alohabob
Capsman - config to keep cap up when capsman connection lost
Tue Jan 12, 2021 7:30 pm
I am using capsman in datacenter with mAP in a remote location. Works perfectly. How can I configure the cap to remain operational when connectivity to the capsman is lost for an extended period. (local forwarding is enabled) Thank you.
johnb175
Re: Capsman - config to keep cap up when capsman connection lost
Thu Jan 14, 2021 11:52 pm
Yes, I would like to know this info also.
quackyo
Fri Jan 15, 2021 10:56 am
I'm pretty sure you can't.
sindy
Fri Jan 15, 2021 11:13 am
Currently, a CAP cannot run when its connection to CAPsMAN breaks, dot.
The maximum you can do is to enable a local CAPsMAN on the mAP and synchronize its configuration from the big one using a script, so if you do any changes at the big one, you don't need to copy them to the mAP manually.
Don't write novels, post /export hide-sensitive file=x. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: Andre81, DDG117, Google [Bot], sindy and 182 guests
