ghanoonimasood
The dude . links creation question
Sun Mar 14, 2021 11:16 am
Hi every one.
I have implemented dude to monitor my network. I have for example 4 site in different places . each site has let's say 4 router which one of these 4 routers is a edge router. sites are connected together with OPENVPN(or SSTP) tunnels using public IPs to make the tunnels . inside each site, I have got static routes between routers and also OSPF between edge routers ...
this was a summery of my network .
And now my question is that :
when I add a link between devices I have already added, and I put the mastering Type on "routeros" then thee Interface drop list is completely empty ... and after making the link done , there is no rx/tx rate on the link ....
could anybody tell me what is the problem ?
I have attached some photo with the purpose of making the question more clear.
EvertVB
Re: The dude . links creation question
Wed Nov 17, 2021 7:46 pm
I have the same problem with none ARM Mikrotik devices.
My RB3011 and RB4011 populate the Interface drop down.
My other Mikrotiks are a RB1100 Powerpc and a hEX PoE
which has the MIPSBE software and they have an empty
drop down. So it seems to be firmware related.
inteq
Sat Nov 27, 2021 7:44 pm
Do all devices allow inbound Winbox port? If yes, it is accessible from all devices?
Have you set the type to RouterOS for each device?
bpwl
Sat Nov 27, 2021 8:36 pm
Check your settings for RouterOS. Do a reconnect if RouterOS status is not OK
What do you see in the RouterOS tab ? Interfaces should be there.
You can do exactly the same with SNMP on MT.
Users browsing this forum: No registered users and 31 guests
