MiseryOne
CSS610-8G-2S+ Management Access from SFP+ Port
Wed Oct 21, 2020 6:21 pm
Hey everyone,
I recently got my CSS610-8G-2S+ switch and its running great so far.
Yesterday I connected my servers via SFP+ RJ45 modules and removed their 1G links but after doing that, I could no longer the management website of the switch from the servers. If I move the cable to a normal RJ45 Port it works again. I also checked port isolation, nothing configured there and the "Allow from Ports" setting in the general tab, but all is default there - access to management from every port. A reset to default etc. didn't change the problem. My CSS610-8G-2S+ is running 2.12rc2.
Can anyone of you, also owning that switch, try if you have the same issue?
thanks
MiseryOne
AvAxxCZ
Re: CSS610-8G-2S+ Management Access from SFP+ Port
Thu Oct 22, 2020 11:38 am
Hello
Same issue
I contacted technical support:
Description:
Problem: It is not possible comunicate with device CSS610-8G-2S+ through
SFP+ ports (I,II) [Mikrotik S+RJ10 /r2]. Web interface is inaccesible, PING to
device failed, (DHCP lease failed) and static IP on the device do the same.
Standard 1G ports 1-8 works correctly (DHCP/PING/WEB). Switching between
ports 1-8 / SFP+ I,II (vice versa) always working well.
Answer SUP-30842 :
Thank you for the report!
We have managed to reproduce the issue locally in our labs and look forward to fixing it on upcoming SwOS versions, unfortunately, I cannot comment on the version availability.
wojrep
Thu Oct 22, 2020 3:49 pm
I have this problem too. It's good to know that Mikrotik Support will be working on it. I have yet seen that many people report a problem with the vlan configuration, I haven't tried it yet, I will wait for the new SwOS, maybe there will be less nerves.
MiseryOne
Thu Oct 22, 2020 6:16 pm
Hello
Same issue
Description:
Answer SUP-30842 :
Ahhh Thank's for that info. I already thought I did something wrong. Not a big issue at the moment, but great that they will fix it.
nagylzs
Thu Oct 22, 2020 8:45 pm
I can also confirm this problem. I just plugged in two identical CSS610-8G-2S+ switches, connected them via SPF+. I can access both of their web interfaces through RJ45 port, but not with SFP+ port.
nagylzs
Thu Oct 22, 2020 11:28 pm
It is not just the management interface. It seems that DCHP client is also affected. On the DHCP server side I see that address was "offered" to the switch, but the switch is not bound to the offered address.
wojrep
Thu Oct 29, 2020 8:50 am
I got the following responses from MikroTik:
A similar issue has been observed also in our labs and we look forward to fixing it on upcoming SwOS versions, unfortunately,
I cannot provide an ETA now.
and
Unfortunately, I cannot share any details regarding software availability. My apologies for the caused inconvenience.
nagylzs
Fri Oct 30, 2020 9:37 am
Well, I bought these units for a concrete installation, and now I'm not able to use them. I have a deadline. Since they cannot tell when it will be fixed, I have to use something else.
When I bought them, I did not know that web management and DHCP client won't work on SPF+ port. It also turned out the VLAN is not working normally.
Are these covered by the manufacturer's warranty?
angelspire
Wed Nov 04, 2020 7:49 am
Bump. Same with CSS610-1Gi-7R-2S+ and RB4011iGS+RM
When connected via SFP+ it works pretty much like unmanaged switch. And only in DHCP mode.
Configurations tested:
All configurations assume default router config with IP changed to 10.0.1.1 and DHCP address space to 10.0.1.101 - 10.0.1.254. Client IP set to 10.0.1.50 manual.
Case 1: Switch configured to "Static only" with IP: 10.0.1.100. Switch connected to Router vis SFP+
- switch can be accessed when client plugged into switch
- router (10.0.1.1) can't be accessed from client when client plugged into switch
- switch can't be accessed via IP address when client plugged into router
- resources connected to router are NOT accessible from client, connected to switch
- resources connected to switch are NOT accessible from client, connected to router
Case 2: Switch configured with "DHCP only" or "DHCP with fallback". Switch connected to Router vis SFP+
- switch can NOT be accessed when client plugged into switch
- router can be accessed when client plugged into switch
- switch can NOT be accessed when client plugged into router
- router can be accessed when client plugged into router
- resources connected to router are accessible from client, connected to switch
- resources connected to switch are accessible from client, connected to router
Case 3: Any switch configuration. Switch connected to router via ethernet
- both admin UIs are accessible when client connected to either box
- all resources are available when client connected to either box
leopardus2
Tue Nov 10, 2020 4:07 pm
Same here. Really annoying.
nannou9
Tue Nov 10, 2020 9:58 pm
Same problem. Took me few hours of wondering what am I doing wrong before I found this.
Agree. Quite annoying as my networks are connecting to this switch through sfp.
norepto
Wed Nov 11, 2020 2:14 pm
Same problem... I have 33 new units of this model. My dead line is in 7 days. If i don't have any solution i go to return the units.
leopardus2
Wed Nov 11, 2020 2:22 pm
return them so Mikrotik support will learn what you get when someone submits a very annoying (and easy to fix) bug and their answer is "NO ETA"
norepto
Wed Nov 11, 2020 2:36 pm
In the last 10 Years we spend in MKT devices more than € 250,000. Sometimes we had some problems but never something as obvious as this. Aswell we work with Huawei, Ruckus, Netgear, Mimosa, Silvus.... I don't normally buy switches from MKT and now I know I did it right.
norepto
Wed Nov 11, 2020 2:53 pm
Hello
Same issue
Description:
Answer SUP-30842 :
It think is a big issue... If do you have 33 units in a ring using the SFP+ ports and you can not manage it.
angelspire
Wed Nov 11, 2020 5:23 pm
Guys, seriously? This is NEW product. Not really tested by earth and fire. If you're planning a commercial install based on an untested product - it's not MKT problem, it's your risk management. Go check Cisco forums for new products they release. Give folks some slack.
Again, you wanted a cool shiny new thingie? Wanna pay a fraction of what you'd pay for Cisco? Be ready to deal with early adopter issues.
To Mikrotik team - you guys are doing great, keep pushing.
And maybe after you resolve this you could think of replacing "G" with "P" in this product name? Having PoE+ for this switch will truly make it THE instant classic :)
leopardus2
Wed Nov 11, 2020 5:51 pm
you missed the point completely
bugs do exist, in any product, new or not new.
what we are criticizing is support's answer to the request to fix a bug which should be trivial to fix
for these, Cisco used to deliver us custom builds back then when I was a customer.
norepto
Thu Nov 12, 2020 11:08 am
Totally agree. As you say, sometimes there are bugs. The strange thing is this type of error and the support that MKT provides. It's so strange that they didn't test it before launching it. On a managed switch I think this is the first point to check because... Do you want to be able to manage it? LOL.
nagylzs
Fri Nov 13, 2020 5:56 pm
This is like selling a car that has no wheels. We may classify this problem as a "software bug". But this is an obvious fault, and the product could never work with the simplest configuration.
leopardus2
Fri Nov 13, 2020 6:33 pm
Well I canceled mine, I believe many people will do the same.
norepto
Mon Nov 16, 2020 12:59 pm
Hi all,
I was in contact with MKT support. They had email me with a RC release. It works and i can manage the switch by the SFP+ but i'm waiting for a final release with the corrected bug...
leopardus2
Mon Nov 16, 2020 1:18 pm
Can you please share the RC somewhere?
norepto
Mon Nov 16, 2020 2:25 pm
I go to ask MKT support first if i can share de direct link from them or i can share by my self....
leopardus2
Mon Nov 16, 2020 3:29 pm
thanks. I canceled my order for 2 of them but already got one, so I can use that.
EdPa
Mon Nov 16, 2020 4:36 pm
Below you can download the SwOS 2.13rc5 version for the CSS610-8G-2S+ device:
https://box.mikrotik.com/f/2d3d33561426401a8697/?dl=1
And for the netPower Lite 7R (CSS610-1Gi-7R-2S+) device:
https://box.mikrotik.com/f/089b908aede040b099c8/?dl=1
It should improve the management connectivity for the SFP+ interfaces. Other fixes and improvements are coming, but I cannot comment when the stable version will be released.
leopardus2
Mon Nov 16, 2020 4:39 pm
Thanks. Appreciate it.
norepto
Mon Nov 16, 2020 7:07 pm
Below you can download the SwOS 2.13rc5 version for the CSS610-8G-2S+ device.
TY
bikerrich
Wed Nov 18, 2020 10:48 pm
You're not wrong. Just got 2 of these and the main thing people will use the SFP's for is to do 10G back-haul to a main switch not testing that management access works over the SFP is pretty poor
norepto
Thu Nov 19, 2020 11:26 am
Hi all,
Now i can manage the devices but icmp to IP of the device is very unstable...
AvAxxCZ
Thu Nov 19, 2020 12:54 pm
I know and understand it's the rc5 version, but here are my observations
  • device unstable response (ICMP)
  • lazy web interface (often you need to refresh the page to retrieve tab content)
Just for the record, Mikrotik introduced SwOS Lite
marekm
Thu Nov 19, 2020 1:44 pm
Has anyone with some electronics knowledge tried to open the CRS318-16P-2S+OUT to see inside if its PoE-out ports could be modded for use as PoE-in?
It's more expensive but runs proper RouterOS and just works, power consumption could be an issue though (would probably need 48V PoE-in).
I've done a similar mod for 24V reverse-PoE-in on a much smaller device (OmnitikUPA - old one with 802.11n and 10/100 ports), it was just adding 4 diodes (used 2 dual schottky diodes in isolated TO220, anodes to pins 4,5 of each port 2-5, common cathode to "+" of DC input jack - which becomes an output in case you need to power something non-PoE, I haven't used it).
PoE-out ports 2-5 have diodes in series, so simply applying power (without the mod) does nothing (no current flow, no damage).
Ports used as PoE-in must be set to PoE-out "off" of course - in my case ports 1-4 are used as PoE-in and port 5 as PoE-out powering the uplink radio.
soporte_tecnico
Fri Nov 20, 2020 3:23 am
we are having the same problem cannot be accessed from the sfp ports, they do not have connectivity from the sfp port among other CCS610, we bought more than 25 and I am waiting for the resolution of Mikrotik I follow the thread.
bikerrich
Fri Nov 20, 2020 11:10 am
r5 definitely allows access over SFP however the switch doesn't seem to be able to re-negotiate lower link speeds with copper 10G Mikrotik SFP modules. I have these renegotiating fine between a Mikrotik RouterOS device to a Zyxel XGS switch where they will happily renegotiate at 2.5G or 5G if the cable or length is not good enough but the CCS610 only want to do 10G or nothing. It looks like there are quite a few bugs left in SwitchOS to fix....
aurelepavia
Fri Nov 20, 2020 1:38 pm
Hello
on a css610 I configured port 1 in the lab as a trunk with 5 vlans and I configured 5 access ports on each vlan - on port 1 I connected a mikrotik router which delivers me the vlan and the associated dhcps - I can't get the vlans to transit - I followed the procedure step by step I don't see where the problem is - can you help me
I checked with a sw cisco that the router was correctly configured it's correct - my problem is of course on the css
angelspire
Fri Nov 20, 2020 10:28 pm
Trying to install r5 - fails with error that bad firmware file. Tried both from webfig and winbox. Any hints?
msimmons
Sat Nov 21, 2020 12:23 am
You got this for the NetPower 7R Lite?
EdPa
Mon Nov 23, 2020 4:21 pm
I edited my first post and added a download link for the netPower Lite 7R, see above.
sterling
Mon Nov 23, 2020 11:52 pm
Thanks for providing us with further RC candidates.
I've got 8 units now, and just was notified that my backorder of 20 units from Baltic Networks has shipped.
So I'm coming to the point where I would like to have a known good release version soon!
msimmons
Tue Nov 24, 2020 4:57 am
Thank you, sir!
However, It doesn't seem to be taking on my unit running 2.12rc2. It doesn't give me any errors, it just briefly says upgrading, then the page automatically refreshes and nothing happens or upgrades. Thanks.
angelspire
Tue Nov 24, 2020 10:01 pm
Same case for me. Shutting it off and powering back helped solving this issue. Also, make sure you use firmware for your specific device. I.e. CSS610-8G-2S+ and CSS610-1Gi-7R-2S+ are not cross-compatible.
nannou9
Wed Nov 25, 2020 1:31 am
Big thanks to Mikrotik!
msimmons
Thu Nov 26, 2020 12:02 am
A power cycle finished the upgrade. Thanks.
localnetplus
Thu Nov 26, 2020 4:14 am
I upgraded to rc5 and I still can't manage with the SFP+ port active. I have to unplug the fiber from the SFP and plug in the cat 6. Very frustrating. DHCP still doesn't work very well either.
aitidina
Thu Nov 26, 2020 10:48 am
I've rarely worked with mikrotik devices, but I just bought 3 of these and upon tinkering, I found this same problem. I'm glad it's already being worked on. Unlike many of you, I don't have any deadline and this is more of a learning project, but it would have nonethelessly bothered me to have to setup another port for management. Just wanted to thank you people who already have complained to Mikrotik about the problem.
soporte_tecnico
Fri Nov 27, 2020 9:50 pm
works with this version but with different hardware equipment, if the CSS610 equipment is not connected
bikerrich
Wed Dec 09, 2020 9:21 pm
Is there any movement on a release version that fixes the various bugs - I have a couple of these that I would like to deploy but until the major bug(s) like management access over SFP are fixed they're not really a viable option as everyone wants to do 10G segment back haul. rc5 seems to occasionally work over SFP but then mainly not. At the moment the only way I can manage the device is by having a Raspberry Pi in a LAN port and doing an SSH port forward to the switch. It's weird as it looks like traffic switching works fine but management traffic routing seems really broken.
wojrep
Thu Dec 10, 2020 8:35 am
I guess you have to be very patient ... I have the same problem, but the support's answer does not show that it quickly solves the problem definitively.
Recently, there are many problems with the new MikroTik models.
marekm
Fri Dec 11, 2020 1:49 am
Waiting for the updated firmware, too. I have a few netPower 7R switches which I'm waiting until fixed to install.
Firmware upgrade of a reverse-PoE switch should not need a power cycle. With redundant power from a few customers, it's difficult to ask all of them to power-cycle their PoE at the same time - or ask the electric power company to power-cycle the whole area ;)
Perhaps such devices should have some independent way to remotely power-cycle - just a thought, use a cheap esp8266 wifi-controlled relay module?
gateff
Mon Dec 14, 2020 9:39 am
I have a login loop issue with that model and mozilla firefox 78.5.0 esr (can not try different browser at the moment). Help!
Edit: no problems with SwOS 2.13rc5 so far
soporte_tecnico
Tue Dec 15, 2020 12:07 am
someone has version 2.12 update to 2.13rc but I don't like the results, where can I find version 2.12 to go back to the previous one, thank you very much.
cwachs
Mon Dec 21, 2020 1:08 am
Looks like VLANs are still totally broken with 2.13rc5 firmware. Makes this unusable for us in production. While I get this is a new product, switches are not new to Mikrotik and having a switch product leave the production line with no VLAN support at all is ridiculous. That is not a new product bug, that is rushing something out the door when you know it has limitations but not mentioning that in any documentation. I would never expect a Mikrotik product to arrive without a basic feature like VLAN support in a switch not working.
bikerrich
Mon Dec 21, 2020 9:32 am
Well said, likewise I also realise it's a new product but releasing something with release candidate firmware with so many bugs is just not on.
Mikrotik this device is unusable for production environments and we have been waiting weeks for some release firmware to fix the issues - why the delay?
spippan
Mon Dec 21, 2020 11:08 pm
various bugs on getting basic functionallity ... for example setting the MANAGEMENT VLAN and handling a "hybrid config" on the 2 SFP+ ports so tagged AND untagged (native) traffic is handled correctly. working on the 8 ethernet interfaces but not on the SFP+ ports
it would be a perfect replacement for some overprived cisco and HP switches but only if basic VLAN performance is given!
sadly disappointed with this incestment :-(
raiffeisen data center infrastructure and security
...stay curious
spippan
Mon Dec 21, 2020 11:19 pm
same issue observed here. DHCP server is a routerboard 922
also it is not possible to configure these ports to handle tagged traffic (trunk) and also untagged traffic (native/pvid) at the same time.
which, in the cisco world, would look like something like
interface Te1/0/1
  switchport mode trunk
  switchport trunk native vlan 10
  switchport trunk allowed vlans 10,20,30
  spanning-tree port type edge
--> which leaves TAGGED frames unchanged in their respected VLANs (egress + ingress) and all UNTAGGED frames would go to VLAN10 ingress and UNTAGGED egress! one hell of a basic VLAN configuration
also i would like to FINALLY have SSH access to SwOS! please mikrotik, let this happen!
...stay curious
JJT211
Sat Jan 02, 2021 9:31 am
BUMP
Anxiously waiting on basic VLAN support. I dont even care about the SFP issue. Just get the VLAN issue working ASAP. Ill take another rc firmware. As long as we at least have VLANS
wojrep
Sat Jan 02, 2021 9:41 am
Bad things happen at MikroTik, a product released for sale without a basic functional check. It is a great shame ... and even bigger is a long wait for a correction.
They are selling "beta" hardware and we are still paying a lot of money to test everything for them !!!
JJT211
Sun Jan 03, 2021 8:23 pm
Agreed, the LONG wait makes it that much worse. This is going on 3+ months now right? How hard is it to fix basic VLAN functionailty? I wonder if its some core hardware issue. If thats the case, why are they still selling it? If not, and giving the development team the benefit of the doubt, its a allocation of resources issue. This switch is very far down on there priority list. Which is shame.
As far as im aware, the Netpower 7R is the only switch of its kind. I need something ASAP. Anyone know of another switch that can do reverse POE with gigabit ports??
marekm
Mon Jan 04, 2021 10:06 am
If 10Gb not required (just 2x 1Gb SFP, 7x gigabit PoE-in, 1x gigabit PoE-out), there are no-name Chinese boards you can put in your own box.
I have been using these after Netpower series was announced by MT, but I got tired of waiting for its real avaiability (a year later, only 10/100 ports)
Pros: working reverse-PoE gigabit switch with standard VLAN functionality
Cons: you have to roll your own weatherproof box (doesn't look as nice), import from China (long wait, no invoice), probably no future firmware updates
Another option (where you also need to roll your own box), with more SFP ports: CRS112-8P-4S-IN should be easy to modify for reverse-PoE (solder a few diodes on the separate PoE board)
nannou9
Wed Jan 06, 2021 1:14 am
Accessing admin via sfp on 2.13rc5 usually doesn’t work for me. I gave up on it and I vpn to edge router to access it. Or connect physically to eth ports.
I’ve got my vlans working however.
This thread was helpful viewtopic.php?f=17&t=168532
sterling
Wed Jan 06, 2021 2:21 am
I loaded a CSS610-1G-7R-2S+, and a CSS610-8G-2S+ with the 2.13.rc5 SWOS (respectively).
I STILL cannot get it to pick up a management IP via VLAN.
It just picks up the regular vlan1 DHCP assigned ID and I can access it from any port.
I have management subnet on VLAN 400 handed out by DHCP.
If it go in to the CSS interface and change Allow from VLAN and put 400 in there, it appears to do absolutely nothing.
I added VLAN 400 to the VLANs tab with defaults all members, and STILL gets vlan1 dhcp IP, not management 400 IP.
Is there something else I need to be doing??
Or is this still broken in this RC5 version??
cwachs
Wed Jan 06, 2021 2:27 am
We got VLAN support working in RC6.
angelspire
Wed Jan 06, 2021 2:33 am
Where did you get rc6?
sterling
Wed Jan 06, 2021 2:36 am
Yes, where is RC6? I'll try it out if someone can link it here.
cwachs
Wed Jan 06, 2021 2:59 am
Support sent me a copy.
JJT211
Wed Jan 06, 2021 7:51 am
Nice, thanks for the heads up!! Thats all I really need!
EDIT: Just stumbled upon below support response from another thread. Got my VLANs working now
First, try to disable the "Add Information Option" under the System menu.
For access or untagged ports, use "VLAN Mode = optional", "VLAN Receive = only untagged" and specify the "Default VLAN ID". For the trunk or tagged ports, use "VLAN Mode = strict", "VLAN Receive = only tagged". And make sure to include all the necessary member ports for each VLAN ID under the VLANs menu.
The wiki manuals will get updated, thank you for pointing this out. We are still working on a new SwOS version for CSS610 devices, but I cannot predict when this version will be available.
JJT211
Thu Jan 07, 2021 6:05 am
I tried contacting support and theyre stonewalling me. Which switch did you get the RC6 version from? CSS610-7R (netpower) or the CSS610-8G-2S+ ?? If you have the Netpower firmware, could you email it over?
gintarasp2
Thu Jan 07, 2021 8:40 am
Completely the same here.
They said wait for it to be published on the web.
sterling
Thu Jan 07, 2021 8:59 pm
Great... I guess we'll sit on our inventory of 40+ units until they pull their heads out of their ass(es) collectively speaking.
I mean really, sending out a product without a viable config solution that is their "standard"?
Who ISN'T programming these on a management VLAN separate from the main/customer default vlan??
leopardus2
Thu Jan 07, 2021 9:23 pm
same here. rc5 did not fix the problem for me.
msimmons
Sat Jan 09, 2021 12:21 am
Would love to try RC6. You mind sending it over since MikroTik won't?
cwachs
Sat Jan 09, 2021 1:27 am
https://box.mikrotik.com/f/a72e315282d149eda481/?dl=1
There is the link they sent me for RC6. I guess if they object to this, they can delete this post. Since it is from their servers and they willingly sent me the link, I hope it is OK to put it here. I guess I should state this is a release candidate, not a stable firmware and is for testing only.
sterling
Sat Jan 09, 2021 1:32 am
Nice.
Did they give you a link to the css610g version as well?
cwachs
Sat Jan 09, 2021 1:34 am
No, I only am running the NetPower 7 so that is the only one I needed a firmware for.
JJT211
Sun Jan 10, 2021 9:46 pm
Nice!! Thank you sir!
norepto
Tue Jan 12, 2021 11:43 am
Any news?
gintarasp2
Tue Jan 12, 2021 12:10 pm
Any news?
O: Hello,
Thank you for contacting MikroTik Support.
Please wait for it to be released to our web page. Thank you!
Best regards,
G:Hello O,
Any idea when this will happen?
O:Hello,
Unfortunately, we do not have ETD for this. Sorry for the inconvenience caused.
Best regards,
O.
From what I learned I will not buy or recommend any Mikrotik device when it is realeased prior to checking forums for bugs reported by the end users.
Feels like early access game. And that is a damn shame.
EdPa
Tue Jan 12, 2021 1:29 pm
We have created a new testing version (rc6) which addresses some of the VLAN related problems, but the management connection from the SFP+ port is still being investigated. In some cases, it might help if you disable the RSTP on SFP+ ports and reboot the switch, but make sure there is no L2 loop on these ports. Let us know the results.
As for the VLANs, I would suggest trying these settings:
- Disable the "Add Information Option" under the System menu
- For access or untagged ports, use "VLAN Mode = optional", "VLAN Receive = only untagged" and specify the "Default VLAN ID".
- For the trunk or tagged ports, use "VLAN Mode = strict", "VLAN Receive = only tagged".
- Make sure to include all the necessary member ports for each VLAN ID under the VLANs menu.
In case you are using tagged VLAN for the device management, I would also recommend using a static IP configuration:
- Set "Address Acquisition = static" and configure "Static IP Address = x.x.x.x".
The rc6 version still contains some VLAN issues (e.g. when using "Allow From VLAN" or enabling "Add Information Option" in the System menu), so I would first suggest trying the above configuration. If you are still interested in upgrading, below are the latest testing versions:
for CSS610-8G-2S+ https://box.mikrotik.com/f/5daa1f8f216a4045b776/?dl=1
for CSS610-1Gi-7R-2S+ https://box.mikrotik.com/f/a72e315282d149eda481/?dl=1
gintarasp2
Tue Jan 12, 2021 2:06 pm
Why would you ship a product with issues like this?
nannou9
Tue Jan 12, 2021 5:30 pm
Disabling rstp on sfp port makes the admin working well for me.
Thanks for this workaround.I
sterling
Tue Jan 12, 2021 8:13 pm
Thanks for posting that EdPa (support) in this thread, that is very helpful.
I will do some testing with the code and suggestions to see if this works for us for our management scenario.
JJT211
Wed Jan 13, 2021 8:40 am
It is what it is everyone.
Thanks EdPA for sharing info and latest RC. I do have my VLANs working now with some brief testing.
gintarasp2
Wed Jan 13, 2021 5:04 pm
Seems like VLANs work yet I do not get dhcp from it. Do you get DHCP leases for VLANs?
nannou9
Wed Jan 13, 2021 7:48 pm
DHCP client for MikroTik devices doesn’t work for me somehow, have all addresses static on my mix of css610 and crs305.
But it works for devices attached to them- untagged traffic, so does the minimum required.
gintarasp2
Thu Jan 14, 2021 9:03 am
Well fo my device DHCP client worked, but for access ports DHCP does not :D
kaeferfreund
Thu Jan 14, 2021 9:22 am
I observed the same behavior:
Communication via VLANs basically works with 2.13rc6 but DHCP does not work. The Clients do not get IP-Addresses via VLAN.
In my case I cascaded (topology doesn't allow any other solution) two MikroTik devices: CRS326 and CSS610.
When I connect to the CRS326 directly, VLANs work fine an I get an IP address from the DHCP server. But with the CSS610 that's not the case. Static IPs work as expected for me.
@EdPa Can you guys look into this as well? I'm quite confident, that this is no configuration issue, but rather a firmware issue as I have installed over 200 Mikrotik devices in 2020 an many of them run VLANs 24/7. I can reproduce the behavior with all 5 CSS610 devices I have at our lab.
EdPa
Thu Jan 14, 2021 9:37 am
Does the DHCP still fail, when you disable the "Add Information Option" in the System menu?
kaeferfreund
Thu Jan 14, 2021 10:51 am
Jepp, just retested. DHCP on IPv4 still fails. On IPv6 it works with the option off. Strange thing^^
JJT211
Fri Jan 15, 2021 5:43 pm
Yea, DHCP still doesn't work for me. You have to set a static
bikerrich
Sat Jan 16, 2021 1:32 pm
That's annoying i need to use RSTP for Sonos' - come on Mikrotik can you get some engineering time to work on this hardware I've got 2 that I want to deploy but good hardware is being ruined by awful software.
Standard
Sun Jan 17, 2021 11:23 pm
I'd like to share my experience with CSS610-8G-2S+.
I managed to make vlan + ipv4 dhcp + management access from sfp+ working.
Maybe it's not the best solution for you, but with DAC cable on sfp+ (with vlan trunk) magagement works great, with the RC5 firmware, and without disabling RSTP.
Obviously with a 10GB base T module (with vlan trunk), it's not as great, but it also works by disabling RSTP on the port as you already know.
With a 10GB base T module without vlan it works great without disabling RSTP.
About VLAN, myc conf is close to what EdPa explained on "Tue Jan 12, 2021 1:29 pm", but it works for me with RC5 firmware.
I have multiple VLANs with one DHCP server per VLAN and every client gets its IPv4 from the correct DHCP.
You obviously have to disable "Add Information Option" and check trusted ports to make it works (and have a static IP for the Switch is better).
I didn't test the RC6 firmware yet as everything works for me.
I 'll wait for a stable version.
Joebar16
Mon Jan 18, 2021 8:10 pm
I switched to Mikrotik product last month with 3 CSS610-8G-2S+ and 1 CRS309-1G-8S+
First tests with SFP+ and copper network. It worked great.
When I switched to fiber as planned ... Inaccessible switches. Outch !
While searching, I discovered this thread.
Support response today with a new RC version of the firmware I passed :
Please upgrade CSS610 to SwOS Lite v2.13rc10 from the link and check if previously experienced problems remain.
https://box.mikrotik.com/f/9c2a7656ab554dd397e1/?dl=1
As seen in previous posts, I hope not to upset Mikrotik by giving this link. I think it's useful to the community!
The switches are correctly viewed, accessible for management by SFP+ fiber (MikroTik S+85DLC03D) Great !
No special modification for RSTP.
I am not using VLAN. I couldn't make any returns. I know there are quite a few worries too!
It is worth testing it for those who are in wait.
Is it better for you too?
kaeferfreund
Mon Jan 18, 2021 8:14 pm
as this is now advertised here:
https://www.youtube.com/watch?v=Xh3oQKcMOmg
I hope, things get leveled up in priority.
@EdPa
BTW: Genius move to connect the metal housing on the bottom for cooling. My RJ45 transrecievers are getting way better temps than in my css326-24g-2s+rm
Will this model (css326-24g-2s+rm) be updated with the same cooling trick? I had a LOT of trouble with using RJ45 transrecievers of various brands with this particular model. I know this is not advertised or recommended and no longer use any RJ45 trans with it. But with the CSS610-8G-2S+ that works remarkably well!
I think many people would be more than happy to pay extra for this feature
gintarasp2
Tue Jan 19, 2021 8:51 am
@EdPa
If you check this Youtuber's comments, you'll see that he encountered the same issues. More details in his web.
bikerrich
Tue Jan 19, 2021 12:14 pm
This appears to have been pulled - shame as it sounds like it fixed some of the major bugs - this is getting beyond ridiculous the time we've had to wait for working software.
Standard
Tue Jan 19, 2021 2:08 pm
Hello, thanks a lot , but the link already seems to be dead.
EdPa
Tue Jan 19, 2021 7:01 pm
A new testing version 2.13rc12 is available - the VLAN and management connection through SFP+ ports are fixed. Please try upgrading your devices and share your feedback.
Below are versions
for CSS610-8G-2S+ https://box.mikrotik.com/f/0a98c88515a64596be3d/?dl=1
for CSS610-1Gi-7R-2S+ https://box.mikrotik.com/f/6321df1cdb1b42708c6a/?dl=1
gintarasp2
Tue Jan 19, 2021 7:38 pm
Below are versions
What about dhcp clients in vlan access port?
Standard
Tue Jan 19, 2021 7:47 pm
Below are versions
bikerrich
Tue Jan 19, 2021 9:03 pm
Below are versions
SFP management works! Thank you.
nannou9
Tue Jan 19, 2021 9:29 pm
On 2.13rc12 all working for me even with rstp and add information option.
I am using multiple vlans, access ports, trunk ports etc. All good.
wsware
Tue Jan 19, 2021 9:50 pm
I just picked up the CSS610-8G-2S+ and could not get the SFP+ ports using DAC to connect at all with 2.12.
Installed the new 2.13rc12 and it is now working properly.
msimmons
Wed Jan 20, 2021 5:13 am
Below are versions
Thank you!
AvAxxCZ
Wed Jan 20, 2021 10:11 am
2.13rc12
  • access/managing through SFP+ ports >> looks OK
  • RSTP on SFP+ >> looks OK
  • VLAN and DHCP >> looks OK
  • LAG (LACP) shows MAC address again and seems more stable
Its looks promising
nannou9
Wed Jan 20, 2021 2:58 pm
2.13rc12
I have new problem now.
When I change port name and save I am loosing connection on some ports. It happens every time for me.
I need to completely reboot the switch to recover operation. Switching information option off doesn’t change anything.
Tested like 5 times and happened each time.
Sfp seem to work however as I am able to reach switch from there but eth ports seems to be down.
Surely connection to router is down (eth1 with poe, trunk port) as I cannot reach the switch from there when it happens and my internet is completely down.
Can anybody test their switches to confirm if this is my case only?
ropeguru
Wed Jan 20, 2021 4:24 pm
Below are versions
The version when I was logged in show SwitchOS, not lite, on the top left and version 2.12, no RC...
mzaferyahsi
Wed Jan 20, 2021 6:42 pm
I seem to get the DHCP on VLANs working as well but it takes too much time (60s) and in some cases I am not getting IP at all.
AvAxxCZ
Wed Jan 20, 2021 8:56 pm
2.13rc12
As [nannou9] writes. I confirming described port rename problem. Reboot fix it.
JJT211
Thu Jan 21, 2021 6:25 am
EdPa
Thu Jan 21, 2021 9:28 am
Thanks nannou9 and AvAxxCZ, it will be fixed in the next versions. For now, avoid changing the "Name" setting on the Link page when running the 2.13rc12 version.
nannou9
Fri Jan 22, 2021 12:49 am
2.13rc12
One more minor issue noticed:
MikroTik discovery doesn’t seem to work anymore.
Can’t discover devices behind the switch. I am pretty sure this was working previously. Switch itself is discoverable however. My other devices are on trunk port eth1 with poe.
Connections however still works if I put address manually, so as said: minor issue.
Thanks to MikroTik team for all improvements over last weeks.
nafeasonto
Fri Jan 22, 2021 3:43 am
I was going crazy, I was like what the heck is going on lol. Thanks for the hotfix. Any idea when they are going to release a stable firmware?
ChillFre4k
Fri Jan 22, 2021 9:44 am
  • Assign a new IP to the Swtich via DHCP wont work
  • Setting the Hostname/Identity wont work
  • Reset to factory settings should ask beforehand if you really want to do this
  • SNMP doesnt show LAG/Trunk Interfaces
I can't understand how a product can be released like this. At least the Rlease candidates bring improvement. Unfortunately they are not linked on the download page.
TheFF
Fri Jan 22, 2021 2:51 pm
Hey everyone,
thanks
MiseryOne
I've got the switch yesterday and spent about 5 hours trying to access the management via SFP+.
Until now i haven't got it working and i was trying to find an update for SwOS that may fix this.
Also there seems to be a problem with the vlans.
I've connected two different devices to the switch and both of them are getting their ip address from the untagged vlan of the switch on the SFP+ uplink.
This happens although both ports of the devices are in different default vlans.
It seems the packets got no vlan tag assigned once they arrive at the switch.
I'm happy to find this thread, because i thought the problems are caused by my configuration, but i couldn't find an error.
nafeasonto
Sat Jan 23, 2021 12:57 am
Any news when a stabile patch will be released?
jookraw
Sat Jan 23, 2021 10:43 am
Below are versions
I've tested this one for a few hours, but I was having a huge packet loss via one of the SPF+ ports using an S+RJ10 module to 2.5G NIC, reverted back to rc5, as rc6 was way worse.
nannou9
Sat Jan 23, 2021 11:48 am
Below are versions
I had temporarily more than 90% pocket loss too.
Not sure why tbh and what is worse not sure why it went away as I did many things at a time after which it suddenly went away and never happened again.
Try some silly things like resetting your switch to factory settings for example or power cycle it. I was power cycling even devices connected to it.
Anyway, never observed it again regardless of config change.
GL mate.
ChillFre4k
Sat Jan 23, 2021 12:13 pm
Plugging in a SFP+ needs a reboot of the switch
mirabelle
Sat Jan 23, 2021 11:15 pm
With rc12, my SFP module does not work anymore (it still appears but does not receive any packets from the other side). It works fine with rc5 (to which I reverted).
The module is a SFP-GE-BX from fs.com (https://www.fs.com/uk/products/75340.html). Autonegotiation is disabled and it is set to 1G.
koffeiniker
Mon Jan 25, 2021 12:34 pm
We have January 25th, 2021 ... I have 3 of these unholy electronic misfits. One would think that 2-3 month after reporting a showstopping bug, they would come up with a solution.
They are now at 2.13rc6 apparantly, but where is the 2.12 release for those who received and rc2 device?
Now of my 3 devices , one managed to run a trunk port and an access port to it. The other two just failed. I had them in the locker for almost three months due to work-load. Seeing the error-reports expecting a firmware update. I got nothing. Then I found the 2.13.rc6 and the description to it. Gave it a try .. failed. The issue with the WebGUI is bad, but my fail is even worse.
I am now busy writing a novel with an error description for sending them back for repair. Obvious reason: 3 devices configured alike, 1 works , 2 don't.
I am sorry but the 610 is a big fail. Probably not the device. But Mikrotik let us down on it, they created a mess and left us alone with it.
I will try to find another supplier for network equipment. I am ok if it costs more even 2-3 times as much, but it will work.
I mean it is not like we got a rebate for not getting what we paid for, right? I paid for a web-managed switch and I got a dumb switch.
I could not be more disappointed.
Paternot
Forum Veteran
Forum Veteran
Mon Jan 25, 2021 1:37 pm
Reading through this thread, I have a sugestion to Mikrotik, two in fact:
1) Get some form of automated basic testing. Something that would test "units of functionality", and do it one item after another. I'm not a developer, so I don't know the real name of this - but it is something wildly used, in order to get regressions and known bugs.
2) When some REALLY critical bug exists (no management from SFP+ on this product is beyond critical), release a new firmware, with JUST this correction. Something like 2.12 -> 2.12b. Change nothing else, leave the "only" serious bugs to the next version - but release a "critical fix" as soon as possible.
Really, I like Mikrotik - but sometimes the company need to step up.
JJT211
Mon Jan 25, 2021 4:10 pm
Just FYI, there's an 2.13RC12 a few posts up
nafeasonto
Mon Jan 25, 2021 9:20 pm
Any news when a more stable patch will be released? This is a little ridiculous.
JJT211
Tue Jan 26, 2021 4:44 am
Changing management IP requires reboot.
VAXman65
Tue Jan 26, 2021 6:20 am
I have a CRS326-24G-2S+ running CAPsMAN connected to my CSS610-8G-2S+ with 10Gb copper SFP+. I have multiple CAP AC units, including one connected to the CSS610-8G-2S+. This generally works but I have had troubles when changing configuration. Specifically, if I am on WiFi against the CAP AC on the CSS610-8G-2S+, changing just the name of the ports on the Link page causes the connection to be lost and for the switch to become inaccessible. So far, the only way out is to physically power cycle the unit. Once the unit comes back, I do see that the change took effect. During the time the switch is not accessible for management, it also stops passing traffic of any kind in or out of the switch for WiFi or cable connections.
I tried this a few times before reporting it.
I am running with SWOS v2.13rc12
JJT211
Tue Jan 26, 2021 6:47 am
^^^ This
I was just testing things out to see if I could deploy one but noticed the same thing, any change requires a reboot and I just cannot risk it.
AvAxxCZ
Tue Jan 26, 2021 12:17 pm
To: VAXman65
Problem was already reported and commented by EdPa from MikroTik Support
2.13rc12
mbelanger
Tue Jan 26, 2021 1:12 pm
Woah. I was pretty intrigued with this switch for my company, especially with the features, size and price-point, but not after reading this thread.
Shipping a switch that lists VLANs as a feature, but that don't function es no bueno. And what's the point of having those powerful SFP+ ports if they're unstable?
I'm new to Mikrotik, are their new product releases typically this problematic?
mknyby
Tue Jan 26, 2021 4:36 pm
Also with 2.13rc12 it is not stable at all. Disconnect with no errors on interfaces, no traffic though the switch, interface get no link when disable/enable. A reboot works for max. 4-5 minuts.
Management though SFP+ are now working.
Paternot
Forum Veteran
Forum Veteran
Wed Jan 27, 2021 4:05 am
They usually have some teething problems. But this time they went the whole nine yards. I don't remember seeing one release as bad as 6.48 (nothing to do with this hardware), and the ney models are having their fair share of problems.
I don't know why. Maybe COVID compounding with RoS7, and getting the development team swamped.
wojrep
Wed Jan 27, 2021 6:37 am
As I remember it was always a problem with new devices. However, the problems with the CCR2004 / CSS610 can only be compared to those introduced by the first CCR models. But it was never the case that support was silent for such a long time.
I see the following possibilities:
1. They row forward to spend R7 as soon as possible
2. They have to wait for the fixes of the manufacturer of individual components, eg chip firmware.
3. The problem is unsolvable and requires hardware changes.
msimmons
Wed Jan 27, 2021 8:41 pm
Any new release candidates or info on a stable release?
cwachs
Thu Jan 28, 2021 5:34 am
We are still running rc6 and had it stop responding to pings and SNMP today. At first I thought it was cold related (10 degrees F when the problem began) but it never cleared up once it warmed up. I have not rebooted the switch yet. It is still passing traffic but we can't get at it, it won't respond to ICMP ping and SNMP stopped. Well, ICMP ping drops 75% of the pings - some bounce back. It has had an uptime of about 3 weeks. This is very similar to the RB4011 (and 3011) issues that were traced to ARM software. I am expecting this switch to totally die and stop passing traffic in the next 24 hours.
JoSchaap
Fri Jan 29, 2021 11:55 am
Might it be an idea to create a sticky/pinned thread with SwOS Beta releases and their known fixes/faults?
I had to upgrade my CSS610-8G-2S+ to 2.13rc12 to resolve my SFP+ Management & DHCP passthrough issue and it took me a while to find out there is actually more then just the stable release out there.
Whilst it's a bit annoying to have to reboot the switch every time anything is changed on the interfaces page (not just names, even changing flow control/negotiation makes all ports except for SFP+ cease working); my use of the Tik devices is @home so i'm willing to shotgun any release you want us to try :)
I also wonder if anyone was able to setup 2 (or more) port LAG between the CSS610-8G-2S+ and a non-MikroTik/RB device such as a managed 3com/netgear switch or LAG supported ISP router?
Had a life.. Got a modem..
JJT211
Sat Jan 30, 2021 8:15 pm
Have you tried RC12 yet?
cwachs
Sat Jan 30, 2021 9:44 pm
Just installed rc12 after we power cycled the router to regain access to it.
mbelanger
Mon Feb 01, 2021 11:42 pm
Can someone update me on the current status of the CSS610 firmware?
Can one access the management site over the SFP+ ports?
Do VLANs properly work now?
Any other pressing issues remaining?
How far away is this software from deploying in a small production environment?
Thanks,
MB
JJT211
Tue Feb 02, 2021 7:44 am
Cool, keep us posted
JJT211
Tue Feb 02, 2021 7:46 am
Thanks,
MB
Scroll up the page and you'll see the latest 2.13RC12
VLANS and SFP management works. I have yet to deploy it yet as some have mention there's still a few bugs
alexk1
Tue Feb 02, 2021 1:08 pm
I have now successfully got this switch running with all the features I need; VLANs, Trunking, 2x10Gb MMF, SNMP, RSTP.
Haven't tried LAG yet as I don't need it, but other than that it has been up and stable for 3 days of heavy usage.
Using RC12.
Alex
mbelanger
Tue Feb 02, 2021 8:22 pm
Using RC12.
So happy to hear!
Is anyone using this with the S+RJ10 connecting at 10G over cat6a?
Thanks,
MB
bikerrich
Wed Feb 03, 2021 11:02 am
Using RC12.
So happy to hear!
Thanks,
MB
I tried but was using at 30M cable lengths and the transceivers weren't stable, I ended up switching to 80M transceivers and they're solid as a rock - just ticked over 2 weeks up time with no issues. It would just be nice if we could get some proper release firmware now.
jookraw
Wed Feb 03, 2021 1:51 pm
Using RC6 and RC12 the SFP+ with an S+RJ10 module I get a huge packet loss to the rest of the network.
I have a server connected via an SFP+ DAC cable at 10g without issues, so, for me, it seems to affect any speed with the 10GBase-T SFP+, did not test 10G or 5G, because of the lack of 10G NIC's for BaseT.
ectoplasmosis
Thu Feb 04, 2021 5:31 pm
I'm running 2.13rc12 on a CSS610, trunked via SFP+1 to a CRS317 at 10GbE via a DAC.
VLANs are configured and working on the 1Gb copper ports; I get correct DHCP addresses when plugging a client in.
But when I plug a client into SFP+2, regardless of how I have VLANs set up, the CSS610 will not pass traffic to SFP+2, and the copper ports also stop working properly until I re-plug SFP+1 trunk.
What is happening here? It would be great to be able to use the second SFP+ port for a 10Gb-capable client.
JoSchaap
Fri Feb 05, 2021 6:04 pm
Using RC12.
So happy to hear!
Thanks,
MB
I am, but only over 7 MTR length to my server; so I cant vouch for range :)
ropeguru
Fri Feb 05, 2021 8:09 pm
Can someone from Mikrotik support please explain why we have to dig through months long threads just to see if there is a new version available? Why are you avoiding putting up a pinned item for easier tracking like someone trying to avoid COVID?
This whole new set of switches and SwOS Lite seem to be the bastard children which will never get the support they deserve. Put a huge black eye on Mikrotik for me and wanting to avoid the products in the future.
bikerrich
Fri Feb 05, 2021 9:03 pm
Bit harsh but I get where you're coming from - even with Covid etc etc..., not having a release software version for hardware that shipped months ago is pretty shoddy. I think MikroTik are expecting quite a lot from their customers - hardware many be cheap but if the software doesn't work then that cheap hardware looks like an expensive paperweight.
ropeguru
Fri Feb 05, 2021 10:06 pm
It is more about transparency. When I first received the CCS610-8G-2S+ and powered it up, it show something like "SwitchOS 2.12" in the web UI so I went to the site, like I do for every new piece of hardware that I get, to see if there was any newer version of the code. I was really baffled as on the download page there was version 2.13 available but none of the versions included the switch I. had just purchased. I had to come to the forums and search and dig only to find out that the firmware was still in RC status and was a "Lite" version at that. I then had to search through this long a$$ post and found RC5 which I downloaded, only to find out later, in this same thread, that RC12 was available which fixed some of my issues.
It is just frustrating to get a new device in only to find out it is still in Beta, although not advertised that way, and has so many issues with very little response from the manufacturer.
cwachs
Sat Feb 06, 2021 11:23 pm
I have upgraded our switch to RC12. I have two customers attached to it via ether1 and ether2 - both have GPEN powered devices on their end. The uplink to the switch is into SFP+1 using a 1G SFP module.
What we notice is on RC12, every hour at exactly :13 past the hour, the switch (and all customers behind it) loose exactly 15 pings (1 second apart) - or 15 seconds on connectivity. On RC6, we would loose access to the switch over SFP+ port so it was too unstable to use.
I have swapped out the GPEN power supplies and the SFP module. The switch at the other end of the fiber never looses a ping so the problem is in the CSS610 and seems to be in the SFP+ port. We've tried turning off flow control with no effect.
cwachs
Sun Feb 07, 2021 9:42 pm
Looks like Watchdog is broken in RC12. This seems to be what was causing our router to reboot every 3600 seconds. I've turned Watchdog off and we have gone 2 hours now without a reboot.
AvAxxCZ
Mon Feb 08, 2021 8:40 pm
viewtopic.php?f=17&t=172032#p842824
I currently have 4 trunk ports on 7,8,SFP1,SFP2 and ports 1-6 I assign as needed. I did previously have a client(access port) on SFP2 working fine(same as what you are trying to achieve) and i had just removed the extra VLANs on SFP2 and assigned a native VLAN ID on the VLAN tab.
Thanks for the tips; I'll try this.
Mikrotik Support also replied with a new firmware version, 2.13rc25: https://box.mikrotik.com/f/a4b001debcee4a05aec2/?dl=1
alexk1
Mon Feb 08, 2021 9:30 pm
Appearently this is RC25 haven't checked link yet https://box.mikrotik.com/f/a4b001debcee4a05aec2/?dl=1
Edit: Yep it is
cwachs
Mon Feb 08, 2021 11:01 pm
That firmware is not for the netPower 7R.
alexk1
Mon Feb 08, 2021 11:24 pm
Working fine so far for me on the CSS610-8G-2S+
cwachs
Tue Feb 09, 2021 12:16 am
We need a version for the CSS610-1Gi-7R-2S+ switch.
alexk1
Tue Feb 09, 2021 2:19 pm
I take back what I said about RC25 being fine, I am getting hourly reboots of the switch on the hour with full outage.
Started a transfer just before reboot for testing, you can see where the switch cuts out
Disappointing :(
elevendroids
Tue Feb 09, 2021 2:33 pm
Interesting - mine works without issues - simple setup with ports 1-7 serving as untagged ports bound to a VLAN, 8 and both SFPs as trunk ports:
I have yet to test another issue that was present in rc12 - hotplugging (or unplugging) a SFP module from SFP2 would sometimes cause the traffic to be no longer forwarded via SFP1 (which is set as trunk port), need to re-check that though.
So far this firmware seems to be stable...
nannou9
Tue Feb 09, 2021 2:54 pm
Rc25 fixes all my remaining problems
ectoplasmosis
Tue Feb 09, 2021 3:08 pm
2.13rc25 breaks IGMP Snooping for me...
When IGMP Snooping is enabled in System and web interface is on the IGMP tab, multicast members are shown for a few seconds before the page is replaced with an error message in red text:
gintarasp2
Tue Feb 09, 2021 4:53 pm
Disappointing :(
Have your device actually rebooted? Because it might be that Uptime is only bugged.
I noticed it back in RC2 with Zabbix SNMP scan. Yet I did not recall losing connection at all, i had my always plugged via the switch.
I used switched as it is in current situation usable - as dumb switch.
cwachs
Tue Feb 09, 2021 4:56 pm
See my comments a little higher up. I think watchdog is broken. Our was rebooting exactly every hour as well. It was a true reboot with 15 seconds of packet loss through the switch each time it rebooted.
gintarasp2
Tue Feb 09, 2021 6:48 pm
I just powered on the PC after I got home.
6 hours earlier I have upgraded to RC25 leaviang default config with Watchdog enabled.
Switch shows uptime with no reboots 06:16:04
mbelanger
Tue Feb 09, 2021 11:12 pm
The UI keeps timing out, but uptime shows 23:33:37 since I last rebooted after installing rc25. Granted I'm still testing this switch, so it hasn't had a lot of traffic running over it, but it is connected to my network.
-MB
alexk1
Wed Feb 10, 2021 9:38 am
It is strange that we have different problems with the same hardware.
I have tried a factory reset and rebuild but i still get the same problem with hourly reboots. If I disable the watchdog function(as mentioned by Cwachs - Thank you!) i do not get the reboots.
Edit: I am also getting a similar issue to ectoplasmosis where igmp tab keeps clearing itself but i don't get the error message they do.
sterling
Wed Feb 10, 2021 6:58 pm
I assume you guys are reporting all problems in RC to support as they are getting closer to release?
I submitted a ticket to get the latest 7R RC update package so I can test it along with the 610 8 port 2 SFP+ port switches we have and want to use.
gintarasp2
Thu Feb 11, 2021 2:21 pm
Hello everyone, yesterday I have compiled a list of issues with CSS610-8G-2S+ that I have found in this forum.
I have upgraded two units of CSS610 to RC25 and run two instances of testing:
1. With default configuration.
2. With VLAN configuration.
P.S. Due to not having SFP cable of any kind, SFP issues could not be tested by me, feel free to post below your results.
Here are my tests and results:
1. With default configuration after RC25 upgrade:
1.1. Management Access Via SFP+ - NOT TESTED - do not have available cable.
1.2. Default access ports - TESTED - dumb switch forward everything works.
1.3. DHCP client SWITCH - TESTED -works with no VLANS.
1.4. DHCP client SWITCH-Connected-Device - TESTED - works for all devices.
1.5. ICMP drops - TESTED - none observed.
1.6. Less than 10G speed negotiation on SFP fails the port - NOT TESTED - do not have available cable.
1.7. Port rename causes port to fail - TESTED - no issues observed.
1.8. Discovery behind the Switch - TESTED - no issues with discovery.
1.9. Random packets get lost between/to switch. - TESTED - did not observer any lost packets.
1.10. Plugging in SFP requires device to be rebooted. - NOT TESTED - do not have available cable.
1.11. Changing IP for management requires reboot the device. - TESTED - it requires reboot yes, is it intended? I do not know.
1.12. Changing flow control causes to fail ports. - TESTED - one PING got dropped.
1.13. Switch reboots every hour. - TESTED - 6 hours later, no reboots.
1.14. IGMP snooping is broken. - NOT TESTED? - Empty window, no idea is it broken or not.
1.15. Changing negotiations causes port failures. - TESTED - No failures, need to be set on both sides, no reboot required.
2. With VLAN configuration after RC25 upgrade:
2.1. Management Access Via SFP+ - NOT TESTED - do not have available cable.
2.2. VLAN access ports - TESTED - works with Optional + Untagged + ID + Port membership configuration
2.3. DHCP client TRUNK port SWITCH - TESTED - does not work.
2.4. DHCP client SWITCH-Connected-Device in VLAN - TESTED - works fine. All separate VLANs gave their own DHCP leases.
2.5. ICMP drops - TESTED - none observed.
2.6. Less than 10G speed negotiation on SFP fails the port - NOT TESTED - do not have available cable.
2.7. Port rename causes port to fail - TESTED - no issues observed.
2.8. Discovery behind the Switch - TESTED - no issues with discovery. Device has to be in the same VLAN as managed device (router, switch, etc.)
2.9. Random packets get lost between/to switch. - TESTED - no issues observed.
2.10. Plugging in SFP requires device to be rebooted. - NOT TESTED - do not have available cable.
2.11. Changing IP for management requires reboot the device. - TESTED - it requires reboot yes, is it intended? I do not know.
2.12. Changing flow control causes to fail ports. - TESTED - one PING got dropped.
2.13. Switch reboots every hour. - TESTED - no reboots after one hour of testing today.
2.14. IGMP snooping is broken. - NOT TESTED? - Empty window, no idea is it broken or not.
2.15. Changing negotiations causes port failures. - TESTED - No failures, need to be set on both sides, no reboot required.
2.16. Management access via TRUNK port - TESTED - works fine from trunk port / no issues observed.
2.17. Mikrotik DHCP client on access port - TESTED - gets IP address.
Topology:
HAP AC3 router -> Atheros 8327 SW chip for trunk port -> CSS610(SW1) -> CSS610(SW2)
Point to point connections are trunks. Access ports are VLAN 10, 20, 30, and default 1.
Access ports : Mode=Optional + Receive=Untagged + ID=1/10/20/30 (depends)
Trunk ports : Mode=Strict + Receive=Tagged + ID=-
After configuration configure VLAN and port memberships.
Hope this post saves you some time of scrolling thru this page.
Leave a like, comment, subscribe.
Best regards,
ectoplasmosis
Thu Feb 11, 2021 5:32 pm
Update:
Using the second SFP+ port as an access port for a client is broken again. Using 2.13rc25, was working fine until I changed the native VLAN on the SFP+ access port.
Even with everything set as per the copper access ports, the client connected to SFP+ will not get DHCP or pass traffic.
The strange thing is that in the 'Stats' tab, Rx Rate always shows zero when a client is connected to the secondary SFP+ port, whereas Tx Rate and Tx Bytes count up.
sterling
Fri Feb 12, 2021 2:26 am
Mikrotik support punted and gave me the "default" useless answer:
"Hello,
You can download the latest releases from our download page, www.mikrotik.com/download, or wait till the next version is releases with fixes.
Best regards,
Oskars K."
Of course the answer is invalid since they currently have NO firmware available on the download page for 610 series anything.
Can someone post the latest 7R version firmware download link please?
I mean, it's not like I've been purchasing Mikrotik since they first started selling junky wireless PCBs a couple decades ago.......
msimmons
Fri Feb 12, 2021 5:00 am
"Hello,
Best regards,
Oskars K."
Let me know when you get that, Sterling.
marekm
Sun Feb 14, 2021 12:35 am
Is there still (as of current RC) any situation where the reverse-PoE switches might need a reboot by power-cycle (remote reboot either not possible, or possible but not sufficient)?
Asking because power-cycle is difficult to do in many reverse-PoE installations (redundant power from several different customers who may not even be around all at the same time).
sterling
Re: CSS610-8G-2S+ Management Access from SFP+ Port
Sun Feb 14, 2021 12:51 am
I sure hope it doesn't have issues.
But to be sure, we've implemented watchdog based on a ping to the upstream switch to make sure it power cycles itself.
That works in most cases so far with older CRS switches, so I'm hoping it's solid in the 2.13 release...
JJT211
Sun Feb 14, 2021 1:04 am
"Hello,
Best regards,
Oskars K."
Yea, I got same answer as well
sterling
Tue Feb 16, 2021 11:53 pm
I emailed suppport back and asked them to give me access again to the RC candidates.
I did some testing on the 610-8G-2S+IN today in preparation to start testing them out in the field.
Doing some rate limiting on the Ingress/Egress with management/feed on SFP1.
Egress/Download to client on any of the Ethernet GigE ports seems to work ok when I put in something like 250M in the field.
It gives me around 255Mbps on speedtest.net client. So download/Egress works.
Ingress on any of the GigE ports seems broken though.
If I put a similar value of 250M on Ingress it limits my upload to around 5Mbps.
If I put it to some max value around 900M it lets it go to about 20Mbps.
So that doesn't work correctly.
If I do set the Egress on the uplink SFP1 at 250M then it does successfully limit the client to 250Mbps both ways.
But that limit ALL upload in total to 250Mbps across the switch outgoing SFP1 uplink.
So it's a temp solution for us until they fix it.
Also, the download never seems to get above 900Mbps Egress on any of the GigE ports without throttle, so there might be some 50Mbps of optimization to do there as well.
Our uplink is 10Gbps to a Force10 switch with 40Gbps to the speedtest server, so there is plenty of bandwidth there for testing.
That's all I've tested so far.
I will also be testing Option 82 DHCP Snooping and port isolation as well.
pwnet
Wed Feb 17, 2021 7:04 am
Well, I have to say, reading this thread (and others) has been really disappointing. Thankfully, I wasn't too invested in Mikrotik; I purchased one CSS610-8g for lab testing before deployment, and I've decided not to move forward with Mikrotik at all.
You guys realize you are beta testers, right? What is this RC25 nonsense? If you are on version 25 of a release candidate, and your forum users are having to issue their own test findings on long-list point form, just call it what it is: a beta. They are selling a product that they have known for months isn't functional as documented or advertised, with crippling bugs, and providing extremely little feedback as to when these issues will be resolved.
Where are the recalls? Where are the end user bulletins? Why have the vendors not been instructed to pull these off the shelves? Why is Mikrotik continuing to authorize the sale of a product that they know will be deployed in a enterprise setting, when they are well aware that the product doesn't even work properly? Aren't there some sort of consumer protection laws against this sort of thing?
We aren't talking about some small obscure bugs here. These are major issues. If they released a product with these glaring deficiencies, how can we trust they have implemented the more discrete security measures properly? Perhaps they haven't?
I am very glad I did my due diligence and tested a unit before full deployment. I feel sorry for people who have been sitting on a full inventory of these bricks for months now with no word on when they will even be usable.
gintarasp2
Wed Feb 17, 2021 11:59 am
Until the legal expenses are not greater than recal expenses, there wount be any recal, that is how corporate and reality works. If you want some kind of recal, go to court.
Sucks, Mikrotik seemed to be something else for business and for home, even considered to get certified, but it seems their name means less than money.
How many months device is for sale?
How long not even a warning on device tab in official site or eshop?
nafeasonto
Wed Feb 17, 2021 5:01 pm
I hate to be a dick, but you do realize these aren't business switches/routers/L3 right? I mean at MOST you should only be using Mikrotik in very small business environment, or home lab. I would never use these things at a big business. There are way too many bugs in these things. I.E. this model. There have also been many many bugs in their previous.
But honestly, for as cheap as these are, they work decently well, and Mikrotik doesn't abandon them, and the firmware upgrades are free.
mikronerd
Thu Feb 18, 2021 8:24 am
This is like saying you should be happy with a brand-new but cheap Toyota that can't go as fast as it claims because tires are not inflated, there is no windshield and clutch doesn't work half the time. You can be upfront about software beta status during purchase so people know what to expect. I'm so glad I stumbled upon this forum by mistake before purchasing.
marekm
Thu Feb 18, 2021 1:32 pm
CRS running RouterOS have the ping watchdog feature, but it has been fixed to work properly with VLANs only recently (previously it never got any response and rebooted periodically).
But this device only supports SwOS, probably on some small microcontroller - not sure if it can support the ping watchdog, if it does TCP/IP with simple algorithm (replying to the same IP/MAC it got the request from) this means it can't initiate any communication on its own. I don't understand the reasons for SwOS today, some CPU capable of running full RouterOS should be cheap enough (see the RB931-2nD - slow CPU is OK here, as it only manages the switch and doesn't handle all the traffic).
Just an idea how remote reboot could be added in a reverse-PoE setup - add a simple hardware circuit to monitor the supply voltage (after the logical OR with diodes from PoE-in ports, but before powering the device itself and its PoE-out) and disconnect it with some series P-channel mosfet if detected too high. So if you usually run the setup with 24V PoE from customers, connect a 48V power supply at one customer to reboot without need to visit all other customers at the same time. As an added bonus, you get some overvoltage protection (reboot instead of damage). But of course, before connecting a higher voltage power supply you need to be sure such protection exists in the device where you connect it, so it's still not fool-proof (some other devices might be damaged). But then, any passive PoE is not fool-proof anyway.
nafeasonto
Sun Feb 21, 2021 5:27 pm
Yeah that is exactly what I am saying. So what?
ectoplasmosis
Wed Feb 24, 2021 7:15 pm
IGMP Snooping still broken for me on RC25...
Anyone using IGMP Snooping?
ropeguru
Thu Feb 25, 2021 12:06 am
I have it enabled on a single vlan and do see entries under the igmp tab, but have not tested any further than that.
msimmons
Thu Feb 25, 2021 12:28 am
Can someone post the latest rc?
Users browsing this forum: llag and 4 guests
