mikruser
bridge hardware offload
Tue Feb 09, 2021 12:41 pm
RB750Gr3, hardware offload enabled for bridge ports ether2 and ether3.
Why hardware offload is inactive?
do not ask me why it is necessary.
vecernik87
Forum Veteran
Forum Veteran
Re: bridge hardware offload  [SOLVED]
Tue Feb 09, 2021 1:02 pm
Because your RB750Gr3 features a MT7621 switch chip which does not have many features: https://wiki.mikrotik.com/wiki/Manual:S ... p_Features
Almost any setting will disable hardware offload: https://wiki.mikrotik.com/wiki/Manual:I ... Offloading
So - you can't use STP, you cant use IGMP/DHCP snooping, no VLANs and of course no bonding.
mikruser
Tue Feb 09, 2021 1:14 pm
Thanks, after set STP Protocol mode = none, hw offload is active.
Users browsing this forum: No registered users and 24 guests
