MUM Europe 2020
pjulian
SNMP OID for Qty of Wireless Clients Connected
Sun Jul 29, 2007 10:08 am
Hey guys, does anybody know how I can get the amount of wireless clients connected using SNMP ?
I have trolled through the SNMP walk and can't find anything that relates to this value.
I want to be able to graph the amount of clients connected to an AP every 5 minutes using MRTG.
Any suggestions would be appreciated.
Paul
sergejs
Re: SNMP OID for Qty of Wireless Clients Connected
Mon Jul 30, 2007 4:15 pm
Paul, currently such option is not available,
as you have two sections for SNMP monitor,
'interface wireless print oid', that allows to monitor the following values,
tx-rate=.1.3.6.1.4.1.14988.1.1.1.1.1.2.4010 rx-rate=.1.3.6.1.4.1.14988.1.1.1.1.1.3.4010 strength=.1.3.6.1.4.1.14988.1.1.1.1.1.4.4010 ssid=.1.3.6.1.4.1.14988.1.1.1.1.1.5.4010 bssid=.1.3.6.1.4.1.14988.1.1.1.1.1.6.4010 frequency=.1.3.6.1.4.1.14988.1.1.1.1.1.7.4010
'interface wireless registration-table print oid',
[sergejs@HotSpot] > in wireless registration-table print oid
0 strength=.1.3.6.1.4.1.14988.1.1.1.2.1.3.0.11.107.77.4.42.2
tx-bytes=.1.3.6.1.4.1.14988.1.1.1.2.1.4.0.11.107.77.4.42.2
rx-bytes=.1.3.6.1.4.1.14988.1.1.1.2.1.5.0.11.107.77.4.42.2
tx-packets=.1.3.6.1.4.1.14988.1.1.1.2.1.6.0.11.107.77.4.42.2
rx-packets=.1.3.6.1.4.1.14988.1.1.1.2.1.7.0.11.107.77.4.42.2
tx-rate=.1.3.6.1.4.1.14988.1.1.1.2.1.8.0.11.107.77.4.42.2
rx-rate=.1.3.6.1.4.1.14988.1.1.1.2.1.9.0.11.107.77.4.42.2
Total number of client is not available over snmp.
'interface wireless registration-table print count-only interface=name_of_the_ap'
dinfotec
Wed Aug 01, 2007 2:42 pm
We use this; and work fine
[array_size(oid_column("iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrWireless.mtxrWlRtabTable.mtxrWlRtabEntry.mtxrWlRtabStrength"))] Wireless Clients
Regards,
Fran.
jo2jo
Forum Veteran
Forum Veteran
Sat Aug 23, 2008 5:55 am
what do you enter that into? Dude? MRTG?
thanks
:beep :beep :beep
pjulian
Fri Sep 12, 2008 5:55 pm
Mate, you are a legend, this works a treat thanks !
Regards
Paul
jo2jo
Forum Veteran
Forum Veteran
Tue Sep 16, 2008 4:09 am
pjulian, can you answer my question:
what do you enter that:
([array_size(oid_column("iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrWireless.mtxrWlRtabTable.mtxrWlRtabEntry.mtxrWlRtabStrength"))] Wireless Clients)
into? Dude? MRTG?
thanks
:beep :beep :beep
anpena
Wed Apr 29, 2009 5:52 am
Hello "dinfotec"
This is great, this array works great in Dude, just one question, I want to graph the same in Dude, I tried to create same array as function into a new graph, but unfortunately is not graphing, can you tell me how to graph the same array in Dude
Really appreciated your help
Antonio
Pikoro
Fri Jun 26, 2009 11:10 am
Here's how you do this:
In dude, go to "Functions" and create a new function called: wireless_clients
under "Code" paste in the following:
click on Ok and go back to your network map
right click on one of your wireless devices and select "Appearance"
click on the "Label" box and paste the following:
[Device.Name]
[device_performance()][Device.ServicesDown][wireless_clients()] Wireless Clients
Click on Ok and see your handy work.
Here's to graph it:
Right click on your network object and go to "Settings"
on the "Services" tab, add a new service
click on the 3 dots next to "Probe"
Fill out the following settings:
type: Function
Available: wireless_clients()
Error: if(wireless_clients(), "", "")
Value: wireless_clients()
Unit: Clients
rate: None
click on "ok" and select the wireless_probe as your probe
Hit Ok again and you should be graphing the number of wireless clients now.
Cheers
Edit: Added to the wiki: http://wiki.mikrotik.com/wiki/Number_of ... ss_Clients
noamsheffi
Tue Mar 23, 2010 5:16 am
Thanks for that
can you help me on how to add TX & RX probe ? I would like to monitor tx rx rate on device without using link
sergejs
Tue Mar 23, 2010 10:13 am
noamsheffi,
Pikoro
Tue Mar 23, 2010 10:22 am
BTW, I never asked, but back when I added this all to the wiki, I think they were giving out free MT licenses and I never claimed one.
Any chance of picking one up still?
angboontiong
Thu Sep 09, 2010 10:15 am
Hi..
would you mind to print screen on that...
slech
Long time Member
Long time Member
Mon Apr 30, 2012 11:45 pm
As I understand
Show signal strength, but I need Wirelles clients count.
How I can do this via SNMP ?
sorry for my english
angboontiong
Tue May 01, 2012 3:36 pm
Paul
1.3.6.1.4.1.14988.1.1.5.1.1.1
slech
Long time Member
Long time Member
Tue May 01, 2012 5:07 pm
This is HotSpot active users ?
angboontiong
Tue May 01, 2012 5:57 pm
Hi...
sorry, not look into it carefully as rushing just now...
ya, this is for the Hotspot active user but not the registered user under wireless registration table...
angboontiong
Mon May 07, 2012 1:31 pm
The RouterOS V5.15 have such oid...
sergey1369
Fri Mar 14, 2014 9:30 am
Hello, please advice.
Does Mikrotik RouterOS have an OID for total number of Wifi sessions/users/clients since power on?
sergey1369
Fri Mar 14, 2014 9:32 am
Hello, please advice. Does Router OS have OID for total number of users/sessions/clients since power on?
dohmniq
Sat May 17, 2014 10:46 pm
Just to add: I've raised ticket #2014051566000304 asking for more OIDs for the wireless registration table.
Specifically I asked for mac-address (so I can see WHO is connected!) and tx/rx ccq.
It wouldn't hurt for other people to ask too!
dohmniq
Sun May 18, 2014 12:19 am
Also...
/interface wireless> pr oid
 0 tx-rate=.1.3.6.1.4.1.14988.1.1.1.3.1.2.2 rx-rate=.1.3.6.1.4.1.14988.1.1.1.3.1.3.2 ssid=.1.3.6.1.4.1.14988.1.1.1.3.1.4.2 bssid=.1.3.6.1.4.1.14988.1.1.1.3.1.5.2
   client-count=.1.3.6.1.4.1.14988.1.1.1.3.1.6.2 frequency=.1.3.6.1.4.1.14988.1.1.1.3.1.7.2 band=.1.3.6.1.4.1.14988.1.1.1.3.1.8.2 noise-floor=.1.3.6.1.4.1.14988.1.1.1.3.1.9.2
   overall-ccq=.1.3.6.1.4.1.14988.1.1.1.3.1.10.2
client-count (on a per interface basis) seems to be .1.3.6.1.4.1.14988.1.1.1.3.1.6.2
Any use to you?
rekeds
Wed Feb 25, 2015 12:30 pm
client-count=.1.3.6.1.4.1.14988.1.1.1.3.1.6.6
mitzone
Fri May 29, 2015 9:58 am
this is the OID I use :
.1.3.6.1.4.1.14988.1.1.1.2.1.1
It returns number of MAC addresses of the clients connected. It returns an error if no client is connected.
Cheers!
SolarW
Fri Dec 11, 2015 5:53 pm
RB SXT 2 ROS 6.33.2 work as AP
noise-floor=.1.3.6.1.4.1.14988.1.1.1.3.1.9.2 overall-ccq=.1.3.6.1.4.1.14988.1.1.1.3.1.10.2
RB951Ui-2HnD ROS 6.33.2 work as AP
0 tx-rate=.1.3.6.1.4.1.14988.1.1.1.3.1.2.6 rx-rate=.1.3.6.1.4.1.14988.1.1.1.3.1.3.6 ssid=.1.3.6.1.4.1.14988.1.1.1.3.1.4.6 bssid=.1.3.6.1.4.1.14988.1.1.1.3.1.5.6
client-count=.1.3.6.1.4.1.14988.1.1.1.3.1.6.6 frequency=.1.3.6.1.4.1.14988.1.1.1.3.1.7.6 band=.1.3.6.1.4.1.14988.1.1.1.3.1.8.6
noise-floor=.1.3.6.1.4.1.14988.1.1.1.3.1.9.6 overall-ccq=.1.3.6.1.4.1.14988.1.1.1.3.1.10.6
Why?
jarda
Sat Dec 26, 2015 9:35 am
Because of internal port numbering. In sxt the wlan is the second port in 951 it is the sixth port.
Hrobocop
Sat Sep 16, 2017 4:30 pm
I was just playing a bit with MIB browser and in my case it seems to be available on three places:
  • mtxrWlApClientCount
    • OID: .1.3.6.1.4.1.14988.1.1.1.3.1.6.11
      Simple MIB: MIKROTIK-MIB::mtxrWlApClientCount.11
      Full MIB: .iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrWireless.mtxrWlApTable.mtxrWlApEntry.mtxrWlApClientCount.11
  • mtxrWlApAuthClientCount
    • OID: .1.3.6.1.4.1.14988.1.1.1.3.1.11.11
      Simple MIB: MIKROTIK-MIB::mtxrWlApAuthClientCount.11
      Full MIB: .iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrWireless.mtxrWlApTable.mtxrWlApEntry.mtxrWlApAuthClientCount.11
  • mtxrWlRtabEntryCount
    • OID: .1.3.6.1.4.1.14988.1.1.1.4.0
      Simple MIB: MIKROTIK-MIB::mtxrWlRtabEntryCount.0
      Full MIB: .iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrWireless.mtxrWlRtabEntryCount.0
PS: Im'm not sure what is the difference between ApClientCount and ApAuthClientCount - I always have the same number/count (sure, the second should be authenticated).
Users browsing this forum: No registered users and 18 guests
