chvdr
misteriously happends randomply... SOLVED!
Tue Jun 26, 2007 10:53 pm
xr5 vs. sr5. 42km distance, 37Mbps bandwidth test, usually good signal levels, everything works fine, but several times dayly for 10 minutes we have logs such as follows:
===========AP-site================
04:07:17 wireless,debug wlan1: 00:15:6D:XX:XX:XX attempts to connect
04:07:17 wireless,debug wlan1: 00:15:6D:XX:XX:XX in local ACL, accept
04:07:17 wireless,info 00:15:6D:XX:XX:XX@wlan1: connected
04:07:18 wireless,info 00:15:6D:XX:XX:XX@wlan1: disconnected, extensive data loss
04:07:21 wireless,debug wlan1: 00:15:6D:XX:XX:XX attempts to connect
==========Client-site==============
22:13:47 wireless,debug wlan2: failed to select network
22:13:47 wireless,debug wlan2: delaying scanning
22:13:49 wireless,debug wlan2: STA starts scanning
22:13:50 wireless,debug wlan2: STA scan over, results:
22:13:50 wireless,debug 00:15:6D:XX:XX:X1: on 5250 SSID MANIA caps 0x421
    rates 0x3f00 basic 0x100 MT: yes
signal level goes + 10 dBm, packet loss...
is there anybody can help
regards,
C. G.
Superdust
Re: misteriously happends randomply... SOLVED!
Wed Jun 27, 2007 10:03 pm
What was the actual problem?
chvdr
Thu Jun 28, 2007 1:07 pm
the problem is that nobody in this forum can help you in problems like that... or ain't nobody want to help you.
now seriously: big noise arround ap. on frequency quite different from our. problem solved with bigger dishes, sr5 replaced with xr5 and nstreme removed from link.
thank you for interest.
regards,
C. G.
cal361
Fri Jun 29, 2007 7:17 am
I am having a simliar problem on a PtMP system running XR2s to Compex 802.11g clients in 10mhz channels.
So far turning off "The Dude" helped the problem. However, I have seen a few clients recieved signal at the AP drop by 10db on occasion still.
I am pretty sure the volume of traffic being lower since shutting off Dude has helped. I am not saying Dude was the problem, but my problem occurs much less since shutting it off.
I'm working on finding the actual problem still, but my link is 100% better now. No disconnects for 48+ Hours.
boardman
Sun Jul 01, 2007 8:21 am
regards,
C. G.
Any idea why nstreme was causing that behaviour? Did you tested the setup with the bigger dishes, XR5´s but WITH nstreme enabled?
- We are experiencing similar behave on a 53Km PtP link with Xr5´s and nstreme, I haven try it without nstreme since they say for those kind of shots nstreme is necesary .... mmmh
Best
Jorge Boardman
chvdr
Sun Jul 01, 2007 9:44 am
sure, we have...
dishes 1,5m both sites, signal level between 52 and 83!!! working fine with levels under 80, but... we need 30Mbit link and sometimes smt. goes wrong. i still have no any idea what's going on.
regards,
C. G.
Users browsing this forum: reactiv1 and 46 guests
