n21roadie
Reduced noise floor frequencies when using R11e 5HacD + M11G miniPCIe
Thu Nov 19, 2020 6:32 pm
I did a frequency usage and noticed 5270, 5550, 5690, 5775, 5820 all have noise floor of exactly -60 but frequencies above and below is -100 or -90+ ?
marcin21
Re: Reduced noise floor
Thu Nov 19, 2020 7:56 pm
can't confirm. but we are over thousand km apart.
omarraza
Thu Nov 19, 2020 10:59 pm
maybe interference was occur if you want to know which frequency is good for you choose the highest one for example -100 is very good than -90 an so on.
bpwl
Fri Nov 20, 2020 1:39 am
What is noise in wifi? Noise is a RF signal that cannot be decoded as 802.11. NOISE is any signal (interference) that is not WiFi traffic such as cordless phones, microwaves, radar, etc.
This means there is a transmitter using that freq, but is not using one of the 802.11 understood encodings.
NV2 or Nstreme would have been recognized by a Mikrotik device. Others do not understand that signal.
A camera or alarm system may use this, any IOT device, a drone, home automation .... just anything that is sending not 802.11 compliant signals.
( Would 802.11ac recognize all 801.11ax ??? Normally 802.11 is backward compatible.)
Does Snooper (with "Receive errors " allowed) reveal any MAC address?
n21roadie
Fri Nov 20, 2020 3:13 pm
I just left the frequency usage running for a hour and so far 20 frequencies are reading a noise floor of -60, I am just wondering if this noise floor is from onsite AP's or PtP's or both?
The list of -60 noise floor frequencies varies from 2 to 6 and max of 8 at any given time!
bpwl
Sat Nov 21, 2020 12:29 am
Check with "Snooper" (that other tool besides Freq Usage) , and if used with "Multiple channels" and "Receive errors" enabled under "Settings", it might even show more 'sources' of the signal.
n21roadie
Tue Nov 24, 2020 1:30 pm
Tried scan with "Snooper" but didn't get any extra information!
I also did a scan from a CPE on the same mast pointing in the same direction and it did NOT pickup any noise-floor frequencies with -60 ?
My conclusion is that maybe one of the pigtails on the RouterBOARD R11e 5HacD 802.11ac is NOT seated properly but this will need to be taken down to be checked?
n21roadie
Mon Dec 07, 2020 6:30 pm
Update - just discovered that
(1) 3 X RF Elements HG3-TP-A60 60°Horns using Mikrotik RMB11G + M11G miniPCIe, at one site have Frequency usage reporting a noise floor of -60 at certain frequencies ,
(2) At another site 1 X RF Elements HG3-TP-A60 60°Horn using Mikrotik RMB11G + M11G miniPCIe is also reporting noise floor of -60 at certain frequencies,
I would like to ask if anyone else with similar board + radio card have the same issue using RF Elements HG3-TP-A60 60°Horn
n21roadie
Re: Reduced noise floor - RF Elements HG3-TP-A60 60°Horn
Tue Dec 08, 2020 8:28 pm
Update - The -60dBm noise floor is appearing on all RF Elements Antenna's 60° + 30° + SEC-CC-5-17, at this stage I am thinking that the issue maybe a Mikrotik ROS software glitch because the -60dBm is appearing on live production devices and they are working flawlessly since put up in the spring this year,
I did some frequency tests
(1) 20Mhz scan : No -60dBm,
(2) 40Mhz scan: just 1 result -60dBm
(3) 80Mhz scan : 2 results -60dBm,
Must contact Mikrotik Support to comment on this?
Users browsing this forum: 0ldy0ne and 80 guests
