Is there a way of fault finding with ospf error "Discarding packet: locally originated src address = XX.XXX.XX.XX"
this occurs every few mins?
et!Other common causes:
* Multiple neighbors has the same router-id - Checked OSPF Neighbours and no duplicates!
* Actual layer2 loop in the network - I have been adding extra L2 to the network and this maybe the cause ?
* If switch is used in between, bad switch may acts as hub, sending multicast packet back to the port the packet was received from. - The switch has been active for many months before this issue, so I don't think it's the problem!
