wojrep
CRS112 and IGMP snooping - problem
Tue Aug 11, 2020 2:27 pm
Hello
CRS112-8G-4S with RouterOS 6.47.1
IPTV traffic without IGMP Snooping functionality enabled works fine. I plan to fill the remaining ports in the switch and organize the traffic.
If I set:
/interface bridge set 0 igmp-snooping = yes
I can see entries in:
/interface ethernet switch multicast-fdb print
But IPTV won't start working properly - no picture.
IPTV arrives at CRS112 in vlan 675, then traffic is to go directly to the connected STBs without tagging.
My configuration:
add name=SWITCH igmp-snooping = yes
add bridge=SWITCH interface=ether3
add bridge=SWITCH interface=ether5-STB-test pvid=675
add bridge=SWITCH interface=sfp12
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether3,ether5-STB-test,sfp12 vlan-id=675
/interface ethernet switch egress-vlan-translation
add customer-vid=675 new-customer-vid=0 ports=sfp12,ether5-STB-test
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=675 ports=sfp12,ether5-STB-test
add ports=ether3,ether5-STB-test,sfp12 vlan-id=675
Can CRS112 handle IGMP snooping properly at all?
sid5632
Re: CRS112 and IGMP snooping - problem
Tue Aug 11, 2020 4:00 pm
Which interface is which?
wojrep
Tue Aug 11, 2020 4:33 pm
Hello.
ether3 is the interface towards the PIM router.
ether5 and sfp12 towards STB.
IPAsupport
Fri Aug 28, 2020 8:09 pm
Have you upgraded the RouterBoard firmware also?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
wojrep
Thu Sep 03, 2020 3:14 pm
Yes of course. It was updated right after the software.
tdw
Forum Veteran
Forum Veteran
Sat Sep 12, 2020 8:45 pm
According to https://wiki.mikrotik.com/wiki/Manual:I ... Offloading bridge IGMP snooping does not work properly (whatever that means) on CRS1xx/2xx with VLAN switching setups.
Users browsing this forum: No registered users and 8 guests
