Chiara
Fail Variable declaration sintax from manual
Fri Dec 04, 2020 4:34 pm
If i copy and paste this code on a terminal of CCR1009 with routeros 6.47.7 it fails, but on the manual it says it it the correct sintax https://wiki.mikrotik.com/wiki/Manual:S ... #Variables:
:local myVar;
:set myVar "my value";
:put $myVar;
log info $myVar
this is the output from the terminal:
admin@Router] > :local myVar;
[admin@Router] > :set myVar "my value";
syntax error (line 1 column 6)
[admin@Router] > :put $myVar;
What is wrong here, why can't I set my value to myvar?
msatter
Re: Fail Variable declaration sintax from manual
Fri Dec 04, 2020 4:39 pm
:set $myVar "my value";
Loving my freedom and so, no Twitter, no Facebook/Instagram/WhatsApp, no Apple and no Google/Alphabet, no Amazon/Cloudfront/AWS.
Running:
RouterOS 6.49Beta / Winbox 3.27 64bits
Chiara
Fri Dec 04, 2020 5:03 pm
Thank you, you've saved "half" of my day, hope mikrotik will fix it also in the wiki.
Now the var can be set, but next row :put alway is empty.
mrz
Fri Dec 04, 2020 5:53 pm
local variable lives only inside scope, and each command line is in its own scope.
Either put whole script in curly braces or use global variable
and :set $var value does not solve the actual problem either.
Chiara
Fri Dec 04, 2020 6:02 pm
Thank you, this way all seems to work:
 [ :set $myVar "my value"; log info $myVar ]
eworm
Forum Veteran
Forum Veteran
Sat Dec 19, 2020 12:49 am
You should use curly brackets, not square brackets. So correct code:
{ :local myVar; :set myVar "my value"; :log info $myVar; }
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Jotne
Sun Dec 20, 2020 5:14 pm
Or
  :local myVar
  :set $myVar "Some data"
  :put $myVar
  :log info $myVar
Both :set myVar "my value" and :set $myVar "my value" does work fine.
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
Users browsing this forum: No registered users and 36 guests
