Gnubyte
Feature request: HSGMII for SFP >1Gbps synchronization.
Wed Sep 09, 2020 1:39 pm
I submit to the sagacity of the hardware and software developers of v7 firmware the opportunity to manage the HSGMII extensions allowing the synchronization of certain SFP interfaces at speeds> 1Gbps.
For example 2.5Gbps on SFP, for a lot of references, like in https://www.dslreports.com/forum/r32458588
It would be greatly appreciated.
Thanks for your great stuff.
Florian
Re: Feature request: HSGMII for SFP >1Gbps synchronization.
Wed Nov 11, 2020 2:02 pm
Up !
Would be great indeed !
- Sorry for my english -
quentin9696
Sun Nov 22, 2020 11:47 am
I agree.
I really need this feature too, and I'm stuck with my SFP on the Mikrotik CCR2004
stevebrush
Thu Dec 17, 2020 10:50 pm
Yes please :
It will make mikrotik routers/switchs a very valuable good alternative to ISP all-in-one boxes in France.
HSGMII extensions for gpon modules at 2,5 Gbps would allow us to use our fiber offer at its full potential : 2Gbps down / 600Mbps up
Some concurrent hardware already support it but I personally prefer your brand.
Florian
Mon Feb 08, 2021 6:12 pm
Any news ? Is it possible for a futur v7 version, at least for hardware with 10gb ports ?
Thx.
shavenne
Mon May 24, 2021 4:42 am
I also would like to see this.
+1
Florian
Sun Oct 03, 2021 8:21 pm
Up !
akagami
Wed Nov 10, 2021 1:11 pm
This would be really great on the RB5009
+1
mobyfab
Thu Dec 30, 2021 9:05 pm
+1
It's not a hardware limitation on current line of devices (CCR2*** routers, CRS*** switches) as both can support HSGMII according to cpu datasheets.
This would make these devices the easiest replacement for European ISP routers.
jpost
Sat Jan 01, 2022 12:38 am
+1
Required for Nokia GPON SFP with 2.5 HSGMII
mikronerd
Sat Jan 29, 2022 8:49 am
Big +1 for this. especially with new ROS v7!
Gnubyte
Re: Feature request: HSGMII for SFP >1Gbps synchronization.  [SOLVED]
Sat Apr 16, 2022 1:59 am
Today, on a CCR2004-1G-12S+-2XS on RouterOs v7.3beta33, it is possible to sync Lantiq chipset ONU SFP at 2.5Gbps in CLI mode doing:
/interface/ethernet
set auto-negotiation=no etherNumber
set speed=2.5Gbps etherNumber
Then disable dhcp client, disable interface, enable it again, wait for some trafic, enable dhcp client.
Many thanks Mikrotik Devs for this killing feature highly needed in France.
Mackila
Re: [SOLVED !!!] Feature request: HSGMII for SFP >1Gbps synchronization.
Sat Apr 16, 2022 12:12 pm
Thanks Mikrotik !
Too bad I got a CCR2004 16G 2S+, the 2 SFP+ beeing wired direct on the CPU...
I'll try it with the CRS305 :)
Florian
Sat Apr 16, 2022 12:19 pm
Thanks Mikrotik !
I don't get why they can't add the support by the cpu. The switch asic is more "compatible" than the one into the cpu ? idk....
felixka
Sun Apr 17, 2022 6:01 am
Comes down to the Linux driver support. Most don't have 2500Base-X support, even though the chip may support it. So either Mikrotik goes ahead and implements that part themselves or waits for the Kernel to gain this support from the OEM. On Switch chips it may be easier as the switch chip can handle it directly while being connected to the CPU through a different, supported link mode.
shavenne
Mon Apr 25, 2022 9:52 pm
I can confirm it's working on CRS309-1G-8S+ and CRS328-24P-4S+
Tried that with a Huawei MA5671A GPON-ONU.
mobyfab
Tue Apr 26, 2022 10:52 pm
Seems to sync OK at 2.5Gbps on a CRS317. (GPON ONU from FS.com)
However since switch rules are broken and bridge filters are ignored, I can't make it work.
olivier2831
Wed Apr 27, 2022 8:52 am
Does any 2.5Gb/s Ethernet interface support HSGMII or vice versa or both ?
In other words, beside 2.5Gb/s speed, what does an Ethernet interface need to support to fully implement HSGMII ?
Florian
Sat May 07, 2022 7:40 pm
Nope, it has to be 2.5g+HSGMII compatible. A lot of 2.5g interfaces are not HSGMII compatible.
nereith
Sun May 08, 2022 4:57 am
Are you seeing the 2.5Gbps speed option on the SFP+ port when you disable auto negotiation?
I upgraded the CRS309 to 7.3beta37, and 2.5Gbps option isn't available.
mducharme
Trainer
Trainer
Sun May 08, 2022 5:35 am
As it says in the changelog, it is only available from the CLI at the moment, not Winbox.
olivier2831
Mon May 09, 2022 10:00 am
@Florian:
Thanks for replying !
In many instances, I've HSGMII and 2.5Gb/s being used as if they meant exactly the same !
Florian
Wed Sep 21, 2022 11:00 am
Any news on HSGMII support on device without switch chip, like some tilera CCR ?
Users browsing this forum: Bing [Bot] and 10 guests
