hrz
per IP bandwidth log
Thu Jul 12, 2007 7:09 pm
i'm wondering if i can store per IP bandwidth log, and then passing the data to web server.. and let the web server do the graphing.... because there's some IP host doesnt have snmp agent...
thx for advice :D
edzix
Re: per IP bandwidth log
Fri Jul 20, 2007 5:04 pm
use RADIUS authentication to achieve this, the data is stored on the server in a very obvious form (DB), so there wouldn't be any problems to do graphs..
Otherwise you should make magle rules for each IP, SSH to the router from some Linux based machine, read the counter for each rule etc. But there will be problems with counters after router reboot and there will be no possibility to do session based graphing.
Edgars
Users browsing this forum: No registered users and 25 guests
