kvan64
Beta9 can't delete/remove any user !!!!
Mon Jun 25, 2007 6:46 pm
I can't delete or remove any user or session. Basically can't delete anything. It always says that "check at least one user" or "check at least one session" but i have done that too. Disabling "Enable Native XMLHTTP Support" did not help either. I have also tried Fire Fox but just not helping!
sergejs
Re: Beta9 can't delete/remove any user !!!!
Thu Jun 28, 2007 3:57 pm
Could you provide us with remote access to the User Manager Web interface (contact support department about this),
we will check the situation out there, we could not reproduce the particular issue on our User Manager routers.
kvan64
Thu Jun 28, 2007 4:54 pm
I may sound a bit...dump but how do I get the remote access to the user manager? I only have the local ip address of it.
sergejs
Fri Jun 29, 2007 8:24 am
You need to set routeable IP address to the router, then router will be accessible from everywhere,
provide support with access to Web interface of this rotuer.
kvan64
Sat Jun 30, 2007 11:22 am
Please give me some specific instruction how to set this. Ta
sergejs
Mon Jul 02, 2007 10:00 am
You have to ask your provide to give routeable IP address for your router, that is accessble from any other public network.
kvan64
Wed Jul 04, 2007 3:05 am
Now I have obtained a external static ip address. I am having trouble forwarding it to my router using my Billion 7300A ADSL2+ modem settings. I got the the Virtual Server setup page and found the follwing parameters:
Service sellect: I chose <user defined>
Protocol: TPC/UDP
Public start port: no idea
Public end port: no idea
Mapped Private IP Address: I guess this is for my router's IP
Mapped Private Port: no idea
sergejs
Wed Jul 04, 2007 8:57 am
Protocol should be TCP,
Public start/end port 80
Private port 80
kvan64
Thu Jul 05, 2007 7:28 am
The problem fixed with beta10 upgraded from 2.9.44. COOL !!!
Now I heard that external IP address accessibility is still needed for PayPal payment system.
Private port 80
I tried this but it doesn't forward to my routeros. When I entered the static IP address, I got to my ADSL2+ modem's page. Do I need to add any extension to get to my MT router?
sergejs
could I private ms you my external IP and login of my modem so that you could help me have a look at the setting? Ta
sergejs
Thu Jul 05, 2007 10:35 am
Probably, you can disable Web service on your modem, if such option is available at this router.
kvan64
Thu Jul 05, 2007 11:00 am
I can't find this option. Also I have the modem that acts as a DHCP server that leases internet and set DHCP client on my routerOS as this is the only way that I know of.
sergejs
Thu Jul 05, 2007 1:06 pm
Change port for 'www' service on 'ip service' menu from default 80 to any other, than create NAT rules for new port, in order we can access to your User Manager.
kvan64
Thu Jul 05, 2007 3:39 pm
I have not set any NAT rule before. Could you plz show me a bit more specifically how to set it. Ta
sergejs
Thu Jul 05, 2007 3:43 pm
It is the same thing we are talking about in the previous posts,
Set appropriate ports there.
Protocol: TPC/UDP
kvan64
Thu Jul 05, 2007 4:13 pm
Winbox
"www services" to port 84
ADSL Modem
Virtual Server
Service sellect: user defined
Protocol: TPC
Public start port: 84
Public end port: 84
Mapped Private IP Address: hotspotip
Mapped Private Port: 84
External static IP address still leads to the Modem's manager page and not the routeros user-man
Ps. there is also an option for enabling DMZ. what is DMZ IP Address?
skillful
Trainer
Trainer
Sat Oct 06, 2007 12:42 pm
This problem is back in 3.0RC6! I always get the "check at least one user" error message whenever I try to remove some users despite the fact that more than 10 users are check marked.
Users browsing this forum: No registered users and 4 guests
