 long term has know issues with OSPF. I'm currently on 6.44.6 long term and I think many people operating production networks are still on the one before that. Also found that upgrading a piece of lab equipment to ensure you don't get a failure is imperative if your working with remote devices.
krafg
Long time Member
Long time Member
Tue Jul 21, 2020 9:53 pm
No icon for TR-069?
Regards.
Yotendoten
Tue Jul 21, 2020 11:15 pm
hi,
ho hum..
Bill
It seems you're experiencing the same issue, described above, that I'm experiencing on the rb2011uias-2hnd.
I believe the RB951G-2HnD uses the same switch chip as the RB2011 -- unclear about what is included on the HAP AC LIte.
ozone
Wed Jul 22, 2020 3:33 am
Good! Patches.
The only way I found I could fix it was to use superchannel and set everything by hand.
(there may be other ways I don't know about yet. If so, please advise)
I could see the purpose of this removal on simple devices like hap-lite (with printed PCB-antenna), but on any RB with antenna's that can be swapped this removal is ill-advised imho.
ozone
Wed Jul 22, 2020 4:44 am
@ amojak
.... Treat beat like alpha, stable like beta, and long-term as stable. However, even this is not always the case as for example at the moment 6.45.9 long term has know issues with OSPF. I'm currently on 6.44.6 long term and I think many people operating production networks are still on the one before that. Also found that upgrading a piece of lab equipment to ensure you don't get a failure is imperative if your working with remote devices.
I agree totally.... Use only long-term for "stable" in production, and classify every other (stable, beta and dev) one notch lower..... In the current "stable" branch there is still too much fixing going on. But in typing that, I realize that there is now no longer a real "long-term" available. :(
What I mean is a version that is only security-patched and bug-fixed, without changing the features and config method, and that targeted to environments that runs for several years (not just about one year). Something like Microsofts LTSB/LTSC versions..... They have 10(!) years of support lifespan.
Ok, from what exists today, changing from about 1y to 10y maybe a bit much all at once, but 3-5y is more than reasonable.
But I also know that in this forum there are (senior) people that object to that idea, as they feel that this would suck too much MT resources away from new developments, and that is what they love from MT (in fact, the degree of innovation is indeed something that is very great at MT. I love that too). But since they are so 'senior', they also intentionally or unintentionally tend to smother any real discussion about the issue.
With MT now also producing devices in the same price-range and targeted to the same business customers as the high-end "cisco's" (and the like), they will also need a more real-long-term support branch for those devices when they are deployed in such environments. These devices need to stay secure as well.
You can't have devices running 2 to 3 long-term releases back (with unpatched security issues), just because these environments simply do not allow config/behavior changes and there is no version update available anymore after about a year.. That is just bad practice. But that is the consequence of not having a real LTSB at MT.
For enthusiast-setups or more mainstream environments current MT branches are great. Nevertheless some devices are clearly targeted to something different. And these devices need the support to match.
It would be great if 6.47.x would be the first version that supports a new longer-term branch.
jimmycr
Wed Jul 22, 2020 8:47 am
Had probably some issue on my RB760iGS. Upgraded from 6.46.6 to 6.47.1 and next day I realized problems on WAN (SFP) which - by reading PL graph - started just after upgrading. Massive packet loss. So I downgraded to "Long term stable" and problem went away.
Jan
Cheers,
Jono.
Z0ltan
Wed Jul 22, 2020 10:43 am
The left hand menu disappears in webfig if you switch to quickset or terminal and back - you have to switch back to webfig, log out and log back again for the menu to appear again. I confirmed this on 3 separate devices running 6.47.1 but don't have the time to downgrade and play with it.
pe1chl
Wed Jul 22, 2020 11:52 am
I tried it. When I login to webfig (and do not save the password in the browser), then go to quickset or terminal, when I click on webfig again I am logged out.
The login screen appears without its usual markup, the same that happens when you e.g. powercycle the device while working in webfig.
When I re-type my login and password the webfig appears correctly.
Jeroen3
Wed Jul 22, 2020 12:59 pm
Good! Patches.
It says only regulatory domain is allowed for this country.
No, for the hap lite it also is a nice feature. I use hap lites on my desk to tinker with prototype iot hardware, and I do not need to create a wifi network going over the entire floor. Just my desk is fine.
I hope this function can be restored in some way, reducing output is not illegal, right?
The new icons are nice.
Strikysha
Wed Jul 22, 2020 2:15 pm
Does the problem with sectors writes solved?
en1gm4
Wed Jul 22, 2020 8:08 pm
Is anyone else having issues with VoIP devices not working after upgrade?
I have a Siemens gigaset A480IP DECT base station. It was working fine until upgrade from 6.46.6 to 6.47.1 when it just stopped working with a SIP registration error.
I factory reset the Siemens just in case and gave it a clean config but it just would not connect... reverted to 6.46.6 and it started working again immediately
A SNOM phone on the same network connected to the same voip provider had no such problems on either firmware.
Not sure even how to submit a bug report so feel free to (gently) point me in the right direction
Pea
Wed Jul 22, 2020 9:06 pm
No problem for me, simple home setup.
mszru
Wed Jul 22, 2020 9:11 pm
No issues with Gigaset C610A IP after the upgrade. The phone has successfully registered at 3 different VoIP gateways.
Z0ltan
Wed Jul 22, 2020 11:28 pm
I don't save the password in the browser. Try going into the Interfaces menu, then Terminal and then back. For me that doesn't log me out, instead it takes me back to the Interfaces screen but without the menu on the left.
I tried it on a RB4011 & 2 hap ac2-s with the same results
Edit: I tried again today with my browser cache cleared and it does log me out as well. After logging back, the menu is there. Strange...
ozone
Thu Jul 23, 2020 4:49 am
With superchannel, you have to set "no country selected" or any of the countries with loose telecom-laws. The latter is becoming a shorter list with each release.
Nope, not illegal. It's actually mandatory.
Since, if you connect an antenna with higher gain then the build-in one, and cannot set it correctly in Ros, it will transmit at an illegal level in the designed direction of the antenna.
For the Hap-lite, even this cheap and small device can transmit more than is allowed in this country, when set in a certain way ;)
I'm currently using my haplite as wifi to ethernet bridge powered directly from my laptop's usb port.
Try that with any other 10$ device. I love it!
Yep they look great..... Don't know why I would have needed them to look better, but it looks really very nice like that!
DimaFIX
Thu Jul 23, 2020 11:00 am
The problem is not fully resolved.
In versions <6.46 there were about 120 sectors per day, now it is about 1000.
WildRat
Fri Jul 24, 2020 12:18 am
I think the problem still here. This is my, at least year old WAP AC:
emils
Fri Jul 24, 2020 8:57 am
It is possible that the filesystem needs to correct itself (sort of like defragmentation works in Windows), but after the process is done, the sector write count should not drastically increase any more.
jeanpara
Fri Jul 24, 2020 11:53 pm
Since version 6.47, he really screwed up. The stable version is not advisable. mikrotik is made the same as microsoft.
jonah1810
Sat Jul 25, 2020 8:37 am
Hey! I'm not sure if this has been pointed out before or not. but in 6.46 you updated dhcpv6 server to give a "User-Name" attribute for radius accounting. it did indeed fix that but every since that release dhcpv6 "delegated-ipv6-prefix" doesnt work for accounting only. you can still set static prefixes but the accounting table is just blank in that field.
and it was definitely giving a delegated prefix in accounting on 6.45.9. just not a username. now it's vice versa
johnson73
Sat Jul 25, 2020 11:02 am
Updated RB962, wAP ac and RB2011 without issues.
ncd
Sat Jul 25, 2020 1:43 pm
Hi All,
I've just been upgrading a few devices this morning, all looking good on 6.47.1 apart from one. A RB951-2N seems to have lost the menu bar on the left in webfig.
Just done a clean netinstall of 6.47.1 and the menu is there initially but after I set anything the next time it's gone.
Not a massive problem as I still have the cli and winbox but it's just odd that it is only this device affected.
Anyone else seeing similar? - Just noticed I'm not alone, Zoltan in #94 [ viewtopic.php?f=21&t=163482&p=807781#p807333 ] also has this. Sorry!
Airell
Sat Jul 25, 2020 2:47 pm
When did showing the IP addresses in the list of static defined DNS addresses list disappear?
fbl
Sat Jul 25, 2020 7:02 pm
My Mikrotik 60 GHz connections got quite unstable since RouterOS 6.47. Especially a 3.7km link between two LHG 60G (yeah, thats way out of spec, I know..) got unusable with 6.47. The link disconnects very often, at least every 15-30 minutes.
It looks like the Beamforming doesn't work as expected anymore. The tx sector is jumping around way more than before. I've attached a screenshot of statistics of this 3.7km link. The upgrade to 6.47 and downgrade back to 6.46.6 is clearly visible..
floaty
Sat Jul 25, 2020 10:43 pm
ran into a problem configuring ROS 6.47.1 as xauth-client:
I cannot choose 'key-id' as local-id-source -> error
same on CLI
[admin@MikroTik] /ip ipsec identity> set 0 my-id=key-id:abcxyz
failure: XAuth must use auto my-id
according to this post, it seems this was working before :?: :!:
viewtopic.php?f=2&t=121258&p=787347&hil ... id#p787347
and it works in 7.1beta1
so question is: bug or known limitation ?
floaty
Sun Jul 26, 2020 3:32 pm
What's new in 6.48beta12 (2020-Jul-06 13:33):
*) ike1 - allow using "my-id" parameter with XAuth;
SOLVED
gabrielcasaliggi
Mon Jul 27, 2020 1:41 pm
Dear, last week I updated my ccr1072 to version 6.47.1. In these last two days the team stopped responding having to remove the power to restart it. Did the same thing happen to someone?
This team manages 6 BGP sessions and has a maximum traffic of 7Gb.
Thank you.
nithinkumar2000
Mon Jul 27, 2020 2:58 pm
Thank you.
I also tested the same with CCR1072 recently and never faced any problem.
Fiddlesticks
Mon Jul 27, 2020 5:57 pm
I hope the issue with SFP interfaces on this release is fixed.
In a dilemma which Launch Scanner https://bestobd2scanners.com/launch/ to choose? Read this review article to help you decide.
jackz
Mon Jul 27, 2020 6:12 pm
I have problem with sfp cage that not showing any info even link is OK...
kkosmev
Mon Jul 27, 2020 6:19 pm
I have rb952ui-5ac2nd configured as CAP.
After 6.47.1 update router is not accessible.
Unable to bring up any Ethernet interface - neither WAN nor LAN.
Reset is not working too.
Device just hang and is completely unresponsive to anything.
nithinkumar2000
Mon Jul 27, 2020 8:47 pm
Try to perform Netinstall once
https://wiki.mikrotik.com/wiki/Manual:Netinstall
kd2pm2
Mon Jul 27, 2020 10:03 pm
Same issue I have with my 2011. But my 4011 displays just fine
Ed in NJ-USA
RB2011 / RB4011 / RB260GS / RB750
changeip
Mon Jul 27, 2020 10:05 pm
Did you report this to support? It seems like I have the same problem but dont have the nice graphs like you do. Can you share the method you are using to graph those? I am currently using MRTG and SNMP but had problems with multiple registrations not working properly.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
kkosmev
Mon Jul 27, 2020 10:12 pm
Thanks, managed to bring back LTS version 6.45.9 with Netinstall
grims
Mon Jul 27, 2020 10:24 pm
Updated to 6.47.1 and noticed a strange thing, the associated IP address (make static 192.168.3.254) was suddenly transferred to a new IP 192.168.3.249, with a strange Client ID 1:52:41:53:20:0:25:22:d8:XX:XX:0:0:0:0:0:0 is this normal?
[Si@Mi] > system routerboard print
       routerboard: yes
        board-name: hAP ac lite
             model: RouterBOARD 952Ui-5ac2nD
     serial-number: 90XXXXXXXXXX
     firmware-type: qca9531L
  factory-firmware: 3.41
  current-firmware: 6.47.1
  upgrade-firmware: 6.47.1
madgrok
Tue Jul 28, 2020 3:19 pm
danielwifi
Tue Jul 28, 2020 11:35 pm
Updated the v6.47.1stable to RB2011UIAS-RM . Tried to set up Hotspot feature but can;t get to work. Tried all manuals and videos but can't get it to work. Please direct me to the right instructions.
gabrielcasaliggi
Wed Jul 29, 2020 1:41 pm
Thank you.
Thanks for your answer. I can add that this situation occurred with fasttrack enabled.
When disabled, the equipment behaved normally.
Regards
netmouse
Wed Jul 29, 2020 3:37 pm
RB2011UiAS-2HnD 6.47.1 (stable)
Stopped responding, had to turn off the power to restart it.
This is the first time in many years!
r00t
Wed Jul 29, 2020 4:41 pm
Made big mistake by installing latest stable version on 60GHz link before installing it. It was completely impossible to point it correctly at 1100m link. Reported used sector kept jumping randomly around, MCS going up and down for no apparent reason as well, even without touching the LHG at all. Finally gave up, loaded 6.46.6 and everything worked like it should. Really annoying having to deal with this, at the roof that's melting hot.
This is not a stable version, this is garbage. Use it on 60GHz hardware at your own peril.
WildRat
Thu Jul 30, 2020 8:24 am
Still something wrong with this numbers:
torkue
Thu Jul 30, 2020 11:01 am
I've had the sames issues with two older Siemens Gigaset S685IP base stations, starting with 6.47.0, while other VoiP Clients and Softphones are working fine with the same SIP providers. Rreverting back to 6.46.6 and the siemens gigasets are working fine again.
Recently I've upgraded to 6.47.1 and run in the same issue again, but this time I had more time for debugging.
It seems for me these devices don't even try to register with the SIP provider and have trouble to "understand" the DNS responses from my mikrotik router, as I could only capture DNS query and responses with wireshark, but no real atemts to register with any SIP server.
Sadly these gigaset voip base stations have very poor debuggung/logging options for deeping troubleshooting.
As workaround I tried to hand out the DNS server IPs of my ISP via DHCP to them and they are able to register successfully again.
A friend of mine is using more recent Gigaset C430 Go base stations, and he had no issues with ros 6.47.0/6.47.1 so far.
Guntis
Thu Jul 30, 2020 1:32 pm
torkue could you please send us a report to support@mikrotik.com or via https://help.mikrotik.com/servicedesk ? We'd be interested in the DNS captures as well.
docmarius
Thu Jul 30, 2020 11:52 pm
It seems there is an issue with multicast routing in the the last 2 releases of ROS (on a CCR-1009).
PIM, after working for ages with my multicast setup (upstream on a vlan, clients on a regular bridge) stopped working in 6.47.
IGMP proxy was still working ok and I switched to it.
But after upgrading to 6.47.1, that's also gone.
Has anyone else seen a similar behavior?
LE: It seems somehow my vlan interface was not initialized properly since its interface route didn't appear in the routing table. After an edit/update of the interface it seems to be fixed.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
pe1chl
Fri Jul 31, 2020 1:05 am
I'm running PIM on a CCR-1009 only as an IGMP querier for the IGMP snooping in the switches, and it appears to run as before (on 6.47.1)
No multicast routing between the networks configured.
torkue
Fri Jul 31, 2020 12:26 pm
@Guntis, I've created an report (SUP-23619) and attached my DNS captures from that time.
Hopefully that can help to analyze, if its caused by any changes introduced in 6.47.x or it's just an stupid bug in these voip devices.
pe1chl
Fri Jul 31, 2020 3:27 pm
After upgrading to 6.47.1 and doing a /export, some routers export this:
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
Others have "dude" not enabled in that group and it is not exported.
It is a bit unclear to me what is the correct "default config": with dude in that group enabled or disabled.
Cha0s
Fri Jul 31, 2020 3:30 pm
This has happened to me starting with v6.45.7 (also on a CCR1009).
Disabling/enabling the interface fixes the routing table, but it took me a trip to a remote location and about an hour to figure out why the local VLAN would not work, while everything else worked fine on the network. This had happened after an unexpected power outage.
faxxe
Sat Aug 01, 2020 12:46 pm
Today after 20d uptime on my CCR1009 suddently the internet was down. I could login in the CCR1009 and even the WAN port seems online and had a IP from the provider.
I had to reboot the CCR and the problem was solved. This happens first time with this build
-faxxe
Micropower
Tue Aug 04, 2020 5:30 am
We are having issues with the Powerbox Pro in simple bridge mode. Router mode is as expected. Bridged ethernet ports don't pass traffic.
Other MT devices can't see the updated devices in IP Neighbors with discovering ports = all.
pe1chl
Tue Aug 04, 2020 11:11 am
For some time already, there has been an issue with the QuickSet option to set devices to bridge mode. The default installed firewall rules make the
device reject all IP traffic. I don't know if this is is already fixed.
When this is the reason you can connect the device in MAC mode (using winbox) and remove the firewall rules. Then it should work.
(of course assuming you use the device on an internal network and don't need protection from the internet. when you do, you need to have some input rules but they need to be different from the default rules that select by incoming interface)
RalfG
IPSEC IKEv2 stopped working after upgrade from 6.46.3 to 6.47.1
Tue Aug 04, 2020 1:53 pm
on RB4011iGS+:
after upgrading to 6.47.1 all of my ikev2 tunnels (RSA auth with certificates) stopped working. (peer's ID does not match certificate).
Tested on a second device, same issue. I had to revert to 6.46.3.
Anyone else saw that?
Ralf.
gangster123
Thu Aug 06, 2020 3:42 am
While some of these issues are getting sorted out, I hope they are, what is the last really stable release? Is 6.45.9 good, or is something in the 6.46 series a better choice? Nothing's perfect but the 6.47 and 8 series seem really problematic after reading the comments. Thanks.
gcsuri
Thu Aug 06, 2020 7:54 am
my Powerbox Pro identifies itself to HEX Poe :)
regards,
bpwl
Forum Veteran
Forum Veteran
Thu Aug 06, 2020 11:23 am
My personal favorite for stability at this time is 6.45.6 (stable). There have been new features in 6.45.8 LT when the stable was migrated to LT. And new features usually bring new issues, as known in all software development. Don't know about 6.45.9 , should be a reasonable choice.
This 6.45.6 is nothing more than my personal choice at this moment. It will change over time. There are nice new features in the newer releases.
pe1chl
Thu Aug 06, 2020 11:59 am
It is the new name for the device. Apparently it does not have a built-in camera to look at the outside of the case what you have, and include the appropriate name.
Elans
Thu Aug 06, 2020 2:21 pm
@gcsuri
Please write an e-mail to support@mikrotik.com or create a request via https://help.mikrotik.com/servicedesk and attach supout.rif file from this device.
bpwl
Forum Veteran
Forum Veteran
Thu Aug 06, 2020 2:28 pm
Almost identical indeed, except for the USB and Beeper ?
https://i.mt.lv/cdn/product_files/RB960PGS_161241.png
https://i.mt.lv/cdn/product_files/RB960 ... 171122.png
owsugde
Thu Aug 06, 2020 2:53 pm
They even have the same bugs, e.g. PoE out power cycle not working. :lol:
I've always seen them as basically the same device.
vedi2
Re: IPSEC IKEv2 stopped working after upgrade from 6.46.3 to 6.47.1
Sat Aug 08, 2020 4:58 pm
on RB4011iGS+:
Ralf.
The same But 6.43.14 to 6.45.9 => identity not found for peer: DER DN: client_ikev2 .... Authentication_failed
Downgraded back and ok againe
Fuck ....
dcolli
Wed Aug 12, 2020 7:25 pm
Ctrl+c and Ctrl+v and remove the old one
gangster123
Sat Aug 15, 2020 5:21 am
on RB4011iGS+:
Ralf.
Fuck ....
Did you try any other 6.45.x builds?
npeca75
Mon Aug 17, 2020 12:59 am
Hi to all
i noticed that option 23 in dhcp v6 does not work anymore
i have
0x2a00ad0010001f000000000000000002 as value for opt 23
but it is not pushed to clients
older version work vell
pe1chl
Mon Aug 17, 2020 11:56 am
Hi to all
i have
Works for me! (in 6.47.1)
jirinovak
Tue Aug 18, 2020 8:20 am
I have encountered in this version with "waiting for program xx". It's not possible to login to router (ssh, winbox, mac-te..). After restart, everything is ok. Never happend before. HW RB1100Ahx4-dude and RB1100Ahx4 no dude. No configuration changes, no log information before this.
Has anyone encountered with this?
nje431
Tue Aug 18, 2020 2:56 pm
Join the crowd over here:
viewtopic.php?f=2&t=149062
emils
Wed Aug 19, 2020 12:28 pm
New version 6.47.2 has been released in stable RouterOS channel:
viewtopic.php?f=21&t=165166
Users browsing this forum: bozko, ste and 15 guests
