jonmill
DST-NAT not opening port
Wed Apr 14, 2021 3:34 am
Hi - I'm trying to open a couple of ports and have looked at the forum / documentation here, followed the previous advice, but the port is still not open. I'm on a MikroTik hEX S and I know my ISP is not blocking the ports since it worked on my old Ubiquiti router. I'm trying to open (to start) port 32400 and testing it via both the Plex UI, a 4G connection, and an external port-scanner...all of them say that the port is still closed. Any ideas?
Here's my config:
# apr/13/2021 17:31:55 by RouterOS 6.48.1
# software id = E5TS-FVUZ
# model = RB760iGS
# serial number = AE370C704F06
add admin-mac=48:8F:5A:D9:36:A5 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.50-192.168.1.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=bridge comment=defconf interface=sfp1
/interface l2tp-server server
set enabled=yes use-ipsec=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.1.1/24 comment=defconf interface=ether2 network=\
    192.168.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no \
    use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.1.101 mac-address=18:74:2E:D8:F5:0C
add address=192.168.1.201 mac-address=00:11:32:10:AA:9A
add address=192.168.1.242 mac-address=A8:A1:59:3F:AA:0B
add address=192.168.1.243 mac-address=A8:A1:59:3F:A1:1F
add address=192.168.1.126 mac-address=10:98:C3:BC:DF:8B
add address=192.168.1.148 mac-address=00:0C:29:28:BC:6B
add address=192.168.1.150 mac-address=C8:34:8E:60:E5:D1
add address=192.168.1.151 mac-address=B8:31:B5:31:9A:33
add address=192.168.1.152 mac-address=A4:5E:60:B9:45:F1
add address=192.168.1.200 mac-address=00:11:32:6D:17:99
add address=192.168.1.210 mac-address=00:0C:29:62:51:D7
add address=192.168.1.125 mac-address=98:09:CF:8F:6C:BA
add address=192.168.1.100 mac-address=50:14:79:1E:47:76
add address=192.168.1.153 mac-address=4C:ED:FB:BF:10:BB
add address=192.168.1.5 mac-address=00:0C:29:40:E7:75
add address=192.168.1.215 client-id=1:0:11:32:e1:d5:8 mac-address=\
    00:11:32:E1:D5:08 server=defconf
add address=192.168.1.64 client-id=\
    ff:8a:54:d0:44:0:2:0:0:ab:11:95:a0:47:56:6c:49:c3:14 mac-address=\
    DC:A6:32:49:07:48 server=defconf
add address=192.168.1.77 client-id=\
    ff:10:4e:b6:48:0:2:0:0:ab:11:95:a0:47:56:6c:49:c3:14 mac-address=\
    DC:A6:32:49:07:4A server=defconf
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
    established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
    protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
    invalid
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
    192.168.89.0/24
add action=dst-nat chain=dstnat comment=Plex dst-port=32400 protocol=tcp \
    to-addresses=192.168.1.210 to-ports=32400
add action=dst-nat chain=dstnat comment=Jellyfin dst-port=8920 protocol=tcp \
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
add interface=ether2 type=internal
add interface=ether3 type=internal
add interface=ether4 type=internal
/ppp secret
add name=vpn
/system clock
set time-zone-name=America/Los_Angeles
/system clock manual
set time-zone=-08:00
/tool mac-server
/tool mac-server mac-winbox
anav
Re: DST-NAT not opening port
Wed Apr 14, 2021 2:35 pm
(1) WHY? should be bridge!
192.168.1.0
(2) DOUBLE WHY?
Did you remove the most important default firewall rule in the input chain, the one that protects your router from hacking............. aka remove from internet until fixed!!!
add action=drop chain=input in-interface-list=!LAN
(3) Both your Dst nat rules are missing the in-interface................
in-interface-list=WAN to-addresses=192.168.1.210
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
jonmill
Thu Apr 15, 2021 3:29 am
Thanks for the info - I've fixed the issues you mentioned (thanks for pointing out the additional issues, I appreciate it) and the ports are open but external traffic doesn't seem to be routing there properly. Internal traffic is routed just fine, but external requests don't make it (tested via a phone on cellular with WiFi off)...any ideas?
Updated config below:
# apr/14/2021 17:25:10 by RouterOS 6.48.1
# model = RB760iGS
/ppp profile
set enabled=yes
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
/ip cloud
/ip dhcp-client
    use-peer-ntp=no
/ip dns static
    protocol=udp
    invalid
    192.168.89.0/24
add action=dst-nat chain=dstnat comment=Plex dst-port=32400 \
    in-interface-list=WAN protocol=tcp to-addresses=192.168.1.210 to-ports=\
    32400
add action=dst-nat chain=dstnat comment=Jellyfin dst-port=8920 \
    8920
/ip service
/ip upnp
set enabled=yes
/ip upnp interfaces
/ppp secret
add name=vpn
/system clock
/tool mac-server
anav
Thu Apr 15, 2021 3:52 am
This line should also normally include dns-server=192.168.1.1
Set this line to NONE (mac-server access is not a secure method and should be avoided). mac-winbox is fine!
/tool mac-server
I am not seeing any of the IP route settings????
(try turning UPNP off and testing connectivity).
Do you mean
a. you can directly access a Server by its LAN address
b. external folks, like myself cannot access the server from my external WANIP given your server inforamation?
jonmill
Thu Apr 15, 2021 4:42 am
Meaning I can access the server locally using the internal IP address but external access does not increment the Packet Counters and does not connect. Port scanning, however, does show the ports as open...so it looks like the packet is being dropped or not routed correctly. Any ideas?
anav
Thu Apr 15, 2021 4:57 am
Already noted,
Dont see your Route settings?
Try turning Upnp off.
Set the dns server in the dhcp network settings.
jonmill
Fri Apr 16, 2021 2:45 am
I don't have any routing rules setup specifically...I've never had a problem and internal traffic works fine; that and the DST-NAT specifies the destination IP address through the bridge. What do I need to add to the routing table?
I turned UPNP off
I added the router (192.168.1.1) and CloudFlare (1.1.1.1) as DNS servers in the DHCP network settings
anav
Fri Apr 16, 2021 5:41 am
So somehow you can reach the internet now with NO entries in IP Routes??
There must be some entries if you can successfully reach the net etc..
The only other thing that comes to mind is your in a double NAT scenario where the actual WANIP you get from the ISP is a private IP and not a public IP?"??
jonmill
Fri Apr 16, 2021 8:38 am
My full config (minus sensitive) is below. My router is directly connected to my modem and has a public IP (verified by checking the DHCP Client IP against external requests source IPs).
My routing table has 3 routes:
1) DAS Dst Address: 0.0.0.0/0 Gateway (external IP here) reachable ether1 Distance 1 Routing Mark null Pref. Source null
2) DAC Dst Address: (external IP here)/23 Gateway ether1 reachable Distance 0 Routing Mark null Pref. Source (external IP here)
3) DAC Dst Address 192.168.1.0/24 Gatewaybridge reachable[/b] Distance 0 Routing Mark null Pref. Source192.168.1.1
jonmill
# model = RB760iGS
/ppp profile
set enabled=yes
    192.168.1.0
/ip cloud
/ip dhcp-client
    use-peer-ntp=no
/ip dns static
    protocol=udp
    invalid
    192.168.89.0/24
    32400
    8920
/ip service
/ip upnp
set enabled=yes
/ip upnp interfaces
/ppp secret
add name=vpn
/system clock
/tool mac-server
anav
Fri Apr 16, 2021 2:30 pm
I cannot fathom why an external attempt from the WAN does not work.
Assuming you mean from an external WANIP and not someone on the lan using the external WANIP (which is a loopback hairpin nat scenario).
jonmill
Fri Apr 16, 2021 11:51 pm
Correct - I'm using a phone on 4G (WiFi fully disabled) to both port-scan and connect. The port-scanner shows that the ports are open but no connections are established and no counters are incremented in the router dashboard, showing that no packets are flowing through my dst-nat rules...I'm at a loss
anav
Sat Apr 17, 2021 2:26 am
Sadly the only thing I can suggest is reinstall firmware lets say the latest long term version..........
jonmill
Thu Apr 22, 2021 12:32 am
That's unfortunate...does anyone else have any ideas?
Thanks for your help anav!
anav
Thu Apr 22, 2021 2:18 am
Suggest you get a friend to try and connect to your server and while doing so run packet sniffer in the tools.
Use the IP address of the server for example for the attempts.
Also try the same exercise running packet sniffer but this time using the WAN interface as the filter (but ensure no one else is using the internet (as quiet as possible).
Users browsing this forum: lucidnx and 81 guests
