jainge
R11e-LTE-US Firmware Upgrade "failed"
Sun Sep 13, 2020 2:29 am
Running MikroTik RouterOS 6.47.3 on a wAP-LTE-US device.
I am getting DL/UL speeds of 7Mbps/10Mbps, so i know there is a proper and consistent connection.
When attempting to update modem firmware via FOTA I see that there is an update available:
[admin@MikroTik] > / interface lte firmware-upgrade lte
installed: R11eL_v12.09.171931
latest: R11eL_v16.02.183961
However, when attempting (repeatably) to update firmware it first displays "status: connecting". Followed by "status: checking". Then finally "status: downloading".
And after a long wait of displaying "status: downloading", it ultimately shows "failed".
[admin@MikroTik] > interface lte firmware-upgrade lte1 upgrade=yes
status: failed
Is there another way of performing this firmware-upgrade?
Perhaps somehow applying it through the "Files" screen?
Any other suggestions?
Thank You for your help, it is Greatly Appreciated!
Mahalo - Jim Ainge
neutronlaser
Re: R11e-LTE-US Firmware Upgrade "failed"
Sun Sep 13, 2020 3:44 am
Try disabling or enabling your normal ethernet connection to the internet. I read that the updates need to be done using the LTE network. Although it never worked the 10x times I tried it.
jainge
Sun Sep 13, 2020 6:03 am
Yup, I'm only using the AT&T LTE Network. Thanx for the reply!
krafg
Forum Veteran
Forum Veteran
Sun Sep 13, 2020 7:26 am
I upgraded using USB to miniPCIe adapter 2 with of these modules.
Not all adapters are compatible.
This is compatible: https://www.ebay.com/itm/4G-LTE-IOT-Min ... b682cde513
If you have another similar adapter, you can try if it works. If the computer not recognized any change in hardware after plug in the adapter with LTE module installed, it is not compatible.
Please contact to Mikrotik support to get drivers, tools, firmware and instructions to do the upgrade.
Regards.
If you want to know my network, you can find it here.
Telegram: @krafgrgi
jainge
Sun Sep 13, 2020 9:11 am
Thank You.
I do not have an adapter like that... one more thing for my toy box. https://www.ebay.com/itm/4G-LTE-IOT-Min ... b682cde513
There is something definitely wrong here...
I am posting this so that others that run into this will not waste their time and realize that it is time to contact MikroTik Support.
When performing the steps described to perform the LTE Modem Firmware Upgrade in the wiki.mikrotik.com (https://wiki.mikrotik.com/wiki/Manual:I ... re_upgrade) I am able to receive a result and I can see the Traffic passing through the LTE interface.
[admin@MikroTik] > interface lte info lte1 once
pin-status: ok
registration-status: registered
functionality: full
manufacturer: MikroTik
model: R11e-LTE-US
revision: MPSS: R11eL_v12.09.171931 APSS: R11eL_v02.14.173531
CUSTAPP:
current-operator: AT&T
lac: 23
current-cellid: 128048146
enb-id: 500188
sector-id: 18
phy-cellid: 221
access-technology: Evolved 3G (LTE)
session-uptime: 7s
imei: 355509090041493
imsi: 310410272243754
uicc: 89014103272722437544
earfcn: 5110
rsrp: -68dBm
rsrq: -10dB
status: downloading
HOWEVER, once you attempt to run the "interface lte firmware-upgrade lte1 upgrade=yes" command to download the firmware-upgrade, the R11e-LTE-US modem disconnects/shuts down and no longer passes traffic for anything. This happens whether you use the Stable routeros-mipsbe-6.47.3.npk or the routeros-mipsbe-6.48beta35.npk.
After it evidently gives up on downloading, it displays a "status; failed".
Then the modem will reconnect and things go back online.
I've even tried changing to the Long-Term routeros-mipsbe-6.45.9.npk, only to confirm that the firmware-upgrade commands are not supported under that RouterOS.
pin-status: ok
functionality: full
model: R11e-LTE-US
CUSTAPP:
lac: 23
current-cellid: 128009738
enb-id: 500038
sector-id: 10
session-uptime: 1m18s
rsrq: -15dB
failure: Device does not support this feature!
neutronlaser
Sun Sep 13, 2020 5:07 pm
Following this topic as I also have a R11e-LTE-US using AT&T, never could upgrade firmware and received no response from support.
krafg
Forum Veteran
Forum Veteran
Mon Sep 14, 2020 3:27 am
Anyway the problem is not with At&t, I used two different ISP, not from US and anyway the process fails.
For now, using the adapter is the only way to do the update. I know that they are investigating the cause of this problem.
Regards.
Telegram: @krafgrgi
jainge
Thu Feb 11, 2021 1:39 am
Using RouterOS 6.47.9 goes as far as showing "status: downloading"
But it eventually shows "status: failure" after 10 minutes
krafg
Forum Veteran
Forum Veteran
Thu Feb 11, 2021 5:18 pm
WOW, I see that the problem continues yet. So, for now, the only way to do the firmware upgrade is using the miniPCIe to USB adapter.
Regards.
Telegram: @krafgrgi
jainge
Thu Feb 11, 2021 7:02 pm
I purchased the 4G LTE Mini PCIe to USB Adapter, Model P2U52V06USB.
I sent a message to MikroTik-Technical Support yesterday.
Just waiting to get the instructions and files to use it.
SiB
Fri Apr 02, 2021 12:54 am
And you receive them ? For many cases what I see, they not block it and few people just receive howto with firmware set.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | Buy me a caffe
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
Users browsing this forum: No registered users and 37 guests
