tboernert
OSPF with redundant Routers
Fri Mar 26, 2021 11:25 pm
Hi all,
i have the following setup:
Redundant
CiscoStack
R1 --- R2
80 GHz
80 GHz
R3 --- R4
Redundant
CiscoStack
R1 - R4 are CCR2004 runnig OSPF.
R1 and R2 have a DA cable (routed) and R3/4 also.
Between an 80 GHz 1+1 Radio Link. On each site 2 bridged(!) interfaces connected to R1/2 and on the other site connected to R3/4.
So all interfaces from R1-R4 on the radio site are bridged.
On Top of OSPF i have running MPLS with VPLS tunnels.
So if one Router on one site will fail i have no problem.
Is that an good idea ? Or have everyone a better solution ?
Thomas
mada3k
Long time Member
Long time Member
Re: OSPF with redundant Routers
Sat Mar 27, 2021 12:07 pm
It sounds like a decent solution. All four routers is, in other words, on the same Layer 2 network?
All four is present on /routing ospf neighbour print?
And you are running R(STP) over the VPLS tunnels?
tboernert
Sun Mar 28, 2021 1:57 am
yes all 4 routers on the wireless site are on the same layer 2 network. that will be a problem, isn't it ?
which network-type should i use on the wireless site ? ptmp ?
i think horizon will be eliminate the loop for the bridge network through vpls.
Thomas
millenium7
Long time Member
Long time Member
Mon Mar 29, 2021 5:22 am
PTMP has issues on MikroTik
I'd suggest you create a separate VLAN interface for every router to router link over wireless and then use point-to-point type. You'll have far less issues
Users browsing this forum: MarkoB and 14 guests
