antleo
unable to delete/rename default bgp
Thu Sep 17, 2020 2:56 am
Is there a way to delete or rename the default BGP Instance? I have tried through webfig, winbox, and ssh with no luck. Is there a reason that this is locked out?
mrz
Re: unable to delete/rename default bgp
Thu Sep 17, 2020 10:49 am
Default items cannot be renamed or deleted.
If you want your custom instances then add new ones and disable default.
antleo
Thu Sep 17, 2020 12:50 pm
Is there any reasoning behind this? It seems counter intuitive.
mrz
Thu Sep 17, 2020 2:38 pm
Items are hard coded if other default configuration might depend on existence of such items.
Users browsing this forum: No registered users and 11 guests
