janar
SIM slot on wAP LR8 (LoRa) kit
Tue Nov 03, 2020 11:36 am
I found that the Mikrotik wAP LR8 kit (LoRa) has a SIM-slot and according to the specs, it has a modem, but there are no details what kind of connectivity the kit supports. I'd like to know whether it supports 3G and/or 4G and which bands. We plan to use some of the devices in different countries, so we want to know, if and where we can deploy these gateways.
xvo
Re: SIM slot on wAP LR8 (LoRa) kit
Tue Nov 03, 2020 11:44 am
The sim slot is there to be used if you swap LoRa card for a 3G/4G modem card.
The kit is basically a wAP R device + LoRa card, so no modem included, and there is no way to use both (modem and LoRa) at the same time.
janar
Tue Nov 03, 2020 1:16 pm
Understood, thank you very much! We'll look into other options then to get cellular connectivity.
fui86
Sat Nov 21, 2020 1:17 pm
This thing is absurd. There are no datasheets, outside the datasheet on the site where they talk about sim slots. We bought this router now, now we will have to buy an external modem.
Sounds really crazy to me.
SiB
Tue Dec 08, 2020 2:33 am
? The specification not say about LTE MODULE https://mikrotik.com/product/wap_lr8_ki ... ifications
Yes, this device have a SIM slot bcs you can replace mPCIe (1xslot only) LoRa card to other lte unit and have LTE&WiFi*Eth unit.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
At vacation until 15.jan.2021
Users browsing this forum: AvAxxCZ, Bing [Bot], mixig, nickshore, sdtu and 40 guests
