erkexzcx
Hairpin NAT - the easy way
Sun Feb 07, 2021 4:54 pm
Decided to write a simple guide on Hairpin NAT, because quite a lot of users struggle to understand how to set it up.
I am not a networking professional and I am open to any criticism on how to implement it in a better way.
Official wiki page by Mikrotik regarding Hairpin NAT: https://wiki.mikrotik.com/wiki/Hairpin_NAT
Step 1 - add LANs to "address-list"
List all your LANs like this:
/ip firewall address-list add address=192.168.10.0/24 comment=Management list=LANs
/ip firewall address-list add address=192.168.11.0/24 comment=Work list=LANs
/ip firewall address-list add address=192.168.12.0/24 comment=Security list=LANs
/ip firewall address-list add address=192.168.13.0/24 comment=Home list=LANs
/ip firewall address-list add address=192.168.14.0/24 comment=Guest list=LANs
Step 2 - add WANs to "address-list"
If you have a single dynamic IP - add your "/ip cloud" domain to address-list named "WANs" and Mikrotik will automatically resolve it to IP. Using custom script in "/ip dhcp-client" is another option in order to keep WAN IP address in address-list updated.
If you have multiple WANs - it gets a little more complicated. I've written a simple solution for multiple dynamic WANs here: viewtopic.php?f=9&t=171049#p836067
List all your WANs like this:
/ip firewall address-list add address=123.123.123.123 list=WANs
Step 3 - mark connections from LANs to WANs
Use this rule:
/ip firewall mangle add action=mark-connection chain=prerouting comment="Mark connections for hairpin NAT" dst-address-list=WANs new-connection-mark="Hairpin NAT" passthrough=yes src-address-list=LANs
Step 4 - perform Hairpin NAT
Use this rule, placed before any other NAT rule:
/ip firewall nat add action=masquerade chain=srcnat comment="Hairpin NAT" connection-mark="Hairpin NAT" place-before=0
Step 5 - port forwarding
Setup port-forwarding like this:
/ip firewall nat add action=dst-nat chain=dstnat comment="Port forward: something1" dst-address-list=WANs dst-port=5001 protocol=tcp to-addresses=192.168.0.8 to-ports=5001
/ip firewall nat add action=dst-nat chain=dstnat comment="Port forward: something2" dst-address-list=WANs dst-port=5002 protocol=tcp to-addresses=192.168.0.9 to-ports=5002
Halfeez92
Re: Hairpin NAT - the easy way
Sun Feb 21, 2021 7:33 pm
Thanks for the tutorial, but I have done it on different approach, so I don't need to do hairpin nat. My config is like this:
/ip firewall nat add action=dst-nat chain=dstnat comment="Port forward" dst-port=5001 protocol=tcp dst-address-type=local dst-address-list=!router to-addresses=192.168.0.8 to-ports=5001
Whereas the address list for "router" is your router gateway addresses on /ip address. With this setup you don't need to have a hairpin nat rule.
anav
Thu Feb 25, 2021 7:39 pm
There are several ways to handle hairpin nat.
Understand hairpin nat is a situation where the admin wants local users, ON THE SAMELAN subnet as the server, to access the server NOT by lanip address but by the routers public IP address.
An easy work around for this problem (often called loopback on other devices) is simply to put the server on its own subnet. {solved}.
The regular rules for destination NAT will work fine.
DarkNate
Tue Jul 27, 2021 2:39 pm
Why have convoluted config like that?
A single NAT rule is capable of doing hairpin NAT efficiently.
rextended
Tue Jul 27, 2021 2:54 pm
I prefer to intercept all DNS request (or use for default the DNS on the Routerboard) for "www.mypublicinternalserver.net" and reply with directly the internal IP.
Also where direct public IP are used, are changed with private IP.
Done, no NAT problem.
My network, my rules...
anav
Thu Jul 29, 2021 5:33 pm
No so simple darknate.
Its true that one needs to add a single sourcenat rule as your link describes at the top of the source nat chain,
but the not necessarily so for the associated DSTNAT rule.
The dstnat rule depends upon if the ISP connection is a static WANIP or a dynamic WANIP.
Quite correct if its a static WANIP then only the source nat rule is required, but in a dynamic WAN IP scenario there are at least 3 options..
And thus I prefer this link to point readers too. (no bias)
viewtopic.php?f=13&t=175064&p=856786&hi ... at#p856786
What I would like rextended to do is expand upon his method as its not so obvious for us mere peons learning RoS!
rextended
Thu Jul 29, 2021 5:50 pm
For those examples please ignore grammar errors and any consideration about security or limitating access.
Example 1)
Internal webserver is reachable worldwide from www.vattelappesca.rex
all the Public DNS resolve www.vattelappesca.rex to Public IP 123.45.67.89
That IP is not on RouterBOARD directly but is >INSIDE< one of RouterBOARD internal network.
NAT is not needed because are Public IP.
Reachable from Inside any local network without NAT: YES
No NAT required for that.
Example 2)
that IP is one IP on RouterBOARD and is redirected by dst-nat to one of RouterBOARD internal network (for example 192.168.68.92).
dst-NAT is required because is a Private IP and is not routerd on public network.
Reachable from Inside any local network using DNS or Public IP without src-NAT: NO,
is not the time to explain again why not, but src-NAT is needed for make webserver reply on correct way to the device.
Reachable from Inside any local network using ONLY Private IP without NAT: YES.
Example 3)
that IP is one IP on RouterBOARD and are redirected by dst-nat to one of RouterBOARD internal network (for example 192.168.68.92).
BUT
Internal webserver is reachable locally from www.vattelappesca.rex without NAT
because on LOCAL DNS the domain resolve to 192.168.68.92
If is my network, already I set on all machine with DHCP, or manually, all DNS to be solved directly from RouterBOARD,
and adding static regex dns entry "(^|www\.)vattelappesca\.rex$" ==> 192.168.68.92 solve the problem without using NAT
And SSL certificate do not give any error because check the domain, not the IP
anav
Thu Jul 29, 2021 6:29 pm
Ahh you twigged a memory, there was a way of directing requesting internally via DNS to the server and not using NAT. Sorry to be so foggy.
So there is a fourth method so lets focus on reality situation 2. Public IP, private IP server using DNS method............
THe only thing I could find on my search was this.....
There's no complexity with hairpinNAT, it's just one rule. Set it and forget it. It's extremely convenient. You have internal server and you make it accessible to whole world (using dstnat) as somehostname.domain.tld. By default, it works for everyone except you (when you're in same LAN).
So you can either connect directly to internal address, or in case the protocol cares about hostname (e.g. http), you need to add some dns override, either to router or local hosts file. Hosts file is bad, because you'll need to change it every time you move between outside and inside. Static dns entry on router is slightly better, but it works only when device uses router as resolver. Have a device with hardcoded outside dns and it doesn't work again. Add another hostname to your server and you need to change everything again. Remove hostname from server, put it somewhere else and watch how everything in your LAN fails, because you forget to remove static entry from router and it's still pointing to old internal server.
Or set universal hairpinNAT rule and never worry about any of this again.
rextended
Thu Jul 29, 2021 6:40 pm
No... simply open, copy, modify, save, the single DNS static rule.
What is the ploblem, I open the router and delete the static entry,
I do not pass all the day moving hosts.... :P
If a host disappears from the network, it is no longer on my management, so it doesn't matter that the internal PCs reach it anymore...
...but it works only when device uses router as resolver...
...Have a device with hardcoded outside dns and it doesn't work again...
Simply on NAT I intercept all DNS query not directed on Local Router and redirect it on RouterOS DNS...
Also this make connections work if DNS are set manually wrong...
anav
Wed Aug 11, 2021 4:52 pm
To summarize and to make more plain for novice users.......
One doesnt change current DHCP server DNS settings (typically they are the gateway of each subnet for example - as you stated solved from routerboard,
what this means is that will not work if you have direct EXTERNAL DNS settings under DHCP server such as 1.1.1.1 or 8.8.8.8 ??
What is not clear is if one in IP DNS, allows remote requests
and then enters in some the Servers box (the one above dynamic servers). Does that also negate this method???
One makes a a static REGEX dns entry, whatever that means. It initially soundedl like one had to enter this in an IP firewall layer 7 protocol thing, but
it appears Regexp also is found in the IP DNS settings under the Static Button selection. so assuming here is where the rule/text is entered
The rule seems to state if a user types in the address shown (dyndns name) it should resolve to the private IP of the server via DNS (vice NAT).
Then some noise about ssl security, but not clear how this is used or invoked??
Clear up limitations on what other DNS setting can and cannot be made
Clear up location of rule/text to be posted
Clear up ssl security bit
rextended
Wed Aug 11, 2021 5:14 pm
No layer7, hairpin NAT or other frills.
Simply do only this, for example RouterBOARD 192.168.88.1 , local www.vattelappesca.rex server 192.168.88.68...
This DOES NOT BROKE SSL certificate
/ip dns static
add address=192.168.88.68 regexp="(^|www\\.)vattelappesca\\.rex\$" ttl=5m
add chain=dstnat src-address=!192.168.88.1 dst-address=!192.168.88.1 dst-port=53 protocol=udp action=dst-nat to-addresses=192.168.88.1
add chain=dstnat src-address=!192.168.88.1 dst-address=!192.168.88.1 dst-port=53 protocol=tcp action=dst-nat to-addresses=192.168.88.1
this intercept all DNS request except for request started from RouterBOARD or already directed to RouterBOARD
(this NAT configuration also allows you to run any machine that has (at least one) a wrong DNS in the settings)
anav
Thu Aug 12, 2021 1:17 am
Okay understood,
but you havent cleared up the limitations required for this to work on
DHCP Server settings for each subnet if applicable?
Alllow remote DNS box
DNS servers entry (above dynamic servers)
rextended
Thu Aug 12, 2021 1:33 am
1) DHCP Server settings for each subnet if applicable?
2) Alllow remote DNS box
3) DNS servers entry (above dynamic servers)
1) You can add address list instead as single IP excluded from interceptation, both as src and dst
2) pihole for example? Yes, you still can add it and resolve inside pihole the DNS with local IP
3) please explain, I not understand
You mean DNS dynamic or staic defined on /ip dns? This DNS use input/output chain, not forward, and are untouched.
The static DNS have precedence over any other way the RouterBOARD can obtain DNS.
(first static, then static with regex, then the others)
anav
Thu Aug 12, 2021 4:39 am
Thanks, that answers it!
So If I had this scenario.
add address=192.168.0.0/24 dns-server=1.1.1.1 gateway=192.168.0.1
IP static DNS 192.168.0.1
The router would not use 1.1.1.1 for DNS queries from 192.168.0.1 subnet???
rextended
Thu Aug 12, 2021 10:39 am
On that way
You provide the DNS 1.1.1.1 "suggested" to the internal DHCP client, which obtains it automatically, instead of setting it manually,
if it does not use one hard-coded inside
(example of hard-coded is android than use 8.8.8.8 and 8.8.4.4 instead of the DNS provided from the DHCP,
only if you block 8.8.8.8 and 8.8.4.4 use the DNS provided from the DHCP)
If you omit the DNS on DHCP network parameters, if "allowed remote request" on /ip dhcp is checked the DHCP server suggest the routerboard IP (192.168.0.1)
else suggest the DNS presents on /ip dns servers
The only way to make routerboard use the 1.1.1.1 is to put it on /ip dns servers, as only DNS server
It is not possible to select which DNS the RouterBOARD should use for each subnet
anav
Thu Aug 12, 2021 6:01 pm
One could not construct a flow chart from that post its all over the map........ I think language is a barrier,
State it in Italien and I will translate
rextended
Fri Aug 13, 2021 11:00 pm
Non è possibile specificare, con questa istruzione, quale DNS la Routerboard deve utilizzare per ogni subnet
Se omesso un DNS server viene comunque inviato tramite DHCP server, tra quelli gà presenti come DNS della routerboard in "/ip dns"
Se è attivo "allowed-remote-request" su "/ip dns" la RouterBOARD in assenza di dns-server specificato, manda il proprio IP
Questa istruzione indica solo ai PC che utilizzano il DHCP quale DNS utilizzare,
ma non sono obbligati ad usarlo, per esempio gli Android hanno codificato all'interno l'8.8.8.8 e il 8.8.4.4
e l'unica maniera per fargli usare i DNS forniti, è bloccare 8.8.8.8 e 8.8.4.4 nel firewall se le richieste arrivano dalla LAN.
L'unico modo per poter far usare alla RouterBOARD l'IP 1.1.1.1 come DNS è impostarlo su "/ip dns servers" come unico DNS
anav
Mon Aug 16, 2021 1:00 pm
Okay, let me ask the question in a different way.
What DNS setup by an admin would prevent your method of hairpin nat from working?
rextended
Mon Aug 16, 2021 4:04 pm
As it is not a hairpin NAT method, just the best way to configure the network when this need are present
(reach internal Server, on another subnet, from valid public DNS),
the only thing that can get in the way is an IP based SSH certificate (instead of a hostname certificate).
Or some device that uses external DoH or DoT, but since it is a matter of deliberately obstacle the reaching of one's own address,
I don't think that someone is self-hindering ...
anav
Sat Sep 11, 2021 3:48 pm
/ip dns static
Okay,
I understand the part in Green. This basically says any lan subnet request to look for that domain name should be (re)directed to the server.
What the heck did you add the NAT rule underneath for. They confuse the crap out of me.
rextended
Sat Sep 11, 2021 3:49 pm
For FORCE all DNS passing trough the Router to be solved from the RouterBOARD internal DNS except (!) all the traffic already from/to Ruoterboard itself...
Zacharias
Sat Sep 11, 2021 5:47 pm
As a workaround seems a good idea, but not ideal, nor common i guess...
I don't think that this is the definition of loopback :D
anav
Sun Sep 12, 2021 3:39 pm
Sorry Zach, old habits LOL. When I used/sold Zyxel gear they had a checkbox for hairpin nat, called loopback.
As for rextended, okay, why do I need those forcing DNS rules. What do they have to do with hairpin nat solutions??
Finally WHO in heck is using DNS that is not already on the routerboard??
Do you let WAN users use your DNS??
WHERE IS THIS OTHER DNS usage coming from??
To be clear, my input chain always ends with
add chain=input action=drop
and thus WAN to router DNS traffic is not permitted
rextended
Sun Sep 12, 2021 3:51 pm
I never say open the internal DNS to WAN side, simply force all LAN side to use RouterBOAD internal DNS.
anav
Sun Sep 12, 2021 5:23 pm
All sources going to all destinations (except for one particular subnet) should be sent to the gateway 192.168.88.1 for port 53 UDP and TCP.
But why do you need to do this for your hairpin work around???
So this statement.
"simply force all LAN side to use RouterBOAD internal DNS"
Means all subnet on the LAN side, OTHER than the server subnet???
Why not use existing redirect functionality??
add action=redirect chain=dstnat comment=\
"Force Users to Router for DNS - TCP" disabled=yes dst-port=53 protocol=\
tcp src-address-list=!192.168.88.1 (or whatever)
"Force Users to Router for DNS - UDP" disabled=yes dst-port=53 protocol=\
udp src-address-list=whatever (or perhaps in-interface-list=LAN)
rextended
Sun Sep 12, 2021 6:15 pm
1) I do not use hairpin nat and what I do is not any form of hairpin nat, and not have nothing to do about hairpin nat.
2) Is like I must rewrite again what already I wrote on this topic...
viewtopic.php?f=23&t=172380#p869441
viewtopic.php?f=23&t=172380#p869947
viewtopic.php?f=23&t=172380#p872307
Zacharias
Sun Sep 12, 2021 8:22 pm
@anav,
you should use redirect here instead...
Redirect replaces the destination address with the Router's Local address..
anav
Sun Sep 12, 2021 9:06 pm
Thanks!
kswong
Mon Sep 13, 2021 5:44 pm
Nat Masquerade 192.168.88.0/24 to 192.168.88.0/24 this works for every services at once. do not specify interfaces or port. internal port must be the same as the external port.
alexkiddd
Fri Oct 22, 2021 6:38 pm
Thanks for this, I have solved my problem with your approach!
Easen
Thu Dec 02, 2021 9:40 am
Thanks for the guide/tutorial.
As https://wiki.mikrotik.com/wiki/Hairpin_NAT is just returning an Error (well for me it is), this post has become the de facto guide on the topic :)
Zacharias
Thu Dec 02, 2021 9:01 pm
Nice approach...
As @anav said, there are many ways to implement Hairpin NAT...
@Easen take a look here https://help.mikrotik.com/docs/display/ ... HairpinNAT
anav
Thu Dec 02, 2021 10:47 pm
Nice approach...
I attempted to capture all the discussion here as well.......
viewtopic.php?t=179343
If there is anything I missed or should add let me know!!
Zacharias
Fri Dec 03, 2021 10:48 am
Nice approach...
ok @anav i will have a look later and let you know...
Corbie
Fri May 27, 2022 2:46 pm
Literally everyone: NAT loopback
Mikrotik: Hairpin NAT
anav
Fri May 27, 2022 5:59 pm
most others - use checkbox dont learn a damn thing
MT - config manually, actually learn how traffic flows within a router..........
Sucks to be an Other! :-)
secbro
Tue Jun 21, 2022 8:32 pm
Thank you for the explanation. Great work.
stefanosp
Thu Jun 23, 2022 1:00 am
Please, how do you solve the problem of having MORE-THEN-ONE internal servers, on different internal IPs?
For example, one web server 192.168.88.100 listening on port 443 and one mail server 192.168.88.101 on port 25. From the outside they are both reachable on the same DomainName "www.mydomain.it" , and with 2 different dst-nat rules you can reach both.
But from the inside, how do you resolve "www.mydomain.it" in IP address?
If you resolve www.mydomain.it in 192.168.88.100, you can reach web server but you can't reach mail server.
If you resolve www.mydomain.it in 192.168.88.101, you can reach mail server but you can't reach web server
Tia
Stefano
rextended
Thu Jun 23, 2022 2:10 am
usually I respect a simple "convection"
www.server.net is for... web!!!
mail.server.net is for... mail!!!
and if I have two server, for example one for smtp one for pop3/imap, I have one smtp.server.net and the other or still mail.server.net or I use pop3.server.net or if need imap.server.net!!!
And if I have a unique server that do all, I still register different names for each service...
and again
if is my internal network, who stop me to provide mail.server.net to internal devices, also if on real internet that domain not exist?
Znevna
Thu Jun 23, 2022 8:14 am
Split DNS vs Hairpin argument kinda died at the moment users started using DoH and other methods that bypass your local DNS hijacking (some just don't admit it yet).
rextended
Thu Jun 23, 2022 10:14 am
When this filter is done for work, not to censor or otherwise, on workstations, I don't think employees can do it to sabotage their work by themselves...
don't you think?
Sob
Thu Jun 23, 2022 8:30 pm
It's not about anyone trying to sabotage or get around anything. It's mainly the Just Works™ factor, hairpin NAT is foolproof and maintenance-free. You add one srcnat rule (or more, one per subnet), you do it once, and you don't need to touch it or even think about it ever again. No matter how many services you have, how many you add or remove, there's no extra work required, you just add or remove dstnat rules (which you need to do for external access anyway). You don't need to worry about what DNS resolver users use. It always works.
anav
Wed Jun 29, 2022 8:26 pm
Seems perfectly reasonable its the same public IP being reached and the distinguishing factor for access is the port/protocol.
Access from the exterior works just fine.
Access from the interior will depend on
a. the proper confi of your firewall rule for port fowarded traffic.......
b. the makeup of your destination nat rule ( is it formulated for the type of WAN connections you have (static vs dynamic).
c. srcnat rule for hairpin nat added to the config.
Remember hairpin nat is only needed if the users and server(s) are in the same subnet. One can always consider moving the servers to a different subnet.
Sob
Wed Jun 29, 2022 8:38 pm
@anav: Not the point. That post quoted @rextended's post about internal DNS, as a way to avoid NAT completely, so it's safe to assume that it was about that. And the answer is that it can't be done, because if you point the common hostname to some internal server, it will always be either one or the other, but not both (well, it can be both, but then it will be unusable hit and miss).
anav
Wed Jun 29, 2022 10:33 pm
Ahh yes, I missed that nuance. Not to worry, DNS is pain in de ass and should be avoided monkeying with at all costs LOL.
geokanellakis
Fri Nov 04, 2022 10:04 am
Man i love you!!!!! hairpin nat with lte hi link through usb worked with your way
tryrtryrtryrt
Fri Jan 24, 2025 9:07 am
Apologies for reviving an old thread.
@anav, could you kindly explain why it will make a difference, please?
Is it because in the same LAN scenario, the packet back would be destined directly to the client MAC address as the server has it in its ARP table, and the router would simply switch it back to the client without any processing,
while in the separate LAN scenario, the server would set the MAC address of the router in the reverse packet as ARP table does not span to directly unreachable LANs, the router would route (not switch) the packet, and the dst-nat would be reversed?
Or am I overcomplicating it/missing anything?
anav
Fri Jan 24, 2025 6:00 pm
Something like that......... the router knows where the originator is and attempts to send it back directly and the originator rejects the traffic as it appears to be traffic not requested ( source IP does not match the original dst IP).
http://gregsowell.com/?p=4242
tryrtryrtryrt
Fri Jan 24, 2025 6:15 pm
Thanks, that makes sense.
But why would it work without the additional srcnat rule if we put the server in a separate subnet?
anav
Sat Jan 25, 2025 3:09 pm
off the top of my head, the issue is no longer a Layer2 problem, as a different subnet provides no connectivity at layer 2.
willianwrm
Wed May 28, 2025 6:33 pm
I did try the topic approach and the official one but none did really work...
The topic approach I do see the mangle packets get increased but zero in the nat; I'm suspecting if fasttrack is somehow influencing it.
Is there other good approaches?
I have a hAP ac² running at version 7.19.1
Urajmal
Wed May 28, 2025 6:39 pm
Try it this way, you need three rules:
chain=srcnat action=masquerade connection-mark=Hairpin NAT log=no log-prefix=""
chain=dstnat action=dst-nat to-addresses=192.168.1.113 to-ports=8000 protocol=tcp dst-address=12.34.56.78(PublicIP) dst-port=8000 log=no log-prefix=""
/ip firewall mangle
chain=prerouting action=mark-connection new-connection-mark=Hairpin NAT passthrough=yes src-address=192.168.1.0/24 dst-address=12.34.56.67(Public IP) log=no log-prefix=""
And you only add firewall NAT (second line) rules, for another devices.
willianwrm
Wed May 28, 2025 7:41 pm
Thanks for the help Urajmal.
The first and third rules are basic the main post and the second one is a dst-nat, I did try set the dst-address to the public IP as mentioned but still didn't work.
The mangle counter is increasing but the nat one is still zero; the dst-nat works but only for devices outside the lan.
loloski
Long time Member
Long time Member
Thu May 29, 2025 1:18 am
check your routing if you have a valid symmetric route to the target host on that LAN segment where the target host and it should work
willianwrm
Thu May 29, 2025 3:07 pm
I'm kind network enthusiastic/newbie, how do I check for the symmetric route? All my ip-routes are dynamic.
External devices can access the lan host by public IP (port forwarding using dst-nat).
loloski
Long time Member
Long time Member
Thu May 29, 2025 3:43 pm
Please use this guide from normis and compare to what you are doing, https://www.youtube.com/watch?v=1I5FywY6opQ this will surely help you another approach is you can use split horizon DNS to fix your issue.
willianwrm
Thu May 29, 2025 5:05 pm
Thanks for the reply; in the video I did notice that in the dst-nat the "in. interface" is empty, only the "dst. address" is used; well that makes sense for hairpin.
The problem was the host was using upnp to auto add the dst-nat rules, but the upnp rules forces the "in. interface"; disabling it and adding dst-nat manually did the trick and now hairpin works :)
In resume the Hairpin works good but not with UPNP.
