much19278
LHG LTE -(R11e-LTE-Us) not showing RSRP level
Fri Nov 20, 2020 9:50 pm
Hi there,
I got one question about R11e-LTE-Us. There is no RSRP information when R11e-LTE connects to LTE. Only RSRQ info available. Also, the RSRP info/graph is not available via Winbox.
[admin@MikroTik] > /interface lte info
number: lte1
pin-status: ok
registration-status: registered
functionality: full
manufacturer: MikroTik
model: R11e-LTE-US
revision: MPSS: R11eL_v16.02.183961 APSS: R11eL_v05.03.183961
CUSTAPP:
current-operator: ROGERS ROGERS
lac: 184
current-cellid: 8693251
enb-id: 33958
sector-id: 3
access-technology: Evolved 3G (LTE)
session-uptime: 1h40m10s
imei: 3*******************
imsi: 302720611555***
uicc: 89302720523095076***
rsrq: -8dB
The previous similar Mikrotik showed RSRP just fine (same provider, same SIM card, etc..)
How I can get this RSRP info?
much19278
Re: LHG LTE -(R11e-LTE-Us) not showing RSRP level
Sat Nov 21, 2020 5:26 pm
Any suggestions? Still want to see RSRP info there )
krafg
Long time Member
Long time Member
Sat Nov 21, 2020 8:21 pm
RouterOS and firmware version?
Regards.
If you want to know my network, you can find it here.
SiB
Sun Nov 22, 2020 1:40 am
And what WinBox version too !
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I back from vacation and try answer at LTE posts
much19278
Sun Nov 22, 2020 2:28 am
Router OS - MikroTik RouterOS 6.45.9
Firmware - R11e-LTE-US MPSS: R11eL_v16.02.183961 APSS: R11eL_v05.03.183961 CUSTAPP:
WinBox (64bit) 3.27
Also, I got the error message when I tried to upgrade the firmware:
[admin@MikroTik] >> /interface lte firmware-upgrade lte1 upgrade=no ;
failure: Device does not support this feature!
krafg
Long time Member
Long time Member
Re: LHG LTE -(R11e-LTE-Us) not showing RSRP level  [SOLVED]
Sun Nov 22, 2020 3:13 pm
Update to the last RouterOS version and under System -> RouterBOARD also update the firmware.
Regards.
much19278
Sun Nov 22, 2020 5:28 pm
Yes, the problem was solved with RouterOS update.
Thank you!
SiB
Tue Dec 08, 2020 2:26 am
Your r11e-LTE-US module have latest firmware, what I know.
Please upgrade your RouterOS to stable 4.47.8 from System > Packages menu
EDIT / Solved :) Browser show me cache and my answer is to late :)
Users browsing this forum: No registered users and 50 guests
