Hello Tik community,
I would be glad if you can give me hints.
Fairly simple home setup. I have HEX S (RB760iGS) as a router and a HAP ac2 (RBD52G-5HacD2HnD) as AP.
What I would like to accomplish is having 2 vlans, 1 COMMON trusted( all trusted computers and equipment) and a GUEST network.
I would like to set the following:
ISP network cable on WAN (Ether1) of HEX S. HEX S port 5 to HAP port1 trunk. Trunk port would include Trusted and Guest VLANs.
The main reason I would prefer VLAN over subnet is that I need to connect GUEST switch to my HAP AP and provide guest WiFi as well.
So the question is: provided that I need to trunk my COMMON network, shall I leave it on native VLAN1 or it is better idea to change it to VLAN5 (for example)? I have a feeling that my HEX S is having special attitude toward VLAN1 and creating some rules that are not visible. Any advice or examples are welcome.
