Black2vs2
Force users to swap to 5Ghz
Sun Jan 03, 2021 9:30 pm
Hey,
Probably a noob question, but is there a way to force the wireless users near the access point to swap from 2.4GHz to 5GHz?
Thanks in advance
anuser
Long time Member
Long time Member
Re: Force users to swap to 5Ghz
Sun Jan 03, 2021 10:30 pm
Lower the TX power for 2.4GHz, i.e. set higher antenne gain.
Black2vs2
Mon Jan 04, 2021 12:31 am
Thank you, is there also a way to do it on a cap through the capsman of the routerboard?
erlinden
Long time Member
Long time Member
Mon Jan 04, 2021 9:26 am
There is a TX Power setting in CAPsMAN.
First the problem, then the solution
whatever
Mon Jan 04, 2021 9:59 pm
If you don't want clients on 2.4 GHz you could disable the 2.4 GHz radio :).
Lowering tx power is a good way to encourage the client to use the other network, but the AP cannot force the client to do anything.
BartoszP
Mon Jan 04, 2021 10:03 pm
For CAPSMAN make access list which kicks off form 2.4GHz if signal is too low.
Real admins use real keyboards.
To quote or not to quote, there is the topic: viewtopic.php?f=2&t=168474
Users browsing this forum: Bing [Bot], Google [Bot] and 48 guests
