Sun Nov 22, 2020 1:02 am
Thanks for the help. Having the "leaf" machines use the MikroTik as the DNS server seems preferable.
Here is my config (export compact). If there's an even more compact way that I should be using, let me know.
# nov/21/2020 16:55:27 by RouterOS 6.47.3
# software id = E1GF-ZJZ5
# model = RB4011iGS+5HacQ2HnD
# serial number = D1470BF44B0F
add admin-mac=C4:AD:34:DC:87:A1 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="united states" disabled=no distance=indoors frequency=auto frequency-mode=manual-txpower installation=indoor mode=ap-bridge secondary-channel=auto ssid=MikroUnified-5 station-roaming=enabled \
wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=0 band=2ghz-b/g/n channel-width=20/40mhz-XX country="united states" disabled=no distance=indoors frequency=auto frequency-mode=manual-txpower installation=indoor mode=ap-bridge ssid=MikroUnified-2 station-roaming=enabled wireless-protocol=802.11
/interface vrrp
add interface=bridge name=vrrp1
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=Ellerman wpa2-pre-shared-key=Ellerman
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=wlan2
add comment="SilverShark router" interface=ether1 list=WAN
add comment="AT&T Router" interface=ether9 list=WAN
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
add address=192.168.88.2 interface=bridge network=255.255.255.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add disabled=no interface=ether9
set allow-remote-requests=yes servers=208.67.220.220,208.67.222.222
/ip dns static
add address=192.168.88.1 name=router.lan
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add disabled=yes distance=1 gateway=192.168.88.230
/system clock
set time-zone-name=America/Chicago
/system identity
set name=MikroTik112
/system leds
add interface=wlan2 leds=wlan2_signal1-led,wlan2_signal2-led,wlan2_signal3-led,wlan2_signal4-led,wlan2_signal5-led type=wireless-signal-strength
add interface=wlan2 leds=wlan2_tx-led type=interface-transmit
add interface=wlan2 leds=wlan2_rx-led type=interface-receive
/tool mac-server
/tool mac-server mac-winbox
