instant
Pi-Hole and Mikrotik - DNS - Pi-hole only show my router’s IP address
Mon Oct 19, 2020 6:51 pm
In a network with a Mikrotik as a Router with DHCP, I have installed Pi-Hole to use it as DNS and block advertising. Once configured as DNS granted by the Mikrotik's DHCP, it works for all computers.
But I have a problem, in the web interface of the Pi-Hole, they all appear as a single device in the client list, which would be the Mikrotik.
This seems to be because the requests are forwarded by the Mikrotik even though the primary DNS is the Pi-Hole.
Some routers force clients to use the router as their DNS server
Even if you set Pi-hole as the only DNS server in your router’s settings, the router still forces clients to use it as their primary DNS resolver.
Once those queries arrive at the router, it forwards the requests to the Pi-hole. Since the queries are all coming from one place, Pi-hole only sees the router as the origin of all DNS requests. So the traffic flow looks something like this:
Multiple network clients > Router (acting as the primary DNS server) > Pi-hole (acting as an upstream DNS server)
Would it be possible to correct it?
DarkNate
Re: Pi-Hole and Mikrotik - DNS - Pi-hole only show my router’s IP address
Mon Oct 19, 2020 7:09 pm
Give the Pi a static IP from DHCP>Leases
Then use static IP as DNS inside DHCP>Network
I'm using Pi-Hole myself.
xvo
Mon Oct 19, 2020 7:14 pm
I guess you entered pi-hole as DNS server in IP -> DNS?
You should additionally specify pi-hole as DNS server in IP -> DHCP -> Networks
instant
Mon Oct 19, 2020 7:16 pm
This is how it is configured, with a fixed IP reserved in DHCP, and that IP as the main DNS.
Best regards.
instant
Mon Oct 19, 2020 7:21 pm
Hi, Yes.
Attached known bug.
https://discourse.pi-hole.net/t/total-q ... er/31648/2
aesmith
Mon Oct 19, 2020 7:48 pm
Hi, Yes.
Attached known bug.
It's not really a bug though. Setting in IP->DNS tells the router what DNS server it should use, for requests not cached or locally defined. Settings in IP->DHCP->Networks is what the router tells the DHCP clients that they should use. The two settings aren't necessarily the same, for example I have IP/DNS set to OpenDNS and IP/DHCP/Networks set to the local router address. That way my clients benefit from caching.
xvo
Mon Oct 19, 2020 8:02 pm
As already stated - It's not a bug, but a misinterpretation of router's config options.
anav
Mon Oct 19, 2020 8:48 pm
Hi, Yes.
Attached known bug.
Would it be fair to say that in order for the clients to make use of the cache and IP DNS settings, the input chain has to allow users to access the router on port 53?
If we block access to port 53, then the only solution is the IP DHCP-server-network entry for DNS correct?
My question is then slightly nuanced, what if we put more than one entry for IP DHCP server-network.
If we put in hard entries such as 1.1.1.1 and 1.0.0.01 and then as last entry the lan subnetgateway as an entry, then the router will only use entered IP DNS settings (lets say we had 8.8.8.8 in there) and its cache, if the hard entries are not providing DNS returns?? (put in another way, is order important?) If so how does the router calculate or figure out a lack of return and switch to the next entry (what criteria is used)
Conversely, if the order was reversed and the router cache and use of 8.8.8.8 was not able to return DNS< would the router go to the next DNS entry on the ip -dhcp-server-network entry??
mkx
Mon Oct 19, 2020 9:18 pm
This was discussed already gazillion times: DNS system is supposed to return same results regardless the intermediate server used (out of configured ones), hence clients don't send query to another server if the previous one returns negative answer.
In that case client assumes none of configured servers will know the answer, or better: the answer doesn't exist. Only reason to send query to another server is lack of any answer (connection timeout) indicating that server is unavailable.
Well, the fact that any server should return same results may lead to different strategies used by clients to query different servers, but reception of negative answer is not one of them.
Which means that if an organization is running local domains, then multiple DNS servers should exist locally for fallbacks and that organization should not rely on public DNS servers for high availability.
robsgax
Tue Oct 20, 2020 3:05 am
I use this rules to see my devices IP in pi-hole, (kind of, i only have to interpret 10 as 192), my pi-hole ip is 192.168.0.8, i use my router ip for dns in dhcp, 192.168.0.1, but the router catches all the dns traffic and send it to my pi-hole, and mascarade it so i can see in pi-hole the device ip address. and i have another script to check if pihole is running, if not, it disable the 4 nat rules so the mk is the dns server. the script is long because i didnt want to fill my log with fetch/enable/disable every minute or so.
hope it helps
/ip firewall mangle
add action=accept chain=prerouting comment="HairPin, use local ip 10=192" \
    dst-address=10.168.0.0/24
add action=netmap chain=srcnat comment="Hairpin NAT Masq, use loc ip, 10=192" \
    dst-address-list=HomeLAN src-address-list=HomeLAN to-addresses=\
    10.168.0.0/24
add action=dst-nat chain=dstnat comment="Pi-Hole 1" dst-address=!192.168.0.8 \
    dst-address-list=!NoPiHole dst-port=53 protocol=udp src-address=\
    !192.168.0.8 src-address-list=!NoPiHole to-addresses=192.168.0.8
add action=dst-nat chain=dstnat comment="Pi-Hole 2" dst-address=!192.168.0.8 \
    dst-address-list=!NoPiHole dst-port=53 protocol=tcp src-address=\
add action=masquerade chain=srcnat comment="Pi-Hole 3" dst-address=\
    192.168.0.8 dst-port=53 protocol=udp src-address-list=HomeLAN
add action=masquerade chain=srcnat comment="Pi-Hole 4" dst-address=\
    192.168.0.8 dst-port=53 protocol=tcp src-address-list=HomeLAN
/system script
add dont-require-permissions=no name=PiHoleCheck owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
    do {\r\
    \n/tool fetch url=\"http://192.168.0.8/admin/api.php\?status\" output=none\
    \r\
    \n:if [/ip firewall nat get value-name=disabled [find comment=\"Pi-Hole 1\
    \"]] do={  \r\
    \n/ip firewall nat enable [find comment=\"Pi-Hole 1\"];  \r\
    \n}\r\
    \n:if [/ip firewall nat get value-name=disabled [find comment=\"Pi-Hole 2\
    \"]] do={  \r\
    \n/ip firewall nat enable [find comment=\"Pi-Hole 2\"];  \r\
    \n}\r\
    \n:if [/ip firewall nat get value-name=disabled [find comment=\"Pi-Hole 3\
    \"]] do={  \r\
    \n/ip firewall nat enable [find comment=\"Pi-Hole 3\"];  \r\
    \n}\r\
    \n:if [/ip firewall nat get value-name=disabled [find comment=\"Pi-Hole 4\
    \"]] do={  \r\
    \n/ip firewall nat enable [find comment=\"Pi-Hole 4\"];  \r\
    \n:log warning \"Pi-hole is working.\"; \r\
    \n}\r\
    \n} on-error {  \r\
    \"]] do={  \r\
    \n} else={\r\
    \n/ip firewall nat disable [find comment=\"Pi-Hole 1\"];  \r\
    \n}\r\
    \"]] do={  \r\
    \n} else={\r\
    \n/ip firewall nat disable [find comment=\"Pi-Hole 2\"];  \r\
    \n}\r\
    \"]] do={  \r\
    \n} else={\r\
    \n/ip firewall nat disable [find comment=\"Pi-Hole 3\"];  \r\
    \n}\r\
    \"]] do={  \r\
    \n} else={\r\
    \n/ip firewall nat disable [find comment=\"Pi-Hole 4\"];  \r\
    \n/ip dns cache flush;\r\
    \n:log error \"Pi-hole isn't working, using local DNS instead.\";\r\
    \n}\r\
    \n}"
instant
Wed Oct 21, 2020 11:52 am
Hello, in the Pi-Hole they all appear as the IP 10.0.0.2, but the subnet is 10.1.0.X.
As I have seen on the internet, it does this on any network when this happens, even if yours is 192.168.1.X.
I attach capture.
Best regards.
xvo
Wed Oct 21, 2020 12:55 pm
Where do you run your pi-hole?
Bare device, VM, docker container?
It looks like some misconfiguration in VM/docker networking.
Anyway, it most likely has nothing to do with mikrotik.
instant
Wed Oct 21, 2020 12:59 pm
Yes, is a Docker in OMV.
hermeson
Wed May 11, 2022 2:32 am
How did you get on this! =)
hope it helps
/ip firewall mangle
    10.168.0.0/24
/system script
    do {\r\
    \r\
    \"]] do={  \r\
    \n}\r\
    \"]] do={  \r\
    \n}\r\
    \"]] do={  \r\
    \n}\r\
    \"]] do={  \r\
    \n}\r\
    \n} on-error {  \r\
    \"]] do={  \r\
    \n} else={\r\
    \n}\r\
    \"]] do={  \r\
    \n} else={\r\
    \n}\r\
    \"]] do={  \r\
    \n} else={\r\
    \n}\r\
    \"]] do={  \r\
    \n} else={\r\
    \n}\r\
    \n}"
jimint
Sun Sep 11, 2022 8:17 pm
Hello
I have excactly the same problem is there any solution abouti it?
https://ibb.co/CwNqQ04
Jarek9008
Wed Sep 14, 2022 11:53 am
I have the same problem, but after installing Pi-Hole on the container - according to the manual from Mikrotik (https://help.mikrotik.com/docs/display/ ... atenetwork)
Previously I used Pi-Hole on a Raspberry and then everything was fine. Now as a Client I can only see the IP address of the Pi-Hole gate.
Have any of you found a solution to this problem?
sut
Mon Sep 19, 2022 1:20 pm
The solution from robsgax is promissing. But how does his adress-list HomeLAN and NoPiHole look like?
jimint
Tue Oct 04, 2022 8:23 am
Finally I found the solution.
My problem was in NAT. I had the rule masquarade without any interface.
So I put out Interface my PPPoE Client and everything OK now.
mrisco
Sun Nov 20, 2022 3:43 am
For future reference:
:local piholeip 192.168.0.3
:local servers [/ip dhcp-server network get 0 dns-server];
:do {
    /tool fetch url="http://$piholeip/admin/api.php?status";
    if ($servers != $piholeip) do={
        /ip dhcp-server network set 0 dns-server=$piholeip;
        :log info "Using Pi-hole as DNS";
} on-error {
    if ($servers != "208.67.220.123;208.67.222.123") do={
        /ip dhcp-server network set 0 dns-server=208.67.220.123,208.67.222.123;
        :log error "Pi-hole isn't working, using OpenDNS instead";
Njumaen
Sun Nov 20, 2022 10:12 am
Fixed the issue for me as well! 👍
mariandoom
Fri Nov 25, 2022 1:25 pm
Hi!!! Do you have instalated pihole in a mikrotik container?
Users browsing this forum: Ahrefs [Bot], anav and 41 guests
