rbilka
Is/Would be there support for client roaming (802.11k,802.11r,802.11v,802.11w) ...
Wed Jul 15, 2020 9:59 am
Hi Mikrotik support.
I need official answer from Mikrotik about current state of following protocols on Mikrotik devices (RouterOS):
1. 802.11k
2. 802.11r
3. 802.11v
4. 802.11w
Please add for all above mentioned, at least following information:
1. is currently supported?
2. already in official development, and at least month/year when it would be released as beta and final
3. planed to be added, but not in development yet, and at least month/year when you start on development, and when it would be released
4. not planed / no support in next 2 years
Reason: I am planning to do some projects with Mikrotik devices, and right now, those protocols are required almost in any project available.
If it would be at least in development and released in "visible future", some of those project could be realized, but there must be official confirmation from Mikrotik, then those would be added later (and when).
I need direct answer, if there is any hope to stay on Mikrotik, or to look for other similar products from other vendor.
Thank you very much and have a nice day.
(And for Mikrotik community: are those supported via alternative firmware/OS on Mikrotik HW, like OpenVRT and etc?, do have someone real personal experience with that?)
anuser
Long time Member
Long time Member
Re: Is/Would be there support for client roaming (802.11k,802.11r,802.11v,802.11w) ...
Thu Jul 16, 2020 3:25 pm
No to all your questions. Am I correct? @all
r00t
Long time Member
Long time Member
Fri Jul 17, 2020 5:05 pm
Don't buy Mikrotik if you need these features. Sadly it's that simple...
anuser
Long time Member
Long time Member
Sat Jul 18, 2020 9:36 am
What alternative product have you already looked for?
marine88
Thu Jul 29, 2021 6:00 pm
any news on this matter?
normis
Fri Jul 30, 2021 1:43 pm
IEEE 802.11b-1999 is supported, maybe you meant something else ;)
anav
Sat Jul 31, 2021 6:59 pm
Not surprized you didnt know the correct acronym Normis ;-PPP
Its 802.11 w - 2009.
Glad to hear however, that MT is right on top of 802.11b jajajajaja
psannz
Tue Sep 28, 2021 5:55 pm
ba-da-bump?
Really would love to see IEEE 802.11k/r/v/w in combination with CAPSMAN.
Even if it's ROS7 only.
mike548141
Sat Jan 29, 2022 11:13 am
Another bump for 802.11r/k/v for client roaming
pe1chl
Sat Jan 29, 2022 12:15 pm
Even the cheapest access points given as freebies with ISP contracts now support it. MikroTik is the last in the WiFi world to add these.
When we are unlucky, they will put the support for this only in their wave2 driver which will run (almost) only on new devices.
(due to the silly 16M flash used in almost all current devices)
mike548141
Sun Jan 30, 2022 12:18 pm
Yeah agree, they are common in consumer and corporate, high end and low end gear. That is the point of open standards after all.
In my opinion we really need to understand
(a) What MikroTik's views / intentions are on these things; perhaps they do not agree with some standards as they have alternatives, maybe there are roadblocks to their adoption
(b) MikroTik to share as much roadmap as they have e.g. what are they working on but dont have an ETA for yet, and what is coming up and [very roughly] when
I was really pleased to see that the new WiFi Wave 2 driver supports WPA3, OWE, 802.11w, MU-MIMO and beamforming. The limited range of compatable hardwareis a concern however... so it would help to understand if they anticipate this eventually being supported on the existing range as the code matures and is made more efficient. Or if we will need to replace our WAP's to gain them.
Let me be clear there are lots of great features in RouterOS and the hardware. I'm personally heavily invested in MikroTik, both in terms of buying equipment and time spent perfecting it (my knowledge, scripting, config).
Besides WPA3, OWE, 802.11w, MU-MIMO and beamforming. I would love to understand their thoughts on standards like 802.11k/r/v, 802.11ax. And extending RouterOS to be able to create directories, SHA2 hash strings or files etc...
MC
gotsprings
Tue Feb 01, 2022 11:34 am
I also have a lot of time invested in Caps-Man that I "just can't use".
Had to relent and go back to other wireless vendors.
GiovanniG
Sat Mar 26, 2022 3:13 pm
thanks for keeping this post up.
I think the modern time is requesting more and more support for mobile devices, Mikrotik should consider this a priority for its development.
May somebody tell if there may be any kind of incompatibility from the old NICs with handover protocols mentioned here, in my opinion is just a question of software development.
pe1chl
Sat Mar 26, 2022 4:10 pm
There likely is no chip compatibility issue, but there might well be a code size problem. Many MikroTik devices have only 16M flash space, and as we all know it is very important to have SMB, Proxy Server, "detect internet", "kid control" etc etc so there might well be no space for 2005 vintage WiFi protocols!
anuser
Long time Member
Long time Member
Sun Mar 27, 2022 11:51 pm
MikroTik could provide a separate kind of "wifiwave2-lite" package for IPQ/4018/IPQ4019 devices with 16MB of ROM. It would fit into the flash ROM, I think:
GiovanniG
Sun Mar 27, 2022 11:53 pm
Luckly it's possible to select which packages we need, so in case there may be a space problem I can avoid with pleasure to install SMB, kid controls, etc.
I guess 802.11k,802.11r,802.11v,802.11w won't take too much space, I hope..
Let's hope they will tink about them soon
mkx
Mon Mar 28, 2022 9:26 am
Luckly it's possible to select which packages we need...
No, not in v7. In v7 almost everything is bundled in single package ... everything one really needs on hAP ac2 is actually part of single package and you can not get rid of it. And that includes SMB, proxy, etc.
Installing wifiwave2 on audience requires at least 64MB disk partition (storage consumption is almost 50MB) ... and partitioning audience's 128MB flash means that upgrades are not possible any more (audience doesn't have RAM disk so upgrade packages are downloaded to flash disk). hAP ac2 is slightly different, but I highly doubt wifiwave2 (even in lite version) is possible on 16MB flash (unbundled ROS 6.49.3 uses 15MB of flash and according to my experience, ROS v7 doesn't use much less storage than v6).
pe1chl
Mon Mar 28, 2022 2:20 pm
Eaxctly! I can fully understand why it would have become very difficult to keep "dhcp", "security", "ppp", "IPv6" etc as separate packages because there would be many inter-dependencies between low level packages like that. However, IMHO it was a bad move to put EVERYTHING in a single package. Applications like SMB and Proxy can easily be isolated in a separate package without complicated dependencies, and likely almost nobody uses these. Some devices even lack the storage (and expansion capability) to use them.
The wireless stuff should have been kept separate as well.
peracchi
Sun Apr 10, 2022 7:53 pm
@r00t sent me to this post.
If someone (preferrably from MikroTik team) could read/answer my doubt I will greatly appreciate!
It's possible to have wifi mesh/seamless roaming with one hEX S and two hAP ac²?
viewtopic.php?p=925580
pepsi133
Mon Aug 22, 2022 4:16 pm
I am just another user and integrator of Mikrotk devices around home and small offices.. wishing for roaming and WiFi 6 features to catch up. Most preferably for some 16MB devices that I have invested in (these are usually just plain wireless AP, with no need for any fancy functionality).
Either way I am (and lot of other people too) looking towards alternate brands. If I have to go with OpenWRT I might as well do it on non Mikrotik device.
kwagga
Sun Oct 23, 2022 8:50 pm
Bump
danirpg
Thu Nov 10, 2022 9:46 pm
bump
pe1chl
Thu Nov 10, 2022 11:48 pm
No need to bump, the answer is clear: no, there will be no support for 802.11k/r/v in the existing devices, only in the new ax devices.
And it will be limited at first. We don't know how long it will take for MikroTik to catch up with the other vendors.
danirpg
Sat Sep 02, 2023 1:47 pm
bump
holvoetn
Sat Sep 02, 2023 3:15 pm
https://help.mikrotik.com/docs/display/ ... 2-Benefits
Benefits
WPA3 authentication and OWE (opportunistic wireless encryption)
802.11w standard management frame protection
802.11r/k/v
400Mb/s maximum data rate in the 2.4GHz band for IPQ4019 interfaces
OFDMA
Users browsing this forum: No registered users and 10 guests
