afuente26
GPeR
Sat Oct 03, 2020 6:47 pm
is it possible to use a GPeR-repeater with one device POE out on the one side, and the other device with "nothing", I mean without any POE?
Al the diagram I see, they use on the one site POE out and on the other side POE in....
Thansk
Angel
xvo
Re: GPeR
Sun Oct 04, 2020 2:26 am
Yes, you can remove jumpers on PoE-out side and then it won't pass PoE further.
But there is a note, that it won't work if 802.3af/at is used - the power source device won't power the GPeR alone.
https://i.mt.lv/cdn/product_files/GPeRqg_190928.pdf
afuente26
Re: GPeR
Sun Oct 04, 2020 8:42 am
Great, thanks. All the information was there ;-)
Greetings
Angel
szymonzdziabek
Re: GPeR
Thu Jun 03, 2021 12:22 am
Do you know guys why GPeR can't be powered by 802.3af/at itself? I'd like to extend the link between two switches, however in that situation it isn't possible to use GPeR.
mkx
Re: GPeR
Fri Jun 04, 2021 3:00 pm
You could use RBGPOE passive injector from one side to power GPeR ... I guess.
Users browsing this forum: No registered users and 20 guests
