eclipsical
BGP Route distinguishers reversed
Thu Nov 26, 2020 7:05 am
Relatively new to ROS however have a working MPLS configuration using OSPF + iBGP. Am doing some testing with l3vpns and have noticed something weird - when I do /routing bgp vpnv4-route print the output displays all l3vpn/vpnv4 routes and their distinguishers known in my MPLS network, but they are in reverse. For example:
Actual route distinguisher:
1.2.3.4:100
Route distinguisher as learned by Mikrotik:
4.3.2.1:100
Similarly the route distinguisher for VRFs that are advertised by the Mikrotik to our other core devices is reversed.
Is this expected behaviour? Have I got something wrong with my configuration? I am not doing any mangle rules or anything fancy other than MPLS/LDP, OSPF, BGP.
Cheers
eclipsical
Re: BGP Route distinguishers reversed
Mon Dec 07, 2020 11:33 pm
Update: I have confirmed with Mikrotik this is a known bug with ROS 6.x. This is hindering our plans to deploy the CCR units.
My next question is if anyone can think of a workaround for the issue, chasing something as low-maintenance as possible as we continually add new VRFs across the network and don't really want to be manually mangling packets for every new VRF just so that it works on the Tik.
Cheers.
mrz
Tue Dec 08, 2020 2:49 pm
It is safe to confirm that this problem will be solved in next v6.48beta version.
IPANetEngineer
Trainer
Trainer
Thu Dec 10, 2020 2:24 pm
I wrote a blog article on this issue and a workaround when doing VPNv4 between MikroTik and Juniper.
https://stubarea51.net/2020/01/22/junip ... 4-interop/
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
eclipsical
Sun Dec 13, 2020 11:41 pm
Thank you very much.
Users browsing this forum: No registered users and 26 guests
