kolorasta
which is the best config to bridge two networks with a p2p l
Fri Jul 06, 2007 8:19 pm
i want to make bridge 2 networks with a p2p link. Which is the best config?
i'm using the example that's in the wiki, but i want to know if there is a better way or is this the best way?
i have only one minipci in each point. I say that because i have read that you can make mice links with two ratios in each point.
i can see also in the config that there are differents bands to work with, 5Ghz, 5Ghz Turbo, 5Ghz-10Mhz, 5Ghz-5Mhz. where can i find some info about this?
Any suggestions?
sokolov
Re: which is the best config to bridge two networks with a p2p l
Thu Jul 12, 2007 1:17 am
better way is to route traffic between them.
Zarko
SkopjeWirelessNetwork
Macedonia
serthan
Thu Jul 19, 2007 11:49 am
i realy wonder that. i am trying to link 2 network, what a fulish Board that i ever seen :)
working hard if i found the config will share with you.
Best Regard
kolorasta
Thu Jul 19, 2007 2:57 pm
thanks serthan
Users browsing this forum: Google [Bot] and 29 guests
