tschiex
ipv4+ipv6 on Chateau 12 LTE / Quectel EG12
Fri Apr 16, 2021 11:54 am
Dear all,
I'm new to Mikrotik routers and have just received my Chateau 12. I have a strange home setup where I have 2 gateways on the same LAN, one is a 4Mb/s ADSL line which offers both ipv4 and ipv6. I cannot deactivate ipv6. I have a small bandwidth but a lot of services on the ADSL box so I don't want to get rid of the box either. The second gateway is the chateau 12. The LTE interface seems to offer ipv4 xor ipv6 but I could not find ipv4v6 in the LTE APN menu. With Chateau
  • In ipv4 mode only, all ipv6 traffic gets routed to the (slow) ADSL interface => slow
  • In ipv6 mode only, all ipv4 websites fail.
Ideally, I would like to have the LTE interface in IPV4V6 mode but I do not see it on my LTE APN interface. My provider claims it supports ipv6 (and the chateau does work in ipv6 mode), it also supports IPV4. I tried:
at-chat lte1 input="AT+CGDCONT=\?"
  output: +CGDCONT: (1-42),"IP",,,(0-3),(0-4),(0-1),(0-1) +CGDCONT: (1-42),"PPP",,,(0-3),(0-4),(0-1),(0-1) +CGDCONT: (1-42),"IPV6",,,(0-3),(0-4),(0-1),(0-1) +CGDCONT: (1-42),"IPV4V6",,,(0-3),(0-4),(0-1),(0-1)
and it seems that the EG12 is IPV4V6 capable. Also:
at-chat lte1 input="AT+CGDCONT\?"
  output: +CGDCONT: 1,"IPV6","","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0 +CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0 +CGDCONT: 3,"IPV4V6","sos","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,
          0,1 +CGDCONT: 4,"IP","","0.0.0.0",0,0,0,0 +CGDCONT: 5,"IP","free","0.0.0.0",0,0,0,0 OK
seems to show that ipv4v6 is possible on "ims" and "sos" PDP.
Does anyone know if there is anything I can do to get ipv4v6 working on chateau 12 ?
LoneRager
Re: ipv4+ipv6 on Chateau 12 LTE / Quectel EG12
Thu May 20, 2021 10:40 pm
I having the same issues. Would love any ideas to fix.
SiB
Mon May 24, 2021 7:43 pm
Please write to support@mikrotik.com
tschiex
Mon Jul 19, 2021 12:34 am
Hello Loneranger,
Did you contact Mikrotik support as suggested below? If yes, did you get an answer?
Thomas
tschiex
Mon Jul 19, 2021 3:37 pm
Well. I contacted them and got the solution (or more precisely, the beginning of a new adventure as I now get 2 IPV6 gateways on my LAN and this creates IPV6 chaos):
You should use dual APN functionality. Please create two separate APNs - one for IPv4 and the other for IPv6. Then assign both APNs to your LTE interface, for example, /interface/lte/set lte1 apn-profiles=ipv4,ipv6. You should see IPv4 address under /ip/address/print and IPv6 under /ipv6/address/print.
jonmansey
Tue Feb 15, 2022 8:15 pm
Any one have any luck with this? Im on AT&T with a EG12 modem. I got the v6 subinterface to go up once, but it didnt pull an address. I had IPv6 interface set to none, so I tried setting it to lte1 and lte1.v6 subinterface, but could never get the v6 sub interface to go up again after that.
I get this in the log
lte1 mbim: error: >>> E service: connect, command: connect, error: 2
Any ideas anyone? thx.
Edit, the subinterface went up after a while, but still no v6 address appearing anywhere.
Users browsing this forum: No registered users and 22 guests
