jeffik
RB952Ui-5ac2nD
Sun Aug 09, 2020 6:39 pm
Hello. all,
I have an RB952Ui-5ac2nD
I was able to access it with the default settings 192.168.88.1 then I change the DCPH range and the router access to 192.168.7.1 I saved in settings and I could not reconnect with any IP address. I have attempted many resets using the five second 10 second and 15 second power reset I have even opened the case and shorted out the router OS. Now I cannot see any gateway when I do an IP config, I posted an image of what i see in network.
 does anybody have any suggestions? Also I have tried to access the router using the MAC address for the LAN but it will not connect.
Thans in advance
erlinden
Long time Member
Long time Member
Re: RB952Ui-5ac2nD
Sun Aug 09, 2020 8:36 pm
Just use Winbox, then you can connect by IP address (which fails) or by MAC address. And use a cable for best result (which you are already doing...).
First the problem, then the solution
krafg
Forum Veteran
Forum Veteran
Re: RB952Ui-5ac2nD
Tue Aug 11, 2020 7:49 am
1. Reset to default.
2. Go to IP-> Addresses -> Change the IP of "Bridge1" to 192.168.7.1/24
3. Put a static IP on your interface on range.
4. Connect to Mikrotik router and go to DHCP Server and delete "DHCP1" and all on "Network" tab.
5. Click on DHCP Setup and follow setup wizard selecting "Bridge1" as interface.
6. Change your interface to DHCP and see if works.
Regards.
If you want to know my network, you can find it here.
Telegram: @krafgrgi
Users browsing this forum: No registered users and 35 guests
