cascom
SXT LTE6 with Wireguard config help
Thu Nov 19, 2020 6:54 pm
I have put RouterOS 7.1 beta on my MikroTik SXT LTE6 so I can use the Wireguard function.
I purchased a client subscription for Wireguard from OVPN https://www.ovpn.com/en and generated keys/config/etc.
Below is the config file but unable to enter all fields as some are invalid, I also don't know how to finalize the interface or firewall to make it all active:
[Interface]
PrivateKey = XXXXXXXXXXXXXXXO3Gqhg7fiQOeGMqMWl2Ku1WF1O2Y=
Address = xxx.16.63.202/32, xxxx:0000:xxxx:cafe:xxxx:1111:xxxx:5579/128 (What do these address represent? Do they need to change or match my router?)
DNS = xxx.227.67.134, xxx.165.9.158
[Peer]
PublicKey = XXXXXXXXXXXXKbkxMGuN98F6N1BzgJnSzGseEgG7t3o=
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = xxxxx.prd.dallas.ovpn.com:9929 (This address will not be accepted so OVPN tech gave me xxx.120.138.194:9929 but still only works if I remove the :9929)
Sob
Re: SXT LTE6 with Wireguard config help
Thu Nov 19, 2020 8:52 pm
You're too quick, it's beta for a reason. Both lack of support for hostnames and inability to set port in GUI are known problems. If you want to set port, you have to do it using command line.
And those addresses you're not sure about is what you get from VPN provider, they should be assigned to wireguard interface.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
Users browsing this forum: No registered users and 11 guests
