MUM Europe 2020
Gromit
Hotspot security
Tue Jul 24, 2007 11:54 am
I have set up a RB532 as a hotspot on the wireless interface, but would like to secure it. I don't want users of the hotspot to be able to access the routerboard via Winbox. How would I go about doing this? Would I create a NAT rule?
(the eth1 interface will have a separate network that will make use of the web proxy but not the hotspot)
Nuke
Re: Hotspot security
Tue Jul 24, 2007 12:04 pm
Hi, are you Gromit from PCF SA?
Set up firewall rule that blocks(drop or reject) port 8291 if the in-interface is the wlan interface. Should do the trick.
normis
Tue Jul 24, 2007 12:05 pm
there are many ways. changing the port, allowing chain "input" only to specific IPs, port knocking (there is a topic on this in the same section)
Gromit
Tue Jul 24, 2007 12:06 pm
Yip thats me Gromit on PCF SA :)
Will give it a bash, thanx
Gromit
Tue Jul 24, 2007 12:39 pm
Please can you post a link to the thread
normis
Tue Jul 24, 2007 12:45 pm
Gromit
Tue Jul 24, 2007 3:40 pm
If I am creating an address pool eg. 192.168.99.0/24 for use on the hotspot. Can I not just create a firewall input rule to drop all input packets from this range of IPs?
Gromit
Thu Jul 26, 2007 9:22 am
No one have an answer for me?
channingzou
Tue Jul 31, 2007 5:58 am
/ip firewall filter add chain=input src-address=192.168.1.2(change to yours) dst-address=192.168.1.1(change to yours) action=accept comment="allow specify login" disabled=no
disable port 8291 if you add for accept with out interface selected
Users browsing this forum: durrsaku and 43 guests
