TheLterlaus
system,error,critical System rebooted because of kernel fail
Tue Jul 17, 2007 3:33 pm
system,error,critical System rebooted because of kernel failure, on RB532 without wireless cards!!!!
Help :(
normis
Re: system,error,critical System rebooted because of kernel fail
Tue Jul 17, 2007 3:44 pm
you can try to reinstall the OS with Netinstall.
TheLterlaus
Tue Jul 17, 2007 4:29 pm
I tried 2.9.26 and 2.9.37 versions, still the same
TheLterlaus
Tue Jul 17, 2007 4:32 pm
i tried even RB miniROUTER, stil the same problem
CPU problem?
balimore
Forum Veteran
Forum Veteran
Tue Jul 17, 2007 4:33 pm
yes this rigth suggestion
regards
Hasbullah.com
mrz
Tue Jul 17, 2007 5:01 pm
and use the latest version (2.9.44 currently )
TheLterlaus
Wed Jul 18, 2007 9:45 am
is it any god?
normis
Wed Jul 18, 2007 10:01 am
YES! Also please try to upgrade the BIOS Loader.
download it from: http://routerboard.com/rb500.html
then use the XMODEM feature in Hyperterminal to send the file to the router. Quote:
The boot loader is needed to initialize all the hardware and boot the system up. Newer loader versions might
have support for more hardware, so it's generally a good idea to upgrade the loader once a newer version is
available. You can upgrade the loader through the onboard serial port using XModem protocol (programs
available for all major OSs). For example, you can use HyperTerminal for Windows or Minicom for Linux to
upload the boot loader. Alternatively if you have a DHCP/BOOTP and TFTP servers available, you can specify
the loader image as a boot image and choose the bios upgrade over ethernet option in the boot loader
configuration menu. The loader will get the image from the TFTP server and upgrade itself. The most current
loader image is available for download on http://www.routerboard.com.
The boot loader upgrading is supported also from MikroTik RouterOS. The procedure is described in the
MikroTik RouterOS manual.
Should the upgrade fail, you may try loading secondary boot loader, by turning the board on while the S1
button is pressed. If that works, you should try upgrading the loader again.
el berto
Tue Nov 11, 2008 9:53 am
I have the same problem on RB112, even before and after upgraded RouterOS. The actual is 3.11.
How can I do that? (I have the radio in a remote station, so I can access it only through radio.)
Users browsing this forum: Google [Bot] and 49 guests
