dhelazt
Replace FLASH on HAP & HEX with larger capacity
Tue Apr 06, 2021 5:43 am
Hi, i have many HAP & HEX in my office after replacing router on our client. Most client required quite lot service where HAP/HEX didn't have enough space to accomodate all required extra packages we need. So, we replaced them with old RB951 or even upgrade them to 2011/3011 series.
Then, i'm thinking about replacing the FLASH inside HAP/HEX series, because it seems MT using regular SPI Flash like Winbond W25Q128JVSM inside HAP AC2. What happen if i replace the Flash memory with Winbond W25Q256 or equal Flash? I know i will lose the license, but will it work? I can purchase another Level 4 License if it work and increase Flash capacity from 16MB to 32MB will make HAP series more powerfull router. For example, HAP AC2 is a good Router for me except it always run out of storage.
Paternot
Re: Replace FLASH on HAP & HEX with larger capacity
Tue Apr 06, 2021 6:40 am
Take a look at hAP AC3. More storage, more RAM and can be bolted to the wall. It's an internal unit, though.
https://mikrotik.com/product/hap_ac3
dhelazt
Tue Apr 06, 2021 10:46 am
HAP AC3 currently out of stock at Indonesia when i bought AC2, until today only Pre-Ordered is available to purchase AC3 from local distributor. I looking for cheap solution for upgrading Flash on HEX or HAP series router i have in my office. Maybe i can make them useful by upgrading the Flash memory.
Paternot
Tue Apr 06, 2021 3:11 pm
The license cost is bigger than the unit itself. Makes no sense upgrading the flash chip. It's cheaper just to resell the unit and buy another one.
tweaker
Sat Mar 19, 2022 5:19 pm
where does your stament that you loose the license from?
i'm planning to do just the same as you are planning.
just haven't received the parts i ordered in china yet.
i'm planning to first read out the flash chip, then flash the result in a new (bigger) chip, and then solder it to the board.
it's a shame MT didn't do this in the first place.
Edit: result: you can replace the flash chip with a bigger one. More space, is visible in winbox, but... the software ID changes, and because of this the licence is t valid any more, So, this is not working.
Paternot
Wed Mar 23, 2022 8:34 pm
The license key is kept on the flash. If You loose it, the license is gone. I don't know how easy, or hard, would be to transfer this to another flash - but I would ask support first.
doneware
Trainer
Trainer
Sun Sep 04, 2022 4:59 pm
you can boot openwrt and dump the flash beforehand. or use a SOP8 adaptor and dump the flash once it's desoldered.
can you please drop here the part# you used to replace the original flash?
r00t
Long time Member
Long time Member
Tue Sep 06, 2022 2:37 am
From W25Q128JV datasheet:
Advanced Security Features
– 64-Bit Unique ID for each device
– 3X256-Bytes Security Registers with OTP locks
So it's likely these features are used for soft-id. Even if you dump and clone regular flash contents, you can't clone chip Unique ID.
chojrak11
Mon Jul 08, 2024 11:18 am
Did anybody succeed with this, for example replacing the factory 128 Mbit chip W25Q256JV with 256 Mbit one - W25Q256JV?
If so, can you share more details about the process?
dang21000
Tue Jul 09, 2024 12:24 pm
With a hotgun soldering station, it can be easy to replace the chip
lapsio
Long time Member
Long time Member
Wed Jul 10, 2024 2:05 am
Like the guys said - you'll loose license. I was replacing flash on CRS326 with dead flash and lost license as well. Even though I dumped and copied old flash contents to new one. MikroTik support refused to give me replacement license key. (Though I had few spare L4 licenses received for MikroTik certifications so used one of those)
Davis
Mon Mar 17, 2025 6:51 pm
Exactly what chip did you use as the replacement?
Was the board hAP ac2?
I guess chip+L4 license together will still be cheaper (and in my case also more interesting :D) than buying a new hAP ac3...
Has anybody else upgraded the flash storage on any of RouterBOARD devices? Were there any problems (in addition to the cost of a new license)?
P.S. As the size of RouterOS is growing with each release and MikroTik hasn't split it in more separate packages, likely flash upgrade on 16 MB devices is becoming more and more relevant for many of the users.
patrikg
Mon Mar 17, 2025 7:31 pm
If you put this command into cli you get the license file into your device flash.
[admin@MikroTik] > /system/license/output
[admin@MikroTik] > /file/print
 # NAME                              TYPE             SIZE LAST-MODIFIED
 0 XXXX-XXXX.key                     .key file         204 2025-03-17 18:27:51
Then you can import that file.
jaclaz
Mon Mar 17, 2025 7:34 pm
viewtopic.php?t=214381
@patrikg
Are you sure sure that it works if the chip (and its "unique" ID) is changed?
patrikg
Mon Mar 17, 2025 7:38 pm
@jaclaz No, I don't know.
I just know that's the command for getting the license file from the device.
And that file can be used with netinstall-cli to flash the device.
jaclaz
Mon Mar 17, 2025 7:51 pm
No, I don't know.
... but seemingly only the same device, with the same flash chip (and same unique ID) ....
Davis
Sat Mar 22, 2025 1:07 am
Thank you very much!
