Gnits
Firewall issue with added VLAN200
Wed Nov 18, 2020 2:43 am
So I am using the older stock configuration on my RB4011.
I have add new VLANs for the IOT stuff and i have one device that i could not get to find its back end service.
When i connected it back to the main network, it started to work.
This is not a ground up configuration.
I know there is junk in this configuration but primarily i want to configure it so that the VLAN 200 can get out to the internet.
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge vlan-filtering=yes
set [ find default-name=ether10 ] poe-out=forced-on
set [ find default-name=sfp-sfpplus1 ] mtu=1600 name=sfp-sfpplus1-downlink
/interface vlan
add interface=bridge name=INT_VLAN1 vlan-id=1
add interface=bridge name=INT_VLAN100 vlan-id=100
add interface=bridge name=INT_VLAN101 vlan-id=101
add interface=bridge name=INT_VLAN200 vlan-id=200
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.0.2-192.168.0.254
add name=dhcp_pool2 ranges=192.168.0.10-192.168.0.254
add name=dhcp_pool3 ranges=192.168.200.10-192.168.200.254
add address-pool=dhcp_pool2 disabled=no interface=INT_VLAN1 name=dhcp1
add address-pool=dhcp_pool3 disabled=no interface=INT_VLAN200 name=dhcp2
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1-downlink
/interface bridge vlan
add bridge=bridge tagged=bridge,sfp-sfpplus1-downlink untagged=ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10 vlan-ids=1
add bridge=bridge tagged=bridge,sfp-sfpplus1-downlink vlan-ids=100
add bridge=bridge tagged=bridge,ether1,sfp-sfpplus1-downlink vlan-ids=200
add bridge=bridge tagged=bridge,sfp-sfpplus1-downlink vlan-ids=101
add comment=defconf interface=INT_VLAN1 list=LAN
add interface=INT_VLAN200 list=LAN
add address=192.168.0.1/24 interface=INT_VLAN1 network=192.168.0.0
add address=192.168.200.1/24 interface=INT_VLAN200 network=192.168.200.0
add address=192.168.101.1/24 interface=INT_VLAN101 network=192.168.101.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.0.0/32 dns-server=75.75.75.75,75.75.75.76 gateway=192.168.0.1 netmask=24
add address=192.168.0.0/24 gateway=192.168.0.1 netmask=24
add address=192.168.200.0/32 dns-server=75.75.75.75,75.75.75.75 gateway=192.168.200.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.0.1 name=router.lan
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip upnp
set enabled=yes
/system clock
set time-zone-name=America/New_York
/system identity
set name=TheWay
/system ntp client
set enabled=yes primary-ntp=107.152.35.167 server-dns-names=0.pool.ntp.org
/system package update
set channel=long-term
/tool graphing interface
add interface=ether1
add interface=ether10
/tool mac-server
/tool mac-server mac-winbox
I do plan to build a configuration from the ground up but right now i am just trying to get something working.
Gnits
Re: Firewall issue with added VLAN200
Wed Nov 18, 2020 12:59 pm
Additional information:]
I connected my Echo Show 5 to this new IOT network and it can establish a proper connection to the wifi and stay there. However, no services function.
So, I am pretty confident that I have an issue with either the dhcp scope or the firewall.
sindy
Re: Firewall issue with added VLAN200  [SOLVED]
Wed Nov 18, 2020 1:20 pm
formatted code
There should be /24.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Gnits
Thu Nov 19, 2020 4:35 am
formatted code
What is interesting is why i need /24 when there is a netmask field for 24 as well.
mkx
Thu Nov 19, 2020 10:05 am
The address part of the config stanza actually tells ROS which IP interface the whole stanza refers to (and then DHCP server uses correct network definition for DHCP requests coming through that interface). There fore the address part should match exactly the address as set in /ip address. The rest of properties (netmask, list of DNS servers, ...) are sent to DHCP client ...
In ROS it is possible to set some things which are not exactly usual. Such as having several interfaces configured with same IP address but with different network addresses (and different netmasks)...
BR,
Metod
Users browsing this forum: Bing [Bot], nescafe2002, noexp, sid5632 and 164 guests
