zagg
Only one route active with 3 BGP peers
Sat Aug 15, 2020 2:29 pm
I use a Mikrotik CCR1009 for distribute IPv6 from 3 tunnels with BGP upstreams.
I received 3 IPv6 fulltables and all imported.
I do not use IPv6 default route.
When I try this :
[admin@MikroTik.core] > ipv6 route print detail where dst-address=2001:4860:4864::/48
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
0 ADb dst-address=2001:4860:4864::/48 gateway=servperso gateway-status=servperso reachable distance=200 scope=40 target-scope=30
bgp-as-path="34872,15169" bgp-local-pref=100 bgp-med=0 bgp-origin=igp received-from=Servperso
1 Db dst-address=2001:4860:4864::/48 gateway=openfactory gateway-status=openfactory reachable distance=20 scope=40 target-scope=10
bgp-as-path="41051,6939,15169" bgp-origin=igp bgp-communities="" received-from=openfactory
2 Db dst-address=2001:4860:4864::/48 gateway=vultr gateway-status=vultr reachable distance=200 scope=40 target-scope=30
bgp-as-path="64515,65534,20473,15169" bgp-local-pref=100 bgp-origin=igp bgp-communities=64515:44 received-from=Vultr
Only the first is active ; problem is the routeur always use first peer and don't knwo why.
Thanks in advance for help
Best Regards,
Davy
mrz
Re: Only one route active with 3 BGP peers  [SOLVED]
Mon Aug 17, 2020 10:55 am
Because BGP is designed to use only one best path by default.
Users browsing this forum: admiralfreak, ananthlucky and 5 guests
