I'm still contemplating at this stage, but something tells me to just get the hardware and play with this... But a few questions here.. Looking at long haul, high throughput backhaul links, I'm planning a implementation where redundancy is NB critical.... Due to performance requirements (ASync links are definately a no go), I have no option here to go NStream2, which is fine. Now, due to the redundancy requirements, a second set of Mikrotik's are installed, and a second NSteram2 link is braught into the picture...
On the Ethernet side, it's easy enough to bring in redundancy over VRRP... But how on earth do I do this on NStream links? For this to work, all 4 radios on the WLAN must be able to see each other (default forwarding - on?), yet due to NStream2, the two masters will see each other, and the two slaves will see each other - the links will thus be independant, and VRRP will therefore not work on the Wireless segment... At the end of the day, these sites will act as a repeater (i.e. two NStream links per Mikrotik), with a drop off feed as a AP, either via a 5th radio, or Ethernet to an additional Mikrotik...
Any wise people out there with ideas??
