usovalx5
RSTP stops working after update to 2.12
Mon Jan 18, 2021 10:22 pm
I have strange issue after updating SWOS to 2.12, where RSTP stops working and will switch ports to discarding.
I have first hit this issue back right after release of 2.12, but didn't have time to debug and just rolled it back.
So now I have updated only one of the switches, and should be able to investigate it in more detail.
Here's my current setup:
root - HAP ac2
sw1 - plugged into HAP ac2 (RB260GSP, swos 2.11)
sw2 - edge switch connected to sw1 (RB260GS, swos 2.12)
If I enable RSTP on the ports connecting SW1 and SW2 - it will detect as:
* on SW1: role: designated, type: point-to-point (instead of edge), state: discarding (periodically switches to forwarding and then back to discarding).
* on SW2: role: designated, type: edge (instead of root), state: forwarding
Port connecting both switches is set up as trunk port, settings are (same on both SW1 and SW2):
* VLAN tab: vlan mode=strict , receive=only tagged, default id=1, force id=off, egress vlan header=leave as is
* VLANs tab: IVL=on, IGMP snooping=off, mode=leave as is
On the system tab, "Allow from vlan" is set to management VLAN.
What can be interfering with RSTP here?
If I remember correctly, when I also upgraded SW1, it had similar issues with RSTP on the trunk port between the switch and HAP AC2 router, but I'm less confident about details there.
Users browsing this forum: No registered users and 6 guests
