rplant
Feature Request: Wifi MPSK
Thu Nov 19, 2020 12:18 pm
Can Some implementation of Multiple Pre Shared Key be added (good if in V6.x as well),
I assume (hope) it can be done in wpa/wpa2.
My use case would be one SSID and a few different groups possibly pushed to different vlans depending on the password used.
Without requiring a radius server, or EAP authentication, (Though Capsman might make management of this easier).
For easy connectivity to assorted devices, which can be in their own groups.
bpwl
Re: Feature Request: Wifi MPSK
Thu Nov 19, 2020 12:34 pm
Can probably be done already with "Access List"
private-pre-shared-key (string; Default: "") Used in WPA PSK mode.
rplant
Sat Nov 21, 2020 12:17 am
Cool,
Thank you, I will try that.
I was hoping to try it yesterday, but that didn't quite happen.
Finally, after a bit of effort I got it to work ok.
I initially wanted to use the password as a selector which didn't work.
After a bit of thought I realized that this was probably not possible.
And actually for the use case I want it for, selecting by Mac Address will be ok.
Users browsing this forum: No registered users and 12 guests
