alitalia
How to send file in VPN
Thu Jul 19, 2007 12:13 pm
dear all,
im confuse to send file in vpn,
im new using mikroitik , i've create vpn over intranet so im using two server mikrotik, how can i transfer file between one vpn to another vpn ? my vpn conneting and ping each other.
thaks :shock:
broken
Re: How to send file in VPN
Thu Jul 19, 2007 12:48 pm
Use something based on TCP/IP to transfer file. There is a thousands of programs such like this : http://www.whitsoftdev.com/ssft/.
normis
Thu Jul 19, 2007 3:57 pm
or simple windows file sharing
balimore
Forum Veteran
Forum Veteran
Thu Jul 19, 2007 4:21 pm
can explain detail please,...my best friend :wink:
myVPN can't get with file sharring to make map, ala windows.
i had establised my VPN over dialup to my noc with fo connection..
thanks
Hasbullah.com
Borage
Thu Jul 19, 2007 5:12 pm
Both computers must reside on the same network (subnet), or else you need either a wins server, a properly configured name server (DNS), or you need to edit lmhosts (hosts).
normis
Fri Jul 20, 2007 9:12 am
well when you make a VPN, you tunnel into another network. After you are on the same network, windows file sharing works.
balimore
Forum Veteran
Forum Veteran
Fri Jul 20, 2007 1:34 pm
sorry, @normis [best friend]
i never success to make file sharing over tunnel.
can you explain detail please....
very2 interesting
normally my tunnel control any local routers or will use RDP for, but never success about file sharing
thanks your time for.
regards
Hasbullah.com
Borage
Fri Jul 20, 2007 3:07 pm
You never succeeded because you didn't read the fine manual. :roll:
http://www.microsoft.com/technet/prodte ... x?mfr=true
balimore
Forum Veteran
Forum Veteran
Fri Jul 20, 2007 3:19 pm
ok fren
thanks your point for, later i will read that page.
regards
Hasbullah.com
balimore
Forum Veteran
Forum Veteran
Fri Jul 20, 2007 5:04 pm
Thanks Borage and all
From now my VPN, working great
this simple screen report, you can see Z:\ drive is mapped one and this action from Dialup modem to my NOC over FO
again nices and thanks for your point. [on screen still transfer any files, just demo]
Best regards
Hasbullah.com
Users browsing this forum: glat, Spaz and 110 guests
