fs89
Problem in the menu "Bridge" and "PPP" after Upgrade to 6.48
Mon Jan 11, 2021 10:10 am
Hey@ALL
After upgrading to the version 6.48, I cannot create a new connection in the menu "bridge" or "ppp".
The URL appears, but the web interface remains empty:
Example:
- http://%IP%/webfig/#Bridge.Bridge.new
- http://%IP%/webfig/#PPP.Interface.new.OVPN_Client
Thx for your help and feedback
gld22
Re: Problem in the menu "Bridge" and "PPP" after Upgrade to 6.48
Thu Feb 04, 2021 2:37 pm
I've found the exact same problem after upgrading to Version 6.48. I also had 2 established pptp clients accessing a VPN account, which following the update stopped working and wouldn't connect. I managed to create another pptp client via the terminal but this, like the 2 previously working ones, seemed to get stuck at 'connecting' and was 'unreachable.
Any help or feedback much appreciated.
thanks
fs89
Thu Apr 15, 2021 1:16 pm
FIXED with Version 6.48.2 !
anav
Fri Apr 16, 2021 1:49 am
I am confused, why would you use PPP on a bridge?
I though PPP was basically another word for pppoe and thus a WAN issue and we don't typically connect Wans to bridges??
Or
Should I have thought of PPP in the sense of that old technology used for VPNs, which is now considered unsafe and shouldn't be used, in which case MT should remove it as an option to use ;-PPP (sorry couldnt resist)
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Users browsing this forum: abdurrazaqa, Borizo and 40 guests
