Spudrageous
GPEN21 Eth2 to SFP Communication not working
Sat Aug 08, 2020 5:52 am
Just received my first test set of GPEN21! So excited, then so disappointed. I'm trying to terminate ActiveE FTTH into apartments and power access points with PoE using the same device. GPEN21 fits the usage case precisely. However, during testing, we are finding that no communication is possible between the internal PoE-out ethernet port and the SFP port. I suspect this caused by software ie "port isolation." Is this a feature or a bug?
krafg
Long time Member
Long time Member
Re: GPEN21 Eth2 to SFP Communication not working
Sat Aug 08, 2020 10:26 pm
I suppose that you are trying to connect GPEN21(1) -> ETH2 to GPEN21(2) -> SFP (S-RJ01).
Right?
Regards.
If you want to know my network, you can find it here.
Spudrageous
Wed Aug 26, 2020 12:33 am
Yes. I confirmed with a support case that it ins't the intended design and isn't a support operation. They may add support in SWos in a future release.
the2masters
Tue Sep 15, 2020 6:40 pm
That's too bad, this is my primary use case. Already bought two GPEN21, tried to configure them, failed, and then found this forum post. Haven't found anything about this limitation in user manual, quick start guide or your website. Please document this limitation on your website and try to fix it in the next swOS release!
For now I switched to the RB260GSP to connect a LHG to Fiber.
leeq
Fri Nov 20, 2020 11:04 pm
We just deployed 20 of these today in exactly the same setup, only to find it does not work :( .. Going to have to work out a hash with a power lead and splitter now. :(
Lee Quince
BitStreme.io
Our service is at the heart of everything we do. Customers matter fullstop. Our services are reliable and up to scratch to set the expectation.
blingblouw
Sat Nov 21, 2020 9:12 am
I don't get why it's like this. If it's a combo port then it should be marked as such. It looks great as a fibre to ethernet with poe
owsugde
Wed Dec 02, 2020 7:30 pm
Ran head-on into the same trap today. Expected the GPEN21 to be basically a three-port switch, with one copper PoE in, one copper PoE out, and one SFP. Found out that ETH2 to SFP isn't switched at all, maybe even an undocumented combo port. Cool. The AP behind the ETH PoE is now isolated from network. All this makes it much less usable as a "smart injector".
Just finding out now that in the brochure it says "GPEN21 has an Ethernet and an SFP port for fiber connectivity. These ports can be used for simultaneous external connections, but not for cross-port
communication."
Now I'm kinda asking myself: Why?
Users browsing this forum: Bing [Bot] and 36 guests
