172.20.xx.xx is not public address, so that would mean no port forwarding for you. Unless you'd have NAT 1:1, but judging by zero packets hitting your rules, you probably don't.
One chance would be if upstream router had public address and working UPnP, and if you'd not insist on using your router as router, but only as transparent bridge/switch. Your devices would then get addresses directly from upstream router and would be able to open ports using UPnP. It's not guaranteed that it would work like this, but maybe it could. Downside is that you wouldn't have isolated LAN as you have now. You can quickly test this, if you connect your gaming device directly to big box on the left instead of router.
How do I export? Through the web version through terminal it did not do anything. I opened winbox app, signed in but see no export option.
It should create file anynameyouwish.rsc which you'll see in Files. In WinBox you need to select New Terminal.
Never mind, I used an online reader.
# nov/22/2020 20:14:51 by RouterOS 6.43.12
# software id = C3K4-41ZX
# model = RBD52G-5HacD2HnD
# serial number = B4A00AE11D6B
add admin-mac=74:4D:28:74:BC:DB auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n disabled=no distance=indoors \
mode=ap-bridge ssid=APARTMENT12_2G wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40mhz-Ce \
disabled=no distance=indoors frequency=5785 mode=ap-bridge ssid=\
APARTMENT12_5G wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input dst-port=22,443 protocol=tcp src-address=\
213.218.229.144/29
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
ipsec-policy=out,none out-interface=ether1 out-interface-list=WAN
add action=dst-nat chain=dstnat comment=ps4 dst-port=3074 in-interface=ether1 \
protocol=udp to-addresses=192.168.88.135
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/system clock
set time-zone-name=Europe/London
/tool mac-server
/tool mac-server mac-winbox
