celeritynetworks
Script Contents Run Manually but Not from Run Script Button
Tue Feb 23, 2021 10:03 pm
Hello. I have this script, which runs fine when I copy/paste it into a terminal window, but doesn't seem to run when I click on the Run Script button in Winbox (the variables referenced are manually created global variables for testing).
:if ($RadIncReq>$RadIncReqLast) do={
/tool fetch mode=https url="https://hooks.slack.com/services/real-token-removed" http-method=post http-data="payload={\"attachments\":[{\"color\":\"#f54242\",\"pretext\":\"ALARM\",\"callback_id\":\"dude_alarm\",\"text\": \"ROUTER-BNG - Incoming RADIUS Requests are Incrementing\"}]}";
/log info "**** Incoming RADIUS Requests are Incrementing****";
When I copy/past the above in this exact form, I get the log entry and the message in Slack. When I click Run Script button, I get neither.
Here's the actual export:
/system script
add dont-require-permissions=no name=CheckRadIncRequests owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":if (\$RadIncReq>\$RadIncReqLast) do={\r\
\n/tool fetch mode=https url=\"https://hooks.slack.com/services/real-token-removed\" http-method\
=post http-data=\"payload={\\\"attachments\\\":[{\\\"color\\\":\\\"#f54242\\\",\\\"pretext\\\":\\\"ALARM\\\",\\\"callback_\
id\\\":\\\"dude_alarm\\\",\\\"text\\\": \\\"ROUTER-BNG - Incoming RADIUS Requests are Incrementing\\\"}]}\";\r\
\n/log info \"**** Incoming RADIUS Requests are Incrementing****\";\r\
\n}"
Here's the actual environment:
/system script environment> print
# NAME VALUE
0 RadIncReq 9
1 RadIncReqLast 8
I'm sure I'm missing something simple, thanks in advanced!
Jotne
Re: Script Contents Run Manually but Not from Run Script Button  [SOLVED]
Tue Feb 23, 2021 10:42 pm
Simple to solve.
You need to declare the global variable before it can be seen by a script, so change to:
:global RadIncReq
:global RadIncReqLast
PS use code tags </> when posting codes and ; are not needed on end of each line, only between multiple commands on same line.
Try to use Splunk to monitor your MikroTik Router(s). Look at this page in how to set it up.
MikroTik->Splunk
celeritynetworks
Tue Feb 23, 2021 11:12 pm
Thanks so much for the quick reply, I appreciate it. I will use code tags next time, too.
Users browsing this forum: efolch, mickas824 and 47 guests
